dean.psiropoulos(at)veriz Guest
Posted: Wed May 18, 2011 8:00 pm Post subject: Audio panel to camcorder mic input |
Looking to connect a Sony camcorder to my PS engineering model 6000 audio
panel. An electrical engineering collegue suggested a simple resistor
network that consists of a 10kilohm in series with the signal line coming
out of the audio panel followed by a 200 ohm resistor connected across the
signal line to signal ground which is then connected to the microphone input
of the camcorder. I presented this to the support engineer at PS
engineering and he had no comment but instead suggested I talk to the folks
at edmo.com for a cable to make this connection. After talking to edmo
today and looking at their website it became apparent that they have no
commercially available interconnect that can perform this function.
Edmo does have impedance matching cables to connect between civil aviation
audio panels and military headsets but I don't think these will work for my
application. Any EEs out there who work in analog audio? Any suggestions on
making something that keeps the audio panel outputs from saturating the mic
input? The camcorder input is stereo and so is the audio panel so hopefully
whatever design comes out of this exercise can be used in a stereo
application as well.
Specs on the camcorder mic input are as follows: Minijack, 0.388mV low
impedance with 2.5-3.0 volts DC, output impedance 6.8 kilohms, 3.5 mm stereo
type.
Specs on camcorder also show an audio/video (?line?) input as follows: AV
Minijack, 1Vp-p, 75ohms, unbalanced 327mV, (at output impedance more than
47kilohms), output impedance with less than 2.2 kilohms/stereo minijack (3.5
mm), input impedance more than 47 kilohms.
Specs on the audio panel outputs are as follows: Headphone impedance- 150 to
1000ohms, Headphone output - 45 mW each headset no clipping. Audio
distortion less than 1% at 45 mW into 150 ohms, less than 10% THD at 70mW
into 150 ohms.
Any suggestions? Anyone know of something I can purchase off-the-shelf that
will do this with no assembly required? Thanks.
Dean Psiropoulos
RV-6A N197DM
Flying-3 years now!
enginerdy(at)gmail.com Guest
Posted: Wed May 18, 2011 8:58 pm Post subject: Audio panel to camcorder mic input |
My calculation is:
To dissipate 45mW into 150 Ohms:
http://www.wolframalpha.com/input/?i=45mW+%2F+sqrt%2845mW%2F150Ohms%29
I get about 2.6V 'rms'.
apply an approximate conversion factor to get rms into peak to peak:
2.6V * (2/sqrt(2))
http://www.wolframalpha.com/input/?i=45mW+%2F+sqrt%2845mW%2F150Ohms%29+*+%282%2Fsqrt2%29
And I get 3.7V p-p
To get that to 1v p-p, you need to divide it by four... or five to leave some headroom.
So, unless somebody calls me on an error, I say 10k in series, 3.3k to ground, almost like your friend says.
This would be going into the Line-in jack, and you'd need a separate divider for left and right. Alternatively, you could just bring one channel off the intercom, do the two resistors, and split the outputs to left and right.
I'd say stay away from the mic jack if you can. It just adds problems.
You'll probably still need to experiment with the volume knob on the intercom to get what you're after.
--Daniel
type.
into 150 ohms.
Dean Psiropoulos
RV-6A N197DM
Flying-3 years now!
tshankland(at)sbcglobal.n Guest
Posted: Thu May 19, 2011 4:49 am Post subject: Audio panel to camcorder mic input |
Here is the simple way I used when making video from my airplane. This method is good for temporary connections. Just take an extra headset and put a microphone in the earpieces, put them together and tape the whole assembly together. No impedance problems to worry about.
Tim Shankland
Daniel Hooper wrote: [quote] Quote: | --> AeroElectric-List message posted by: Daniel Hooper <enginerdy(at)gmail.com> (enginerdy(at)gmail.com)
My calculation is:
2.6V * (2/sqrt(2))
[url=http://www.wolframalpha.com/input/?i=45mW+%2F+sqrt%2845mW%2F150Ohms%29+*+%282%2Fsqrt2%29]http://www.wolframalpha.com/input/?i=45mW+%2F+sqrt%2845mW%2F150Ohms%29+*+%282%2Fsqrt2%29[/url]
And I get 3.7V p-p
--Daniel
Quote: | --> AeroElectric-List message posted by: "DEAN PSIROPOULOS" <dean.psiropoulos(at)verizon.net> (dean.psiropoulos(at)verizon.net)
type.
into 150 ohms.
Dean Psiropoulos
RV-6A N197DM
Flying-3 years now!
| [b]
rjquillin
Posted: Thu May 19, 2011 8:38 am Post subject: Audio panel to camcorder mic input |
On 5/18/2011 20:52, DEAN PSIROPOULOS wrote:
Quote: | Looking to connect a Sony camcorder to my PS engineering model 6000 audio
panel.
Is the camcorder going to be connected to ships power?
Consider seriously using a small transformer to match/couple between the
two devices.
Roll your own or perhaps something like this...
http://www.bhphotovideo.com/c/product/750963-REG/Sescom_LN2MIC_ZMH4_MON_3_5mm_Line_to_Mic.html
Ron Q.
Tim Olson
Posted: Thu May 19, 2011 12:55 pm Post subject: Audio panel to camcorder mic input |
I had this problem recently when I tried to do the
same thing. I built the simple resistor network
with one on the signal and then the one to ground
and such, as was the common solution. I tested it
at home and while it did work, it induced noise
into the system with a portable intercom. Not sure
exactly why.
But, as a fluke, I tested just attenuating it with
a resistor only on the signal wires Left and Right.
I used a 1.5Meg and also tried 2Meg resistors, just
in series with the signal wires, nothing on the
ground. That actually worked out perfectly well.
It works pretty good with my PMA8000BT, which
I can't imagine would be different than the
PMA6000. So you may want to give that a try...if
that works well enough, you'd be done real quick.
Tim Olson - RV-10 N104CD
