jan_de_jong(at)casema.nl Guest
Posted: Sun May 01, 2011 10:53 am Post subject: Best device to ratify the Actual Fuel Flow on a 914 |
I intend to make a pair of Model 231 for general (marine) use work for
the 914.
Total factory direct cost is USD 220.
Jan de Jong
tonyrenshaw268(at)gmail.c Guest
Posted: Mon May 02, 2011 1:06 am Post subject: Best device to ratify the Actual Fuel Flow on a 914 |
I already have a 20B, which is a marine sensor, for gasoline engines, generally outboards such as 4 stroke Honda. Spec wise, it seems fine, and I have a feeling the internals are probably one and the same. Tempted just to get another one, as they are a little over $100.00 as I recall.
TR
On 02/05/2011, at 4:51 AM, Jan de Jong wrote:
I intend to make a pair of Model 231 for general (marine) use work for the 914.
Jan de Jong
kheindl(at)msn.com Guest
Posted: Mon May 02, 2011 4:02 am Post subject: Best device to ratify the Actual Fuel Flow on a 914 |
Ian,
I was confused. I thought I had the A model, as you suggested, but it is actually a B. Perhaps that is why I couldn't get it to work by using just the one plus a pulsation damper, as John Wigney had done successfully.
I will now get another B for the return line. Or would an A be compatible ?
The FS450 installation manual only mentions the part numbers for models B and C. The price is the same for all 3. The manual also warns about using aluminum fittings.
Cheers,
Karl
Subject: RE: Best device to ratify the Actual Fuel Flow on a 914
Date: Mon, 2 May 2011 10:57:56 +0100
.ExternalClass p.ecxMsoNormal, .ExternalClass li.ecxMsoNormal, .ExternalClass div.ecxMsoNormal {margin-bottom:.0001pt;font-size:12.0pt;font-family:'Times New Roman','serif';} .ExternalClass a:link, .ExternalClass span.ecxMsoHyperlink {color:blue;text-decoration:underline;} .ExternalClass a:visited, .ExternalClass span.ecxMsoHyperlinkFollowed {color:purple;text-decoration:underline;} .ExternalClass p {margin-right:0cm;margin-left:0cm;font-size:12.0pt;font-family:'Times New Roman','serif';} .ExternalClass pre {margin-bottom:.0001pt;font-size:10.0pt;font-family:'Courier New';} .ExternalClass span.ecxHTMLPreformattedChar {font-family:Consolas;} .ExternalClass span.ecxEmailStyle20 {font-family:'Calibri','sans-serif';color:#1F497D;} .ExternalClass .ecxMsoChpDefault {font-size:10.0pt;} (at)page WordSection1 {size:612.0pt 792.0pt;} .ExternalClass div.ecxWordSection1 {page:WordSection1;}
Karl and Jan
I am quoting what I have been told by both Grand Rapids and Part for Aircraft. I am waiting for an MGL FF1 (with the FT60 sensors) to go into the repair of G-IRON.
The 201B (and 201C) are capable of higher flow rates with slightly reduced resolution but, I believe, are still acceptable to the LAA . The Marine versions are probably also acceptable, cost less but are heavier.
Ian Rickard G-IANI XS Trigear, 300hours
Europa Club Mods Specialist
e-mail g-iani(at)ntlworld.com
target="_blank">http://www.matronics.com/Navigator?Europa-List
http://forums.matronics.com
