tc1917(at)bellsouth.net Guest
Posted: Thu May 12, 2011 2:03 am Post subject: egt |
well, got egt problems again. seems like every time I get them straightened
out, six months or so later, more trouble. tried all kinds of tests,
switching them, trying different ones, checked here and there. cant seem to
isolate the problem. next I am going to remove the wires from the glass
gauge unit and install a short extension right to the probes. this should
tell me something. went flying and everything was cool and all of a sudden
a bobble in the engine. did it again and lost power. was able to keep it
running in order to have a little power on off field landing. (sixth time I
have had an emergency landing off field) landed okay and called my wife to
come with the trailer. the micro filter just slammed plain shut on me while
flying. never seen nothing like this. could not even blow through it. no
light, no air and could not clean it. don't know what clogged it. replace
it and the secondary filter and everything is fine. now, back to the egt.
I have a flashing light when something is wrong on the temps. the egt should
have lighted up or at least shown a lean condition when it ran out of gas
in the carbs. was wondering what do I need them for? are the egts really
necessary? Anyone running without them. I remember airwolf telling me they
do not recommend them on 912s being as they are 2 strokers. any comments?
Ted Cowan, Slingshot 912 zoom zoom
Mike Welch
Posted: Thu May 12, 2011 4:12 am Post subject: egt |
| Quote: | flying.
| Quote: | have lighted up or at least shown a lean condition when it ran out of gas
Ted,
Comments? Here's a couple;
I would use that microfilter again for NO amount of
money. I'd take that sucker apart and find out WHY it slammed shut.
Is an EGT necessary? Some would say no, some say yes. Personally,
I LIKE knowing how well my engine is running (or how poorly). I'd
say, "if your engine always runs perfect, and never, ever has any problems,
don't worry about an EGT."
Lastly, tell the guy at Airwolf he should refrain from giving advice on
912s 2 strokes.......'cause thar ain't any such critter!!'
Mike Welch
Mike Welch
Posted: Thu May 12, 2011 4:15 am Post subject: egt |
Last response was supposed to say "WOULDN'T use that filter". Note to
self; proof-read BEFORE you push 'send'. At any rate, I'm sure you got
the idea.
Mike
zeprep251(at)aol.com Guest
Posted: Thu May 12, 2011 4:23 am Post subject: egt |
Ted,
It is possible you have too fine a filter?I have seen a filter remove fuel additives and clog.It was a teflon additive that could pass through the carb and jetting with out problems but closed the filter.In theory,other than water,any particle smaller than the smallest orifice in the carb should not give you trouble,and that may be judged by the mesh of the filter screen that surrounds the main jet.
The number of power failures you've had is amazing.Have you been able to locate the specific cause for each of them?I have a friend with a 912s on a mk3c that has had at least 2 events of lost power,fuel starvation in both cases ,but he has not identified the root cause for either.But he has stated that both times the fuel level in the tanks was close to half,but he failed to engage the aux pump either time.
It takes a few seconds for the egt probe to sense change.You may have had not enough time to register the change on a 4 stroke.
Could you give me some insight into your other power failures?
Thanks,G.Aman MK3C jabiru2200A 600+hrs .
Posted: Thu May 12, 2011 5:02 am Post subject: egt |
are the egts really
necessary? Anyone running without them. Ted Cowan, Slingshot 912 zoom
zoom
Ted C/Gang:
I have never run EGT gauges with my 912 engines. Have never felt I needed
to monitor EGTs, with nearly 3,000 hours flying in front of 912 engines.
_________________ John Hauck
Titus, Alabama |
Richard Pike
Posted: Thu May 12, 2011 7:01 am Post subject: Re: egt |
Let me suggest that you Google "fuel strainer sock," for in-tank use as your fuel pickup. Something like this: http://www.ssdieselsupply.com/product_338_In_Tank_Fuel_StrainerSock.html
There are other versions that have the pickup outlet in the side.
Then go to your friendly auto parts store with a good idea of what you want, and start browsing. As long as it is a likely candidate to go on the end of your fuel pickup tube, or inside the tank over your tank outlet, that's what you want. Pick out something with lots of surface area, and an opening that will easily adapt to your plumbing. Then it will be unlikely for your inline filter to ever see any junk.
As Barney Fife says, "NIP IT IN THE BUD!"
Richard Pike
MKIII N420P (420ldPoops)
Posted: Thu May 12, 2011 8:04 am Post subject: egt |
Richard Pike
Richard P/Gang:
I use a finger strainer in the tank.
http://www.aircraftspruce.com/catalog/appages/fingstrainers.php
And a Purolator inline glass tube filter. I replaced the glass tube with a
piece of .58" alum tube. Had my first glass tube crack first night it was
installed.
Easy to stick a few elements in my flight bag if I should need them on a
trip. Usually get 100 hours on an element.
Elements can be cleaned in an emergency to get back into the air if you
don't have a new replacement.
Titus, Alabama |
byoungplumbing(at)gmail.c Guest
Posted: Thu May 12, 2011 10:58 am Post subject: egt |
Gang:
This is what the filter looks like:
http://www.eangler.com/product/MP80813459.htm?utm_medium=cpa&utm_source=Shopping
| Quote: | >>>>>>>>>>>>>>>>>>>>>>>>>>
i have had one of these filters in my boat for years,,,, and never once had
an issue, sold the boat to my son and i don't think he has had any
problems. unless there is a difference in the elements,,, mine was more
of a fine mesh screen, not like a paper element,,, i could take it apart to
clean it. being a fine mesh screen it would not plug up if there happened
to be any moisture come through. and if installed vertical, the moisture
could accumulate in the bottom of the filter glass before it got to the
filter element, unless there were a LOT of water.
boyd young
mkiii utah
Thom Riddle
Posted: Fri May 13, 2011 4:26 am Post subject: Re: egt |
"any particle smaller than the smallest orifice in the carb should not give you trouble,"
Gary,
Not to put too fine a point on this, but the smallest orifice in the carb may not be the smallest opening. The jet needle to needle jet gap gets pretty small at low throttle. The opening in this case is a very narrow annular ring. I think Bing specifies a .1 mm (.004") final fuel filter.
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
Posted: Mon May 16, 2011 4:31 am Post subject: egt |
Thom,
Agree,that's probably the mesh size of the screen.You can check it with your pin drills.
G.A.
