turbot
Posted: Wed Apr 06, 2011 8:21 pm Post subject: MK3 Stol performance |
I am in the market for a 2 place folding wing aircraft.
Will be flown from an unimproved farm field. Cruise speed is of no concern, STOL perf & rough field use are .
What is the general opinion of a Mk3 compared to a Kitfox / Avid ?
elleryweld(at)aol.com Guest
Posted: Thu Apr 07, 2011 3:49 am Post subject: MK3 Stol performance |
having flown a Kitfox and owning 3 diferent models of Kolbs the Kolb will Get off the ground Quicker and Has much more room in the cockpit and better View than a Kitfox
Ellery Batchelder Jr.
pj.ladd(at)btinternet.com Guest
Posted: Thu Apr 07, 2011 6:20 am Post subject: MK3 Stol performance |
Cruise speed is of no concern, STOL perf & rough field use are >>
Hi,
there are planes with better wing fold systems but with big tyres (tires)
the Xtra will take some beating for STOL peformance from a rough field
Pat
ghaley(at)wt.net Guest
Posted: Thu Apr 07, 2011 6:43 am Post subject: MK3 Stol performance |
You might want to take a look at the Highlander from Just Aircraft.
YouTube "Highlander"
or Google "Just Aircraft".
--- turbot(at)shaw.ca wrote:
Subject: MK3 Stol performance
Date: Wed, 6 Apr 2011 21:21:40 -0700
http://forums.matronics.com/viewtopic.php?p=336331#336331
herbgh(at)nctc.com Guest
Posted: Thu Apr 07, 2011 10:43 am Post subject: MK3 Stol performance |
I met a fellow who had one of those....87,000 bucks....Herb
At 09:40 AM 4/7/2011, you wrote:
Posted: Thu Apr 07, 2011 10:55 am Post subject: MK3 Stol performance |
Maybe that's what he was asking.... That is a very fine airplane. There is a fellow locally who built his own with a Jab
and I see no negatives in owning one. It is convertible from nose to tailwheel.
BB
On 7, Apr 2011, at 2:35 PM, Herb wrote:
> From: "turbot" <turbot(at)shaw.ca>
> To: kolb-list(at)matronics.com
> Thanks
Posted: Thu Apr 07, 2011 4:36 pm Post subject: MK3 Stol performance |
He went to the factory in South Carolina and did some sort of
builders assist program....912s engine...Said that it cost him
87k. Basically a glorified kit fox...imho.. Herb
At 01:53 PM 4/7/2011, you wrote:
to tailwheel.
BB
>> Thanks
ces308
Joined: 03 Nov 2008 Posts: 317 Location: houghton lake ,mi
Posted: Thu Apr 07, 2011 7:50 pm Post subject: Re: MK3 Stol performance |
I would have to agree with Ellery on the Kit Fox...they are very small inside and the flapper-on system is not very accommodating in a short field landing as you lose 80% of the ailerons when you drop the flaps...very uncomfortable on a windy day ! I love my M3X/Jabiru airplane !
chris ambrose
M3X/Jab A-2200 180.00 hrs
N327CS
search youtube .... ces308.... check out Roberts Landing...
Posted: Fri Apr 08, 2011 5:25 am Post subject: MK3 Stol performance |
I have built & flown a Highlander from Just aircraft and I am not impressed with the airplane
turbot
Posted: Fri Apr 08, 2011 10:33 am Post subject: Re: MK3 Stol performance |
Good Day
The Highlander is to expensive & very few on used market.
I ask about STOL perf here because very little is said about it here, where as the Fox/flyer forums mention weight, landing & takeoff roll alot.
The early Fox/flyers had wings designed strictly for stol, & latter changed for increased speed. After a year of lurking here I cant remember anyone comparing airfoils in regards to low speed lift.
[b]Hi,
the Xtra will take some beating for STOL performance from a rough field
Pat [/b]
Is the Fox/flyer folding system better than Kolbs ?
This is important as our shed door is only 15' wide.
Is an Extra a better choice for stol / rough that a Mk3 ?
I have not been in a MK3 , so the comments about more interior room are appreciated.
Better visibility would be a plus to.
Thanks for all comments, keep them coming
Dana
Posted: Fri Apr 08, 2011 12:45 pm Post subject: MK3 Stol performance |
At 02:33 PM 4/8/2011, turbot wrote:
| Quote: | Is the Fox/flyer folding system better than Kolbs ?
This is important as our shed door is only 15' wide. |
The Kitfox wing fold system is probably easier than even the Kolb... just pull the pin at the front strut and fold it back. No strut removal, and no need to fold the tail. I believe it's still within the 8'5" max highway trailer width. It probably also needs less door clearance on top since it's not a high mounted pusher engine. I've never flown one though, gotta hit my buddy up for a ride.
-Dana
"The difference between death and taxes is death doesn't get worse every time Congress meets." -- Will Rogers
