bernard.wilder2(at)gmail. Guest
Posted: Mon May 02, 2011 10:27 am Post subject: Oil Temperatures |
Dennis,
I installed an auto oil thermostate designed to be used with automatic tramissions. It opens at 180 degrees.
I start take-ofdf roll when oil gets to 100. It gets to 180 before I get to 600-700 feet and stays there.
It is about as big as my fist and installs easily. I got it from Lockwood ten years ago.
Bernie Wilder
On Mon, May 2, 2011 at 1:34 PM, Dennis Adams <ghf4986(at)gmail.com (ghf4986(at)gmail.com)> wrote:
[quote]All,
I have posted notes several times concerning oil temps on my XP. When building I installed an oil thermostat per the Rotax recommendation (from Earls, this is a race car unit and looked better than the Rotax unit). It was difficult to install on an XP due to the lack of space.
Well it worked great in the winter, but oil temps were way too high in the summer as I could not climb in order to keep them below 284 degrees F. I did have some grounding problems with the Dynon and the temperature sensor but I now know that the Dynon is reading correct temps.
I flew this morning with the oil thermostat removed and now my oil temps are way too low (as were the cylinder head temps for the leading two cylinders) The outside air temperatures were -8 degrees C. On climb out the oil was about 132 degrees F max ( and I climbed hard) but then in level flight they dropped down to about 100 degrees F and less on decent. I need to get around 190 and climb out or at least sometime during the flight.
I am going to experiment with some metalized tape over the oil cooler. I can probably do this as long as the cylinder head temps are also low.
Are other XP people having similar problems? What did you do to solve. By the way this engine has high compression pistons and I expected it to tend to run warmer.
Dennis Adams
N375CM 16 hours on the plane.
Quote: |
arget="_blank">http://www.matronics.com/Navigator?Pulsar-List
ttp://forums.matronics.com
| [b]
| - The Matronics Pulsar-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Pulsar-List |
sonja.englert(at)juno.com Guest
Posted: Mon May 02, 2011 11:31 am Post subject: Oil Temperatures |
It is really simple and effective to cover part of the oil radiator with tape to keep the temperatures up and remove it when it gets warmer. That is really all you need.
Sonja
____________________________________________________________
Groupon.com Official Site
1 huge daily deal on the best stuff to do in your city. Try it today!
http://thirdpartyoffers.juno.com/TGL3131/4dbf03aa9a44c203bc5st04duc
mosescpa(at)dcdi.net Guest
Posted: Mon May 02, 2011 11:42 am Post subject: Oil Temperatures |
Dennis,
The first winter, I covered about 2/3 of the oil radiator with duct tape. It worked, but no adjustment. Next, I had built a slide affair that could block between 1/3 - 2/3 of the radiator. It worked ok but I removed it in the summer and haven't put it back. I just run with the lower temps when it is cool.
Austin Moses
N460GM
ccoulter(at)wavecable.com Guest
Posted: Mon May 02, 2011 3:26 pm Post subject: Oil Temperatures |
On Mon, 2 May 2011 11:34:51 -0600
Dennis Adams <ghf4986(at)gmail.com> wrote:
on my XP. When
the Rotax unit). It
space.
way too high in the
284 degrees F. I
temperature sensor
leading two
C. On climb out
on decent. I need
during the flight.
the oil cooler. I
are also low.
you do to solve. By
expected it to tend
to run warmer.
Dennis Adams
I have the same problem of temps too cold. I built a
sliding baffel to close of the cooler, it helps but I
still run cold.
Clarke
