APRS Antenna
rene(at)felker.com
PostPosted: Thu Apr 21, 2011 5:54 pm    Post subject: APRS Antenna Reply with quote
For those of you using APRS: What antenna are you using and where did you
mount it.
Rene'
N423CF
801-721-6080
dlm34077(at)q.com
PostPosted: Thu Apr 21, 2011 8:34 pm    Post subject: APRS Antenna Reply with quote
a stubby inside the tail fairing.
Tim Olson
PostPosted: Fri Apr 22, 2011 5:54 am    Post subject: APRS Antenna Reply with quote
I used a Comant COM antenna, with the guts removed, and trimmed to the
proper length. You probably can't beat a belly whip for performance.
But, there is a great j-pole made by Pete Howell in Minnesota
that you can use that if you're not using metallic paint in the
wingtips, is very easy to put into a wingtip and performs great
too.
Tim Olson - RV-10 N104CD
mount it.
Rene'
N423CF
801-721-6080
