Posted: Fri Apr 15, 2011 7:53 am Post subject: JABIRU 3300 BRAND NEW OVER TEMPERATURE DURING TAXI |
Hi! Frans, Graham /all
With comments about the Jabiru you are subjecting me to a nightmare
!!!!!!!!!!!! don't tempt me !
Bob Harrison G_PTAG
| Quote: | ----Original Message----
Date: 15/04/2011 11:46
Subj: Re: Re: JABIRU 3300 BRAND
| Quote: | I think you are right, much more logical conclusions than mine !
| Quote: | Agree about the Jabiru also, sad but geared and liquid cooled will
always have a
| Quote: | performance advantage. More complication too of course but a more
sensible
| Quote: | compromise I think.
| Quote: | ________________________________
| Quote: | From: Frans Veldman <frans(at)privatepilots.nl>
| Quote: | Sent: Friday, 15 April, 2011 11:17:12
| Quote: | Subject: Re: Re: JABIRU 3300 BRAND NEW OVER TEMPERATURE
DURING
| Quote: | On 04/15/2011 10:17 AM, GRAHAM SINGLETON wrote:
| Quote: | > To a certain extent the same thing happens with Rotax so the front
| Quote: | > cylinders get more fuel than the rear at some throttle settings,
drops
| Quote: | > of fuel don't turn corners the same as air molecules!
| Quote: | I believe the "problem" with the Rotax is of a different nature.
There
| Quote: | are two carbs, and the inlet pulses are not equally distributed. Each
| Quote: | carb will see two inlet pulses in sequence, then followed by a long
| Quote: | pause when the cylinders on the other side (fed by the other carb)
have
| Quote: | their respective inlet pulses.
| Quote: | After the pause, the flow of fuel inside the nozzles is stalled. With
| Quote: | the first cylinder breathing, the fuel has to start moving again, and
| Quote: | the second cylinder has the benefit that the fuel is already up to
| Quote: | speed. So the second cylinder in the sequence receives a slightly
richer
| Quote: | A solution can be to use a bigger bore balance tube. Some Italian
| Quote: | company is selling a pair of manifolds and balance tube for this
| Quote: | purpose, and the manifolds have already the bosses in them to mount
fuel
| Quote: | injectors for future upgrades (and using the carbs as fuelless
throttle
| Quote: | bodies and backup in case the EFI fails).
| Quote: | Ok,the subject was "Jabiru". To keep it in the subject: After the
long
| Quote: | list of problems and disadvantages, can anybody enlighten me what the
| Quote: | benefit is of the Jab over the Rotax? (I assume there must be one,
why
| Quote: | else would anyone bother to install one?)
| Quote: | Frans==================
budyerly(at)msn.com Guest
Posted: Fri Apr 15, 2011 1:52 pm Post subject: JABIRU 3300 BRAND NEW OVER TEMPERATURE DURING TAXI |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> I had thought I was the only one with sleepless nights.
Bud
