PFolbrecht(at)starkinvest Guest
Posted: Wed May 10, 2006 9:57 am Post subject: OT - Certified seatbelt data plates |
A&P is making me replace the belts on my '79 152 now in annual because =
the data plates are missing. The plates on the belts, that is. Perhaps =
I'm quite na=EFve, but I wasn't aware of such a thing, and in any case =
the previous two annuals I've done on this aircraft caused no such =
complaints, and the last one was at the same shop! (Different head =
mechanic now, though.)
This is over $300 plus labor. What next? I had a $4K annual last year =
on this $25K aircraft and am looking at the same kind of bill again this =
year! All for mostly "little" stuff that just adds up like crazy - no =
motor work. I can't wait to own an experimental!
Rant off. Do not archive!
mrobert569(at)hotmail.com Guest
Posted: Wed May 10, 2006 1:37 pm Post subject: OT - Certified seatbelt data plates |
As much as it may sem silly, your mechanic is correct. The TSO/ID tag must
be on the seat belt or the belt can't be used. One way to save some maney
is to have the belts re-webbed by someone, beltmasters is one such. They
keep the metal parts, condition acceptable, and put on new webbing and their
own TSO/ID tag.
Mike Robertson
| Quote: | From: "Folbrecht, Paul" <PFolbrecht(at)starkinvestments.com>
Reply-To: rv-list(at)matronics.com
To: <rv-list(at)matronics.com>
Subject: OT - Certified seatbelt data plates
Date: Wed, 10 May 2006 12:55:11 -0500
Posted: Wed May 10, 2006 2:13 pm Post subject: OT - Certified seatbelt data plates |
Thanks a lot. They didn't offer that option. Gotta be cheaper than new
belts. I'll look into it.
paulmike(at)parashak.net Guest
Posted: Wed May 10, 2006 2:43 pm Post subject: OT - Certified seatbelt data plates |
An authorized person can perform preventative maintenance and this is
listed as one.
Sec A43.1.(c)(14): Replacing safety belts.
from here: ( faa.gov / Regulatory_and_Guidance_Library )
http://tinyurl.com/otcep
Regards, Paul
On May 10, 2006, at 17:35, Mike Robertson wrote:
<mrobert569(at)hotmail.com>
must
maney
They
their
own TSO/ID tag.
Mike Robertson
> because =
> Perhaps =
> case =
> year =
> this =
> no =
Jerry Grimmonpre'
Joined: 09 Jan 2006 Posts: 144 Location: Huntley, Illinois 60142
Posted: Wed May 10, 2006 2:58 pm Post subject: OT - Certified seatbelt data plates |
Paul ...
If you are close to Northern IL call Midwest Flight Check based at The
Landings airport Huntley Illinois. I don't know the ID for the airport.
Midwest's # is 847-669-3515. It's operated by my son and two others in
partnership. You may talk to Gary, Scott or Gregg. Gary, my son, and Gregg
are United mechanics with inspector authority. They are reasonable and do
responsible work. You won't be disappointed .... no rip-offs there.
Regards ...
Jerry Grimmonpre'
RV8A Huntley IL
Posted: Wed May 10, 2006 3:06 pm Post subject: OT - Certified seatbelt data plates |
But the problem here is the TSO/ID tag. Only a manufacturer or STC holder
may install, or cause to install, the TSO/ID tag. If that is missing you
are out of luck. Besides, the reference you give is only for the
replacement of the seat belts under PM, not the repair.
Mike Robertson
| Quote: | From: Paul Parashak <paulmike(at)parashak.net>
Subject: Re: OT - Certified seatbelt data plates
Date: Wed, 10 May 2006 18:41:18 -0400
listed as one.
Regards, Paul
> must
> maney
> They
> their
> own TSO/ID tag.
> Mike Robertson
>> because =
>> Perhaps =
>> case =
>> year =
>> this =
>> no =
Posted: Thu May 11, 2006 6:45 am Post subject: OT - Certified seatbelt data plates |
Thanks for all the replies on this. Mechanic says that re-webbing is
NOT an option because that requires valid belts to start with, and these
are not. They are some bogus belts installed back who knows when. Of
course, they are in perfect shape and completely sturdy and safe.
Oh well, another $400 gone.
Bruce(at)glasair.org Guest
Posted: Thu May 11, 2006 9:00 am Post subject: OT - Certified seatbelt data plates |
Your mechanic is full of BS. Remove the belts yourself, send them out for
rewebing, hand then to him to reinstall. If he won't do it, pull the
airplane and have him sign it off with a squawk list.
Bruce
www.glasair.org
Posted: Thu May 11, 2006 9:38 am Post subject: OT - Certified seatbelt data plates |
The re-webbing people also told me they cannot reweb belts that don't
have data tags...
A complication is I'm off to Europe for two weeks tomorrow. I would
like the airplane flyable when I get back, and have no time to take care
of this myself. But it doesn't seem there are any real options anyway,
other than shopping the belts myself, which isn't like to save much, if
anything.
lsbrv7a(at)yahoo.com Guest
Posted: Thu May 11, 2006 11:38 am Post subject: OT - Certified seatbelt data plates |
I sugest you contact Schroth Aircraft seatbelts and order a set, pay for then yourself, have them sent to the mech, and have you mech install them. Save the mark-up and COD cost.
I will often pre-buy tires, exhaust pipes, etc. prior to the annual. This saves money, saves the A&P time, indicates to the A&P that you are serious about maintining you aircraft, and are aware of the condition.
Could it be that this is a money making item known to an experianced A&P?
have data tags...
anything.
Sherman Butler
RV-7a Wings
Idaho Falls
Talk is cheap. Use Yahoo! Messenger to make PC-to-Phone calls. Great rates starting at 1¢/min.
Posted: Sun May 14, 2006 7:03 pm Post subject: OT - Certified seatbelt data plates |
Paul ..... check with the seat-belt reweb company. Old seatbelts didn't
have the cert label. The FAA made it an issue since there wasn't any
TRACEABILITY of the belts ...... and could be from a car .......
However, the reweb folks DO use the hardware and DO put their cert label
on their rewebbed belts. You need to get another mechanic.
Linn
sisson(at)consolidated.ne Guest
Posted: Mon May 15, 2006 8:51 am Post subject: OT - Certified seatbelt data plates |
Why don't you buy some new legal ones and replace them yourself? Part
43, appendix A, (C), 14 will allow you do this and all other preventive
maintenace which is specifically listed there. This would save you the
labor and you can shop for some good seatbelts. Call Wentworth and talk
to them about some good pullouts with tags...
Just an idea, Phil in Illinois
