Harv
Posted: Sun Apr 24, 2011 12:23 am Post subject: Removing chinese radio kit from cj6 |
Hi
Could anyone offer some advice on removing the old radio components from a cj6?
I'd like to remove as much of the redundant stuff as possible.
We've pulled out the rear large adf box and rotating head unit and also taken out the coffee grinder style radios but i've drawn a blank as to what components we need to leave for the compass to work correctly?
I'd like to construct a baggage compartment behind the rear seats and yesterday I unbolted the large and heavy unit that is located on the removable shelf directly behind the rear cockpit seat but i'm unsure if this unit is required?
Also can any of the components that are bolted between the front and rear cockpits be removed?
TIA
Cheers
Harv
wlannon(at)persona.ca Guest
Posted: Mon Apr 25, 2011 9:41 am Post subject: Removing chinese radio kit from cj6 |
Hi Harv;
Everything aft of the rear seat with the exception of the SBL40 Inverter can
be removed along with associated wiring.
There are no gyro-compass components in that area.
On the shelf between the seats you can remove only one item. I cant' recall
the name right now but it is the central item, a grey box about 4.5" square
containing some large relays. This and all wiring can go.
Quote: | From left to right you must retain: -- SBL35 Inverter, TH3 Gyro unit, FL3
Amplifier, EX Junction Box and the Power Supply relay Box.
But; there could be complications: If your aircraft was modified to a solid
state voltage regulator that is also located on that shelf. Whether that
installation was done without moving other units I do not know.
Don't throw away anything yet! If you take the time you will find a number
of useful items for your spares box.
Cheers;
Walt
talew(at)bellsouth.net Guest
Posted: Mon Apr 25, 2011 11:24 am Post subject: Removing chinese radio kit from cj6 |
Walt I have 1965 CJ . The compass sensor is just in front of the rudder .
You don't want to injure those cables .
Terry
Posted: Mon Apr 25, 2011 12:41 pm Post subject: Removing chinese radio kit from cj6 |
Good point Terry;
On my 1965 and other early ones I have done it is in the LH outer wing. I
totally forgot about that change and you are right - so Harv - don't cut
those!!
Walt
Harv
Posted: Wed Apr 27, 2011 2:36 pm Post subject: Re: Removing chinese radio kit from cj6 |
Thanks for the info,
I should have said my Cj is a 1988 model
Since my post i've had a good look through the parts manuals and It appears something to do with the gyro compass is mounted up high in the tail just forward of the rear fin, I think this is what was just mentioned,
A separate post indicated some form of voltage regulation might be mounted between the cockpits and i'm almost certain there is an inverter mounted there and an identical one mounted in the tail. My guess would be the one in the tail used to supply the adf antenna / radio receiver and the one between the cockpits serves the instruments.
Hopefully I can identify and remove much of this, it weighs one hell of a lot! (Avgas is too expensive to give it a free ride )
Rgs
Harv
Adrian Coop Cooper
Joined: 02 Feb 2010 Posts: 37 Location: Vancouver, BC
Posted: Wed Apr 27, 2011 4:26 pm Post subject: Re: Removing chinese radio kit from cj6 |
Harv.
Mine is a 1988 as well. However, mine has a mechanical voltage regulator behind the firewall whilst my Buddies (same batch) has an electronic voltage regulator on the shelf between cockpits which I suspect was an air force installed mod.
I did manage to remove 166lbs of surplus wiring and tube radios including the complete ADF system. However, I did keep the Magnuson type compass in both panels which requires that remote system with the little window just before the tail. It is a very nice feature as you can use it as a bug ... sort of like a very poor man's RMI. I also kept the inverters and the nice electric DGs
So be careful not to remove something you might still like to have. My electrical Guru did a great job rewiring and I am running two King 196 VHFs a Garmin TX and a self enclosed Narco ILS all very nice and of course light weight. Once the ADF antenna and box is removed you can re-configure. Some folk modify the ADF box for tool and spare oil storage. Perhaps, a better alternative is to remove the ADF box's shelf aft and reconfigure as the battery (batteries 2x12v, modern, sealed, which will fit in the existing box) shelf. That then gives loads of room for a secure luggage area. This you can ensure is sealed to prevent FOD making its way back to cables and pulleys and still have a port and starboard access door as well as access from behind the rear seat. NB, the starboard access door is smaller than the one on the port side, so plan accordingly. This then leaves you the large removable panel on the starboard side, not only can you have the battery(s) there but it might be a good spot for a smoke tank. Of course this is all CofG and weight and balance dependent. I agree about not carrying excess weight at today's horrendous fuel prices. Be safe and good luck. Coop.
_________________ Coop |
Posted: Wed Apr 27, 2011 7:22 pm Post subject: Removing chinese radio kit from cj6 |
Hi Harv;
That is the actual magnetic compass for the Gyro Compass system. On the
very early aircraft like mine it was mounted near the LH wing tip.
Later moved to the better location in the aft fuselage as you described.
If installed (it is a military modification) the solid state voltage
regulator is mounted behind the rear seat either on the shelf or below that
on the front spar. I think Joe Howse was correct that it is on the spar.
You may or may not have that. The normal regulator is on the aft, upper, RH
side of frame #1.
There are two necessary inverters. Refer to my previous post. There is a
third one (for the ADF) located immediately behind the rear seat with all of
the comm radio, radio compass(ADF) and interphone system that you can
totally remove.
You bet it is heavy. With all associated parts and wiring you can remove
approx. 195 lbs. Of course you will later have to install some ballast to
compensate for it.
regards;
Walt
Posted: Wed Apr 27, 2011 7:30 pm Post subject: Removing chinese radio kit from cj6 |
Harv;
I should read before sending rather than after----- Referring to the solid
state voltage regulator I wrote "rear seat". Should have been front seat.
Walt
tigeryak18t
Joined: 26 Sep 2009 Posts: 233 Location: PARIS FRANCE
Posted: Thu Apr 28, 2011 12:31 am Post subject: Removing chinese radio kit from cj6 |
I had a warning from the Yak russian people concerning all these mod on Yak's.
BEWARE OF THE EFFECT OF NEW MASS REPARTITION
All these devices had been taken in account when testing the plane.
Change in repartition could have a very bad effect on the inverted spin recovery.
No other comments....
Didier
2011/4/28 Adrian Coop Cooper <cooperairracing(at)gmail.com (cooperairracing(at)gmail.com)>
Quote: | --> Yak-List message posted by: "Adrian Coop Cooper" <cooperairracing(at)gmail.com (cooperairracing(at)gmail.com)>
Harv.
So be careful not to remove something you might still like to have. My electrical Guru did a great job rewiring and I am running two King 196 VHFs a Garmin TX and a self enclosed Narco ILS all very nice and of course light weight. Once the ADF antenna and box is removed you can re-configure. Some folk modify the ADF box for tool and spare oil storage. Perhaps, a better alternative is to remove the ADF box's shelf aft and reconfigure as the battery (batteries 2x12v, modern, sealed, which will fit in the existing box) shelf. That then gives loads of room for a secure luggage area. This you can ensure is sealed to prevent FOD making its way back to cables and pulleys and still have a port and starboard access door as well as access from behind the rear seat. NB, the starboard access door is smaller than the one on the port side, so plan accordingly. This then leaves you the large removable panel on the starboard side, not only can you have the battery(s) there but it might be !
Coop
http://forums.matronics.com/viewtopic.php?p=338229#338229
rget="_blank">http://www.matronics.com/Navigator?Yak-List
le, List Admin.
Didier BLOUZARD
didier.blouzard(at)gmail.com (didier.blouzard(at)gmail.com)
0624243672
_________________ Didier Tiger YAK18T
Member of Commemorative Air Force
French Wing |
