Yak52: Compressor - and replacement U/G bulbs
nigel(at)yakdisplay.com
PostPosted: Mon Apr 04, 2011 2:02 pm    Post subject: Yak52: Compressor - and replacement U/G bulbs Reply with quote
Thought I'd call on the power of the list.
Two separate enquiries re Yak52.
1. Have had several compressor failures in the last two years - shear pins (rivets) sheared in each case. Replaced each time with correct spec replacements. Compressor itself appears to be fine each time, goes a few hours before the next failure - although never after the same number of hours. Any ideas any one? Anything else to check (apart from replacing the compressor).
2. I've heard that U/C bulbs can be sourced from someone like LUCAS - and all that is required is for the lugs to be filed off. Does anyone know the part number for the official replacement from such a source or similar?
Nigel
dabear(at)devere.us
PostPosted: Mon Apr 04, 2011 3:27 pm    Post subject: Yak52: Compressor - and replacement U/G bulbs Reply with quote
You’ll need to overhaul the compressor.  That is the reason it keeps popping the shear pins.  Been there done that.
Bear
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Nigel Willson
Sent: Monday, April 04, 2011 5:49 PM
To: yak-list(at)matronics.com
Subject: Yak52: Compressor - and replacement U/G bulbs
Nigel
JOE HOWSE
PostPosted: Mon Apr 04, 2011 5:38 pm    Post subject: Yak52: Compressor - and replacement U/G bulbs Reply with quote
Do you ever start with the mags on?
J.C. HOWSE
mikeholoman(at)hotmail.co
PostPosted: Mon Apr 04, 2011 6:54 pm    Post subject: Yak52: Compressor - and replacement U/G bulbs Reply with quote
Do you run your engine at any point of your flying above 80% for more than 5 minutes? Like in an extended climb.
Subject: Re: Yak52: Compressor - and replacement U/G bulbs
Date: Mon, 4 Apr 2011 18:35:47 -0700
rget=_blank>http://www.matronics.com/Navigator?Yak-List
ttp://forums.matronics.com
=_blank>http://www.matronics.com/contribution
tigeryak18t
PostPosted: Mon Apr 04, 2011 8:53 pm    Post subject: Yak52: Compressor - and replacement U/G bulbs Reply with quote
Do you turn off the engine with respect of the procedures.......under 160degre Celsius ....... Without backfire ???
Didier Blouzard
+33 6 2424 3672
Nigel
ky∑Ëû€"ÕÌú¢Z+”M4”G⁄qÁ(∫∏ûÆw∞rã´âÍ”ÖÊê∏¨¥IöäQhÆÈî±Îax∆≠Æâ‚r¬‚≤—^j€´z√Zæ(∂ä̰∫ˬ«≠ÖÈöü"‚≤€≠äX≠âÎ,π»Z∞∏¨µIˇJÊÏr∏©∂*'∑!ä˜íy™‹Ñ:0ûZw∞⁄»ˬ«ÇÖ´E·¢⁄,Ö™fijwfπ»fπ»f¢∑öÜ∑üÜ€iˇ¸0¬f≠Æâ‚r«(õÛZæ(∂äÿjB‚≤ÿm∂üˇ√ &j⁄Ëû',râø5´‚Å´h≠ܧ.+-˝£Mç $ñNECI©ûÇ∑öµ 'µÈÌj[(jˆ¢ï¶Âz¯ö∂ñy±hÆÈ¨jfi~mߡfl¢ª¶≤f≠Æâ‚r«(ömߡfl¢ª¶≤f≠Æâ‚r«(õˆãäÀB¢{kâª≠äâ÷y¥¢µ‰·jy2¢ÁËØ*.Æßz∫.≤À©¶äÌ1´m∂•ï‚‚≤–ö)⁄Ü∑üÜ€iˇ¸0¬f≠Æâ‚r«(õ˜(û⁄‚nÎb¢xm∂üˇ√ &j⁄Ëû',râørâÌÆ&Ó∂*'˝Ø€˝˙'∑˙k{ˆËw/·∂i
Didier Tiger YAK18T
Member of Commemorative Air Force
French Wing
PostPosted: Mon Apr 04, 2011 11:08 pm    Post subject: Yak52: Compressor - and replacement U/G bulbs Reply with quote
Yes. Cooled to below 150, and it never backfires
No. Only take off at 100%. Then almost immediately 80/80.
It does a lot of aeros but only at MCP (82%/Full Throttle).
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Mike Holoman
Sent: 05 April 2011 03:52
To: Matronics Yaks
Subject: RE: Yak52: Compressor - and replacement U/G bulbs
rget=_blank>http://www.matronics.com/Navigator?Yak-Listttp://forums.matronics.com=_blank>http://www.matronics.com/contribution
PostPosted: Mon Apr 04, 2011 11:10 pm    Post subject: Yak52: Compressor - and replacement U/G bulbs Reply with quote
OK. That was the next step. Assume that cured the problem?
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of dabear
Sent: 05 April 2011 00:23
Bear
Nigel
PostPosted: Mon Apr 04, 2011 11:11 pm    Post subject: Yak52: Compressor - and replacement U/G bulbs Reply with quote
No. Always on the shower, then the mags.
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Joe Howse
Sent: 05 April 2011 02:36
tigeryak18t
PostPosted: Mon Apr 04, 2011 11:28 pm    Post subject: Yak52: Compressor - and replacement U/G bulbs Reply with quote
OK so you have to overhaul your compressor. The bog deal is to unmount the six screws. You will need to have the bended tool or to make it.
These screws are so difficult to reach and tight that most time they are not tighten as they should.
After the compressor itself is not a big deal
BTW, unmounting is OK but mounting is another thing.
Russian make the unmounting overhauling and remounting in about half a day.
Better count two days.
Didier
2011/4/5 Nigel Willson <nigel(at)yakdisplay.com (nigel(at)yakdisplay.com)>
[quote] --> Yak-List message posted by: "Nigel Willson" <nigel(at)yakdisplay.com (nigel(at)yakdisplay.com)>
Didier Tiger YAK18T
French Wing
dsavarese0812(at)bellsout
PostPosted: Tue Apr 05, 2011 3:25 am    Post subject: Yak52: Compressor - and replacement U/G bulbs Reply with quote
Totally agree regarding the compressor. Or replace it with a new one of
course.
Regarding the bulbs, OSRAM 3899 is a direct replacement and has the
correct case and bayonet.
Dennis
Bear
[mailto:owner-yak-list-server(at)matronics.com] *On Behalf Of *Nigel Willson
*Sent:* Monday, April 04, 2011 5:49 PM
*To:* yak-list(at)matronics.com
*Subject:* Yak52: Compressor - and replacement U/G bulbs
or similar?
Nigel
