First Flight!
capt_riney(at)yahoo.com
PostPosted: Sat Apr 09, 2011 6:00 pm    Post subject: First Flight! Reply with quote
After more years building than I care to admit, my Mark3 Classic made it's first flight today. It was a short flight because the engine overheated shortly after takeoff after I turned to downwind. It was running about 135F prior to takeoff, and I had not had any problem with it during previous taxi tests (I had 3.6 hrs engine run time prior to first flight). Airplane handled well, slight left wing heaviness (I fly from the left seat). I made a quick loop around the pattern and landed. I let myself be distracted by the coolant temp and the EIS light flashing red, and dropped the landing in a little. Slightly bent the left gear. Looking at the video, it wasn't the prettiest landing, but I really didn't think it was hard enough to bend the gear leg. I guess I'll be getting a new one from Travis, or the steel gear if I can retrofit it on a Classic. I've heard folks say you can straight the gear leg and reuse it, but I'm a little worried about bending
aluminum a lot (is it heat treated?).
Not sure what to do about the coolant temp. I had quite a bit of trouble during the engine break-in with coolant temp and had to run two garden hoses (one to each radiator) to waterfall water over it to get thru the engine breaking. I figured this was just because engine break-in is a static test and the engine was new so the seals were being rubbed in. Since then I've had no problems until today. I don't have a coolant recovery bottle but I haven't noticed any fluid coming out of my overflow tube. I'll check the radiator level when the engine cools down and see if it's low. I did burp the system several times during breakin and again after first flight. Didn'd see a lot of air coming out. The engine is new but the twin radiator is used. Instead of the expensive Rotax cross under molded hose I have a a short radiator hose from each radiator connected to a copper cross under tube, but not sure why that wouldn't work. I do have a BRS (canister) and
the Rotax engine mounted oil tank, so there is quite a bit of blockage in front of the radiators. I may have to make a pair of baffles to improve the airflow.
All in all it was an exciting day. Can't wait to get it fixed and get flying again.
Mark Rinehart
Indy Mark3 N68MR
rickofudall
PostPosted: Sat Apr 09, 2011 7:18 pm    Post subject: First Flight! Reply with quote
Mark, The gear legs are 7075-T6. Pretty tough stuff, they'll handle being straightened more than a few times. I'll tell you what Travis told me, aluminum gear legs are a lot cheaper than fuselage frames. I had similar problems with the Rotax radiators and got rid of them for a one piece motorcycle unit. Try putting an airfoil shaped block off plate in the gap between the radiators to force the air through them rather than letting it spill around the edges.
Rick Girard
On Sat, Apr 9, 2011 at 8:55 PM, mark rinehart <capt_riney(at)yahoo.com (capt_riney(at)yahoo.com)> wrote:
--> Kolb-List message posted by: mark rinehart <capt_riney(at)yahoo.com (capt_riney(at)yahoo.com)>
Mark Rinehart
Indy Mark3 N68MR
http://forums.matronics.com
le, List Admin.
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
  - Groucho Marx
by0ung(at)q.com
PostPosted: Sun Apr 10, 2011 6:34 am    Post subject: First Flight! Reply with quote
airflow.
again.
Mark Rinehart
congratulations on the first flight!!!!!! and sorry about the gear.
ok... from your description i'm not sure what engine you have.... you
mentioned the rotax engine mounted oil tank... are we talking 912, oil
tank or 2 cycle oil tank? you mentioned the coolent temps, how were the
exhaust temps? if you can send a couple pictures of your engine set
up... i am sure someone can help figure a solution. i would invest in a
coolant recovery bottle,,, what kind of antifreeze are you using, and at
what concentration?
boyd young mkiii
Jason Omelchuck
PostPosted: Sun Apr 10, 2011 7:34 am    Post subject: Re: First Flight! Reply with quote
When I slightly bent my aluminum gear, I just unbolted it and turned it 180 degrees in the socket so it was now slightly bent down.
Attached is a picture of my MKIIIC with a steel gear made to John H specs.
 Filesize:  2.12 MB
 Viewed:  7649 Time(s)
Jimmy Young
PostPosted: Sun Apr 10, 2011 8:06 am    Post subject: Re: First Flight! Reply with quote
Mark,
#1, Congratulations on your 1st flight.
I've bent a bunch of gear legs on my Firestar (at least 4 times & I think more). They straighten out pretty easily with a good press.
Have fun & fly safe -
Jimmy Young
Missouri City, TX
Kolb FS II/HKS 700
lcottrell
PostPosted: Sun Apr 10, 2011 9:10 am    Post subject: First Flight! Reply with quote
Gang,
The current thoughts concerning alum landing gear as being a safety feature is contrary to my findings. I have had to do three repairs to my Firestar due to the bending "Safety feature" of alum. legs. I am convinced that if the current steel gear legs had been on my plane the damage would have been significantly less, or non existent, in all three of these incidents.
My last incident, thankfully three years ago, was because of a very hard landing that broke the axle fitting. ( I had stalled the plane about 30-35 feet above the ground, almost leveled out but hit on the right gear leg.) the front angled gear dug into the ground and sheared the tubes on either side of the cage as well as the rivets holding the boom tube in place. The other two incidents bent the legs, one slewing me around into a ditch, the other snapping off upon hitting a rock during an off field landing.
The steel legs that I have now actually have enough spring in them to boost me back into the air a hell of a lot softer and more recoverable than would happen if the leg bent . My point is that the legs bending can end up causing more trouble than if the gear absorbs the "impact" with the springy feature of the steel legs. Yeah, enough impact or a really hard landing is going to tear some things up, but it will at least take a serious one.
My gear legs are designed after the ones that John and his brother Jim, made rather than the factory ones. I haven't seen them, so I cannot comment, but mine have a lot of spring in them that will absorb a lot of shock. There is no way that I would fly in the country that I currently live in with alum gear legs. The thought is that alum absorbs shock, thus preventing damage to the cage. The only problem with that is generally when the gear is absorbing said shock, you are still going to have to deal with the fact that your plane is still moving, either forward, or perhaps sideways if the gear bends. The damage occurs after the legs bend. Steel will return to as normal a position as it is able after the impact occurs. Alum. never does, and often then is when the damage occurs.
Now it is true that the worst injury that I received from these "adventures" was a bunged up middle finger. Who knows things might have been worse. I do know that Homer definitely designed a cage that absorbs shock better than any other home built out there, I just don't believe that alum is better than steel. I think it is too weak a link.
Peace time Ace!
Larry
slyck(at)frontiernet.net
PostPosted: Sun Apr 10, 2011 9:12 am    Post subject: First Flight! Reply with quote
The key word(s) here are GOOD PRESS. The MkIII aluminum legs will take a lot of force to straighten.
One of the respondents said to turn it 180 and stick it back in. Good advice, but alignment will be an issue.
When you stick it in the press you will have to exceed the current bend in the opposite direction by a good amount.
Be careful to block and jig it so you won't get hurt.
My only bent leg wasn't due to pilot error but mechanic error, over eager to shoot around the patch before the carb was
set up right. Quit at 50' on short final when I retarded the little lever. Good thing I was past the expressway.
A hasty dive saved the rest of the plane.
The best of us can still bend one though. All you need is an unpredictable gust at the last minute and you will be in
a precarious position. I've done a few swoop and skim maneuvers since and have lucked out.
Having a fast engine spool up response is mucho importante.
BB
MkIII, suzuki
On 10, Apr 2011, at 12:06 PM, Jimmy Young wrote:
Mark,
Jimmy Young
Missouri City, TX
Kolb FS II/HKS 700
http://forums.matronics.com/viewtopic.php?p=336531#336531
Kip
PostPosted: Mon Apr 11, 2011 6:12 pm    Post subject: Re: First Flight! Reply with quote
Congrats...!
2000 Firestar II
R503 DCDI
VLS 750
2010 Waiex
Jabiru 3300
2020 Pitts Special S-1C
