Masqqqqqqq(at)aol.com Guest
Posted: Thu Jan 12, 2006 11:43 am Post subject: glider wings on UltraStar? |
I hope this doesn't sound too outlandish.......but......
I have 1984 Kolb UltraStar which I purchased used in 1994. I've flown
it often, and love it. It's powered by a 447 Rotax.
Lately, I find myself interested in unpowered gliders. Here's the
question: Has anyone ever replaced the wings on an UltraStar with the larger
glider style wings, removed or downsized the engine, and had a glider? I suspect
there would be some balance issues to address, but I'm wondering if it's been
done.
Rich Iverson
Stevens Point, WI
JetPilot
Posted: Thu Jan 12, 2006 6:33 pm Post subject: Re: glider wings on UltraStar? |
There would be a LOT of drag issues. Its not just the wings, you need a new fuse also... In the end, you are better off just building a glider from the ground up if that is what you want.
If you try to make a powered ultralight into a glider, you will end up putting a huge amount of work into it and still have a dog that will not glide well. That is a really bad idea...
Kolb MK-III Xtra, 912-S |
rswiderski(at)earthlink.n Guest
Posted: Thu Jan 12, 2006 8:07 pm Post subject: glider wings on UltraStar? |
Hey Rich,
I often thought about doing what you are thinking with my old US. I
could catch thermals with engine off here in FL & get 100-150 fpm lift
sometimes, but usually it wasn't enough to get too far. I came close to
adding 3ft wing extensions using a piano hinge connection, but ended up
selling it, (I still wake up crying about that.) I was raised in Mosinee,
just north of you & still have family up there. -Richard Swiderski
