Dennis.Kirby(at)kirtland. Guest
Posted: Wed May 10, 2006 10:56 am Post subject: Redundancy |
<< does anyone have a specific suggestion to routing the fuel lines from
both the mechanical pump and an electric fuel pump. I have read on this site
where many use their electric fuel pump taking off and then shut it off for
normal flight. I am about to re hose and add an electric fuel pump.
Sucking air here in Ohio Ralph >>
Ralph -
The Rotax on my Kolb runs with two fuel pumps: A mechanical one, and a Facet
electric fuel pump. I plumbed my fuel pumps in series. No primer bulb.
The Facet is designed to allow unobstructed passage of fuel when it is
either off or failed. That allows me to turn it on or off at my convenience
(such as during takeoff and landing). Have had zero problems with this
setup since new.
Dennis Kirby
Mark-III, 912, 47 hrs
New Mexico
a58r(at)verizon.net Guest
Posted: Wed May 10, 2006 11:01 am Post subject: Redundancy |
The ultimate in redundancy is/was two seats!
regards,
Bob N.
Ralph Hoover
Joined: 09 Jan 2006 Posts: 206 Location: Central Ohio
Posted: Wed May 10, 2006 11:19 am Post subject: Re: Redundancy |
and a Facet electric fuel pump. I plumbed my fuel pumps in series. No primer bulb. The Facet is designed to allow unobstructed passage of fuel when it is either off or failed.
Dennis, Thank you. That is without a doubt what I will do. Now do you mount the electric pump close to the fuel tank (gulp..sparks), or is it mounted up along the frame of the cage so that you can see it?
Next, which model number pump is it and is it in the low (3 psi) range as previously described by others in order to not overcome the float bowles?
Thanks all for your assistance.
She'a gushin now ralph of Ohio
rlaird
Posted: Wed May 10, 2006 11:50 am Post subject: Redundancy |
Dennis --
The Facet isn't fail-safe. I had one where the internal check valve
got stuck. When it was on and pumping, everything was fine. But when
I turned it off, it created enough of a restriction that, under WOT,
it couldn't fill the bowl fast enough. That was responsible for the
one and only engine-out I've ever had. (I forgot to turn it on during
take-off, and the engine cut out at about 200 feet. Luckily, I landed
straight ahead without incident.)
It took me quite a while to diagnose the problem, helped in large part
to a fuel flow meter I had. Replacing the Facet fixed the problem, of
course. And now I don't forget to turn it on!
-- Robert
On 5/10/06, Kirby Dennis Contr MDA/AL <Dennis.Kirby(at)kirtland.af.mil> wrote:
Ralph -
setup since new.
Dennis Kirby
New Mexico
Robert Laird
Houston, TX area
http://www.Texas-Flyer.com |
Posted: Wed May 10, 2006 12:15 pm Post subject: Redundancy |
| -- Robert
Seems like that would be a good case for doing a full power runup
prior to takeoff with the electric pump shut down.
Would have to hold WOT long enough until you were satisfied the engine
driven pump was going to pump enough fuel to keep the engine happy.
My experience with 2 and 4 stroke Rotax engines indicates the both
shut down right now if they get a "little" starved for fuel.
I have been using a Facet and engine driven pump set up since 1987, on
my Firestar. Seems to be working well.
Primer bulbs were always a source of fuel delivery problems in the old
days. Maybe they have improved them since then. That's the first
thing not to be installed on my airplane.
I have had several ignition related engine failures with the Cuyuna
ULII02 and the point ignition 447. Lost the plug cap off a spark plug
on inverted engine, had an NGK BR8EV lose an electrode, and had plug
fouling twice. All four times put me in the forced landing mode and
on the ground. Dual ignition would have prevented the forced landings
until I could get to a suitable area to land and see what my problem
was.
Once I tried a JC Whitney "el cheapo" Facet look alike pump on the FS.
Was on one of my flights up to the Flight Farm in Monterey, NY. The
electric pump went belly up during the trip. While in the process of
cutting toilet paper and approximately 100 feet, the Mikuni engine
driven pump bit the dust. Very lucky to be in a position to push the
nose over and land in a nice hay field. Come to find out, the rebuild
kit I purchased from LEAF was a no name aftermarket kit. The diaphram
with its little flapper valves lasted about 30 minutes. I built the
pump at the Flight Farm. I pulled the old Mikuni diaphram out of the
trash can and reinstalled it. On my return home I contacted LEAF to
let them know of my disappointment in their inferior parts. They gave
me my money back, but did not seem too concerned about the problem.
No telling how many of us UL nuts out there were flying around with
these things. heehee
1500 and black as night outside. So dark the security light is
burning bright. Really erie feeling to know it is still the middle of
the afternoon, look up from the computer and see a totally black
window. So far the major thunderstorms are just north of my location.
Hunkered down at hauck's holler, alabama,
_________________ John Hauck
Titus, Alabama |
rlaird
Posted: Wed May 10, 2006 12:54 pm Post subject: Redundancy |
On 5/10/06, John Hauck <jhauck(at)elmore.rr.com> wrote:
| -- Robert
I've yet to find any brakes that would hold a 912 or 912S for a WOT
full power runup for that long, but maybe, with a large amount of
money, they can be found. (Probably put me on my nose! Prior
to this event, I had detected a much lower fuel flow rate than nominal
when at a high cruise speed. That was my first clue.
-- Robert
Robert Laird
Houston, TX area
Posted: Wed May 10, 2006 1:04 pm Post subject: Redundancy |
nominal
| -- Robert
The brakes are out there. MATCO makes a good set with 3/4" axles
w/tapered roller bearings (that are adjustable like real wheels), and
enough braking power to hold the 912uls. However, main gear located
in the stock position will put you on your nose.
Titus, Alabama |
Dave Bigelow
Joined: 29 Jan 2006 Posts: 103 Location: Kamuela, Hawaii
Posted: Thu May 11, 2006 1:27 am Post subject: Re: Redundancy |
Dennis,
The electric pump redundancy is a good idea. If you look at the specs for the Mikuni engine pumps that come with the two stroke Rotax engines, you'll see that they are rated to lift fuel no more than about 36 inches. Measure the distance to the mid point of your fuel tanks and you'll see that it is pretty close to that.
I've believed for some time that some of the mysterious engine seizures that seem to happen for no known reason are partial fuel starvation caused by the pulse pump not putting out enough fuel. The classic failure is a full power take off and climb, followed by a seizure when the power is pulled back.
The electric pump should be plumbed in parallel rather than in series. Both the mechanical and electric pumps have a built in check valve, so you don't need to add check valves unless you want more redundancy. If you plumb the pumps in series, the fuel pressure will be too high (unless you install a regulator), and either pump failing can block the single fuel path to the engine. There was a good article in "Ultralight Flying" several years ago by Arnold Anderson (Fight Safety Notebook) on the subject.
I don't see any reason to turn the electric pump off in flight unless you don't have battery charging, and want to save electricity.
_________________ Dave Bigelow
Kamuela, Hawaii
FS2, HKS 700E |
esteuber(at)rochester.rr. Guest
Posted: Thu May 11, 2006 2:41 am Post subject: redundancy |
You guys are making my head hurt from all this complication , I'm with =
BB on the simplistic side of the issue....The reason I got into =
ultralights was the shear joy of uncomplicated flight....also .... I =
tend to be a bit cheap so buying 2 of everything is not an option =
anyway...
Ed in Western NY
Richard Pike
Posted: Thu May 11, 2006 4:24 am Post subject: Redundancy |
I disagree that the pressure would be too high. I have a fuel pressure
gauge on the panel, my pumps are in series, and I learned that with both
pumps working, the fuel pressure pickup located between the Mikuni and
carbs, the pressure is 3 1/2 pounds.
I relocated the pickup for the pressure gauge, so that it now only
monitors the Facet electric pump. Still shows 3 1/2 pounds. Left the
pressure pickup at that location. I test the Mikuni during taxi out and
run up by turning the electric pump off, (fuel pressure gauge falls to
zero) engine still runs ok, Mikuni must be working, and drawing fuel
through the Facet.
Then I turn the electric pump back on for the rest of the flight. Should
the Mikuni fail in flight, as long as the pressure is showing 3 pounds
or better, I know I will get fuel, because I see no way for the Mikuni
to block the fuel that the electric pump is pushing into the inlet side.
Don't know about the article in Ultralight Flying, but I know what
works. It might get blocked up tomorrow, but it's worked fine since '98.
Richard Pike
MKIII N420P (420ldPoops)
Dave Bigelow wrote:
Dennis,
Dave Bigelow
Kamuela, Hawaii
FS2, Rotax 503 DCDI
http://forums.matronics.com/viewtopic.php?p=33990#33990
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
Posted: Thu May 11, 2006 8:07 am Post subject: Redundancy |
I have two electric fuel pumps plumed into my fuel system in series. I would
prefer one of my fuel pumps to be some thing other than electric but my
reduction drive sits were the mechanical fuel would be. I use a Facet as one
of my pumps. I would never want to depend on a Facet pump because I have
experienced a few failures with them.
I use the following procedure that tests both pumps before each flight. I
prime my carbs by turning on only the Facet pump which is the first in
series and is my backup or boost pump. I can physically see the flow rate as
I have a short piece of transparent fuel line just before the carbs. then I
turn it off. I then start the engine using only the primary pump and
continue thru warm-up and run up. Just before take off I switch on the Facet
pump. After takeoff I turn the Facet pump off.
I don't like to run both pumps all the time because I feel that I might be
wearing out both pumps and want to have at least one fairly unused pump
there for back up if my primary pump fails. This is also the same procedure
I was trained to use and described in the Piper Owners Manual. There must
have been reason Piper Aircraft suggested turning off the boost pump at
altitude so I follow the same guideline with my Kolb.
Rick Neilsen
Redrive VW powered MKIIIc
Posted: Thu May 11, 2006 8:48 am Post subject: Redundancy |
Easy to tell when the Facet is ready. -Turn on the ignition and wait
until the
tone changes and its ready to hit start.
For the person who wanted the low pressure number: 40105
AC Spruce has them in stock
-BB
On 11, May 2006, at 12:00 PM, Richard & Martha Neilsen wrote:
<NeilsenRM(at)comcast.net>
would
as one
have
flight. I
rate as
then I
Facet
might be
procedure
must
Rick Neilsen
Posted: Thu May 11, 2006 12:15 pm Post subject: Redundancy |
<< do you mount the electric pump close to the fuel tank (gulp..sparks), or
is it mounted up along the frame of the cage so that you can see it? ralph
of Ohio >>
Ralph - Using a pair of aluminum brackets spanning between two of the cage
members on the fuselage side, I fashioned a method to attach the Facet level
with the bottom of the fuel tanks and angled at 45 degrees (per fuel pump
installation instructions). Part of my preflight is to peer behind the seat
to inspect the pump, mostly for security of hose connections. Easy to see
and service (if needed).
<< Next, which model number pump is it and is it in the low (3 psi) range as
previously described by others in order to not overcome the float bowles? >>
| Quote: | From the ACSpruce catalog, I purchased the Facet model 40105, 2.5 to 4.5 psi
max, 12v, solid state pump. As it is solid state (not an electric motor),
there is no worry about sparks.
The Rotax manuals warn that pressures above 5.8 psi may lead to "override of
float valves," but there is some protection in the float bowl overflow
feature. The overflow can handle pressures up to perhaps 7 or 8 psi before
the floats become overwhelmed with too much incoming fuel. I have never yet
seen the carb bowls overflow on my Bings from the Facet pump being left on
(while the engine is running).
You are wise to follow the "keep it simple" advice from the List members
that offer it, with regard to fuel systems.
Dennis Kirby
Mark-III, 912ul, in
Cedar Crest, NM
Posted: Thu May 11, 2006 1:31 pm Post subject: Redundancy |
"override of
overflow
before
| the floats become overwhelmed with too much incoming fuel. |
| Dennis Kirby
| Mark-III, 912ul, in
| Cedar Crest, NM
Dennis:
That outlet on the float bowl chamber of the 912 carb is not an
overflow as I thought when I initially installed the 912 on my mkIII
in 1994. That is one of the static air sources that works with the
other static air source in the lip of the carb inlet. These two
static sources and the position of the throttle plate tell the piston
in the carb where it should be positioned. That is why it is
important for them to all read the same static pressure.
The low pressure Facet and the engine driven pump will not produce
enough pressure to override the floats and needles.
This is covered in the Rotax 912 School presented by Eric Tucker.
After three classes over the last six years I think I have that part
down correctly. hehehe
Titus, Alabama |
Posted: Mon May 15, 2006 7:59 am Post subject: Redundancy |
<< I start the engine using only the primary pump and continue thru warm-up
and run up. Just before take off I switch on the Facet pump. After takeoff I
turn the Facet pump off. Rick Neilsen >>
This is how I used to do it. Thought I was saving wear and tear on the
Facet fuel pump. But after reading Richard Pike's enlightening post
regarding the expected operating life of the Facet fuel pump (gazillion
hours), and after hearing Rick Neilsen's account of experiencing failures in
Facet pumps in the past, I think I will change my procedures.
| Quote: | From now on, I'm just gonna leave the Facet pump turned "on" for the
duration of my flying. On the 912, running both pumps in series (electric
one first, followed by the mechanical pump) does not overpressure the carbs.
Although I do not have a fuel pressure sensor, my carbs have never
experienced overpressure (with both pumps operating) sufficient to cause
fuel to overflow from the float bowls, as long as the engine is running.
Maybe the Mikuni pressure-pulse pump (on the two-stroke Rotax engines)
provides different results ... I do not know.
Dennis Kirby
Mark-III, 912ul
Getting ready to depart for Monument Valley on Thursday
