		JohnF
				 Posted: Fri May 27, 2011 9:12 am    Post subject: Compression Ratio Rotax 912ULS |
				I can't seem to find the differential pressure  figure that I want to check on the 912ULS. If its in the heavy duty maintenance  manual I didn't see it.
  What xx/80 should I expect if all is  well?
  thanks for the help
  |  | - The Matronics RotaxEngines-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Roger Lee
				 Posted: Fri May 27, 2011 9:25 am    Post subject: Re: Compression Ratio Rotax 912ULS |
				Hi John,
 Your maint items can be found in the "Line Maint" manual. You can use 80-87 psi test pressure as per Rotax. I'm old school Rotax so I still use 87, but regular A&P's use 80. A normal drop in pressure is 2-4 psi.
  _________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Home 520-574-1080  TRY HOME FIRST
Cell 520-349-7056 |
		Thom Riddle
				 Posted: Sat May 28, 2011 3:37 am    Post subject: Re: Compression Ratio Rotax 912ULS |
				JohnF,
 The minimum acceptable differential compression test result is 75% of applied pressure. If applying 80 psi, then 60 is the minimum. If applying 87 psi the minimum would be 65.25.
 I apply 87 psi on Rotax 912 engines because that is what the book calls for, or at least it used to. Don't know if that has changed since I last read it. On every other engine, I use 80 psi because that is what I was taught in A&P school 40 years ago.
  _________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
		Roger Lee
				 Posted: Sat May 28, 2011 5:15 am    Post subject: Re: Compression Ratio Rotax 912ULS |
				Hi Thom,
 The older version of the Rotax manual did only state 87 test pressure, but the newer version allows for use of 80-87.
 John,
 A 2-4 drop in pressure would be normal.
Tucson, Az.
Cell 520-349-7056 |
