Strasnuts
Joined: 10 Feb 2009 Posts: 502 Location: Salt Lake City, UT
Posted: Wed May 11, 2011 9:14 am Post subject: I-phones and Bluetooth |
Just thought I would let everyone know if your Bluetooth audio panel or anything else for that matter doesn't sync to your new Iphone it is most likely the software in the unit is outdated. Apparently Apple doesn't have any protocol with the software changes and the effects it has on external devices. We have all experienced this with the charging jacks! My iphone 3GS would not link up to my PS9000 so I tried it in Scott's plane with the new PS8000BT. It worked flawless in Scott's. I called PS Engineering and they stated it is because Apple is the only company that has no protocol for software upgrades. All other blue tooth phones should work great but if you have a new iphone that doesn't, you need to return your audio panel back to PS Engineering for a free update. He said there is a good chance the new Iphone 5's will have the same problem so be advised.
_________________ 40936
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours |
aerosport1
Posted: Wed May 11, 2011 9:47 am Post subject: I-phones and Bluetooth |
I had the same issue with my ps 9000
And sent it back 2 weeks ago. Works great as of now with the IPhone
Geoff Combs
Sent from my iPhone Geoff
On May 11, 2011, at 1:14 PM, "Strasnuts" <sean(at)braunandco.com> wrote:
40936
http://forums.matronics.com/viewtopic.php?p=339572#339572
_________________ Geoff Combs
RV-10 QB N829GW
Flying 500 hrs
40033 |
