JABIRU 3300 BRAND NEW OVER TEMPERATURE DURING TAXI
gsessare(at)hotmail.com
PostPosted: Sun Apr 10, 2011 9:06 am    Post subject: JABIRU 3300 BRAND NEW OVER TEMPERATURE DURING TAXI Reply with quote
Hi Everybody,
I am Gustavo from ARGENTINA and I bought 1 year ago an Europa xs monowhell 99 % complete with jabiru 3300 brand new and airmaster 3 balde cs brand new
pjeffers(at)talktalk.net
PostPosted: Sun Apr 10, 2011 11:25 am    Post subject: JABIRU 3300 BRAND NEW OVER TEMPERATURE DURING TAXI Reply with quote
Hi Gustavo,
Just one silly thought.  If you bought the aircraft in the States your temperatures readouts would probably be set up in Farenheit units rather than centigrade. Check your units.
Pete
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Gustavo Sessarego
Sent: 10 April 2011 18:03
Subject: JABIRU 3300 BRAND NEW OVER TEMPERATURE DURING TAXI
Hi Everybody,
I am Gustavo from ARGENTINA and I bought 1 year ago an Europa xs monowhell 99 % complete with jabiru 3300 brand new and airmaster 3 balde cs brand new.
now is time to mout take the first test fly and I find out that during taxi engine temperature is 150° celcius at 1400 rpm so I richt the runway for take off run at 190° celcius so I must stop engine for proctection.
Engine Manual says 150° maximun continues and 175° maximun.
note: outside temperature was only 20° celcius
Any advise.....?
regards from Buenos Aires -Argentina
Checked by AVG - www.avg.com
04/10/11
PostPosted: Sun Apr 10, 2011 4:03 pm    Post subject: JABIRU 3300 BRAND NEW OVER TEMPERATURE DURING TAXI Reply with quote
thanks Pete,
I have a uMONITOR and it works on Celcius.....!!
thanks again
GUS
SubjecPete, t: RE: JABIRU 3300 BRAND NEW OVER TEMPERATURE DURING TAXI
Date: Sun, 10 Apr 2011 20:17:43 +0100
Hi Gustavo,
Pete
Hi Everybody,
europa471
PostPosted: Sun Apr 10, 2011 4:41 pm    Post subject: JABIRU 3300 BRAND NEW OVER TEMPERATURE DURING TAXI Reply with quote
Gustavo
Join the Jabiru Engine Matronics Forum and put your question there. There is plenty of work being done.
Lance Sandford in OZ
On 04/11/2011 10:00 AM, Gustavo Sessarego wrote: [quote] thanks Pete,
thanks again
GUS
From: pjeffers(at)talktalk.net (pjeffers(at)talktalk.net)
Hi Gustavo,
Pete
From: owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com) [mailto:owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com)] On Behalf Of Gustavo Sessarego
Hi Everybody,
Any advise.....?
regards from Buenos Aires -Argentine
europa471
PostPosted: Sun Apr 10, 2011 8:33 pm    Post subject: JABIRU 3300 BRAND NEW OVER TEMPERATURE DURING TAXI Reply with quote
Gustavo
thanks again
GUS
Hi Gustavo,
Pete
Hi Everybody,
Any advise.....?
grahamsingleton(at)btinte
PostPosted: Mon Apr 11, 2011 1:16 am    Post subject: JABIRU 3300 BRAND NEW OVER TEMPERATURE DURING TAXI Reply with quote
look at the induction system, you need straight flow into the single carb or mixture will vary between the cylinders too much, a smooth curve elbow doesn't work well.
Graham
Sent: Monday, 11 April, 2011 1:00:39
Subject: RE: Europa-List: JABIRU 3300 BRAND NEW OVER TEMPERATURE DURING TAXI
thanks Pete,
thanks again
GUS
.ExternalClass .ecxshape {} .ExternalClass p.ecxMsoNormal, .ExternalClass li.ecxMsoNormal, .ExternalClass div.ecxMsoNormal {margin-bottom:.0001pt;font-size:12.0pt;font-family:'Times New Roman';} .ExternalClass a:link, .ExternalClass span.ecxMsoHyperlink {color:blue;text-decoration:underline;} .ExternalClass a:visited, .ExternalClass span.ecxMsoHyperlinkFollowed {color:blue;text-decoration:underline;} .ExternalClass p {margin-right:0cm;margin-left:0cm;font-size:12.0pt;font-family:'Times New Roman';} .ExternalClass pre {margin-bottom:.0001pt;font-size:10.0pt;font-family:'Courier New';} .ExternalClass span.ecxEmailStyle19 {font-family:Arial;color:navy;} _filtered {} .ExternalClass div.ecxSection1 {}
Hi Gustavo,
Pete
Hi Everybody,
Any advise.....?
http://www.matronics.com/Navigator?Europa-Listhttp://forums.matronics.com
04/10/11
jimpuglise(at)comcast.net
PostPosted: Mon Apr 11, 2011 6:26 am    Post subject: JABIRU 3300 BRAND NEW OVER TEMPERATURE DURING TAXI Reply with quote
Gus-
Graham makes a good point. There is a section in the installation manual that talks about the induction system. Many Jab users don't even use SCAT tubing because the rough sides create turbulence going into the carb. I just replaced the SCAT tubing between my airbox and the carb with rubber tubing. If you want to do that, there is a NAPA part number (I think it is a radiator hose for an older Ford truck) that you can make it from. In addition, Jab recommends that you use a "cobra head" between the tube and the carb. Also, are you able to monitor the CHT and EGT in each cylinder? That can be important since different cylinders will cool at different rates. If you have only one "hot" cylinder, you can address just that one. All I am saying is based on what I have picked up during my build. I was about to start the engine last week and lost the EMS, so until it gets back from Dynon I am dead in the water. Also, your cooling output needs to be at least 3X your air input area.
Jim
PostPosted: Mon Apr 11, 2011 3:19 pm    Post subject: JABIRU 3300 BRAND NEW OVER TEMPERATURE DURING TAXI Reply with quote
thanks Jim, I was a bit cryptic, (again) I spent a year faffing about trying to help some guys with a Jab6 Europa. After telling them more than once to talk to Tony Higgins they did and he fixed it for them. Instead of a nice smooth elbow, a square box worked like a charm. What a difference!
Tony is so clever he never needed this forum! (He used to tune rally cars)
Graham
From: "jimpuglise(at)comcast.net" <jimpuglise(at)comcast.net>
Sent: Monday, 11 April, 2011 15:13:07
Subject: Re: JABIRU 3300 BRAND NEW OVER TEMPERATURE DURING TAXI
p {margin:0;}
Gus-
Jim
AirEupora
PostPosted: Tue Apr 12, 2011 6:05 am    Post subject: Re: JABIRU 3300 BRAND NEW OVER TEMPERATURE DURING TAXI Reply with quote
I can not address this problem as I have not run my engine, but I was told by Jim McCormick to build a square box in front of the carburetor. I'll include a couple of pictures.
 Filesize:  798.26 KB
 Viewed:  12865 Time(s)
 Filesize:  787.76 KB
 Viewed:  12864 Time(s)
 Filesize:  785.56 KB
 Viewed:  12863 Time(s)
budyerly(at)msn.com
PostPosted: Thu Apr 14, 2011 5:40 pm    Post subject: JABIRU 3300 BRAND NEW OVER TEMPERATURE DURING TAXI Reply with quote
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Just a note on Jabiru 3300 (solid lifter) cooling issues on the ground and in the air that we've experienced here at Custom Flight Creations.
We just finished about 100 hours of research and development trying to get Dr. John Kershner's Jabiru with the nice looking Andy Silvester Cowl to cool. Propeller is a 64 inch Sensenich Wood Prop.
We drew heavily upon Sonnex, Jabiru techs and our own John Lawton's success.
We have built a similar looking but two part lunch box over cylinder duct for ease of accessibility and maintenance. The duct is part metal and fiberglass. The between cylinder barrel and head gaps were extensively worked to optimize airflow, cooling pressures and heat extraction.
Extensive work was done to try to direct and augment airflow through the square heads. (You know, air doesn't like to go around square corners or over and around those wires.)
Our results are very promising. Taxi for 25 minutes before the hottest cylinder gets to 275F at 80 F outside no wind. I can live with that.
Climb is possible to 3000 AGL at 75 KIAS and Max Continuous before we hit 304F (80F outside temp) then we must retard the throttle and accelerate to 90 IAS to keep the cylinders cool. At max continuous, it will stay right at max temp, however when we reapply full power, we are greeted again by temps going above redline, which is not acceptable.
The cowl exit has been extensively modified as the supplied duct on the bottom has proven to be a ram air intake so we added a cowl flap to get a better draw. The cowl inlets are a bit small for the fin spacing as air rapidly goes through the fins without picking up the heat. The spacing of the cylinders fins and their thickness are partially to blame on the old engines, but we can't fix that. The new engines were refined, but alas are not interchangeable with the older engine.
Oil Temps in the climb and 110 Knot cruise are within limits, thanks to a well sealed oil cooler, however, the oil temperature went up as speed increased above 120 KIAS at max continuous due to the poor design of the NACA and oil cooler placement. Yes it is true, as the speed goes up the air stalls at the oil cooler and decreases its efficiency to nil. More work needed, but trying to do it without messing up his paint is a pain.
The engine at cruise will die if the carb heat is pulled and then the throttle retarded so we have a carburation issue still. It is just too lean it seems. Many things may be at play. We'll investigate one at a time.
Shock cooling is a pain so the inlet has a dam on the front cylinders to help out, but it bears watching. We lazy Rotax people normally don't have to go to the cooling page of the EIS as part of our descent check, so make it part of your crosscheck.
To our friend in Argentina:
Thanks to Johns Lawton's and the Jabiru crowd's research, the mixture per cylinder has been identified as a problem in some of the stock engines. The induction system we found is prone to small leaks which leans the cylinders and causes high EGT and CHT. We are pulling the carb (again) to take out the owner installed lean kit. The smooth bore inlet to the carb is a good idea, but please ensure the hose clamps and rubber and gasket parts in the induction are sealing well. Also, the induction hose must be able to hold its shape and still be flexible enough to take engine movement. If that tube collapses your engine dies. My experience has been if your cylinders are running hot and the EGT is high, fix the induction, by either fixing air leaks, jetting the carb differently or moving the mixture clip or both. I have not tried rotating the carb off axis.
John Kershner's plane was a 95 knot trigear and now goes 127 knots at max continuous with a speed kit properly installed and some cooling drag massaging. I was surprised that the 100HP 912S goes faster, but then again, prop speed and size and a gearbox multiplies the torque so they are about even as far as engines go with fixed pitch props.
The Jabiru USA Rep, Pete K, was emphatic that tuning and cooling issues were best answered by using a Sensenich 62 inch wood prop. As the engine rpm passes 2750 or so, torque drops off and engine horsepower increases with engine speed but not a lot of extra power is felt. Propeller airplanes fly on torque so his assumptions make sense when comparing engine charts side by side. Most guys don't consider the torque multiplier of the 2.43 gearbox on a Rotax. The Rotax prop turns slower at 2250 RPM which looses out in potential thrust on a short 64 inch prop where as the short bladed Jabiru turns near 2750 RPM at max continuous. But it burns more gas turning that fast.
The Jabiru is a nice looking engine that came on line before all the bugs were worked out, in my opinion, and it is a bit of time and patience to get it right. I have watched many folks on the net and after about 2 years of tinkering it works OK.
I just had to look at it myself, as I have avoided the Jabiru in the past as heavier, thirstier, and harder to cool. I can make a Rotax cool with my eyes closed assembling the FWF. But what is life without challenges... I have put a couple thou of my own money into working out the deficiencies for my owners at the shop and we may do a cooling 102 on the Jab for those suffering in silence who are still willing to experiment... If it works, parts will be made available.
Here's hoping that we get all the bugs out.
Best Regards,
Bud Yerly
Still recovering from Sun 'n Fun.
PostPosted: Fri Apr 15, 2011 12:22 am    Post subject: JABIRU 3300 BRAND NEW OVER TEMPERATURE DURING TAXI Reply with quote
Sent: Friday, 15 April, 2011 1:18:37
Subject: Re: Re: JABIRU 3300 BRAND NEW OVER TEMPERATURE DURING TAXI
Hi Bud
I think the uneven mixture is a serious issue with the Jab6. If the inlet to the carb is curved the airspeed in the venturi will not be equal across the whole area so the spray of droplets will be uneven too. To a certain extent the same thing happens with Rotax so the front cylinders get more fuel than the rear at some throttle settings, drops of fuel don't turn corners the same as air molecules!
Both engines need fuel injection imho. Or a redesign of the induction system to get the fuel/air mixture properly dispersed before any splitting
Graham
Bud Yerly
budyerly(at)msn.com
PostPosted: Fri Apr 15, 2011 1:51 pm    Post subject: JABIRU 3300 BRAND NEW OVER TEMPERATURE DURING TAXI Reply with quote
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> You bet.
Bud
