Robin(at)PaintTheWeb.com Guest
Posted: Sat May 28, 2011 1:46 pm Post subject: Small Drill Driver Recommendation |
About a year ago someone on the RV list recommended a small Li Ion drill driver. I looked in the archives but could not find the thread. Anyone out there with a preference on this type of tool?
Robin
HCRV6(at)comcast.net Guest
Posted: Sat May 28, 2011 5:04 pm Post subject: Small Drill Driver Recommendation |
I recently picked up a small Li Ion driver made by Ryobi (sp?) from Home Depot. The pluses are small compact size, two speeds, excellent torgue adjustment and easily interchangeable battery, spare batteries available for about 12 bucks. The minus is it has a hex chuck only so if you want to drill with it you will need hex shank drill bits.
Harry Crosby
RV-6 N16CX, 830 hours
vanremog(at)aol.com Guest
Posted: Sat May 28, 2011 5:13 pm Post subject: Small Drill Driver Recommendation |
I really like the 12V Milwaukee Li Ion Driver Kit. You can get the kit for less than $100 at Grainger.
http://www.amazon.com/Milwaukee-2401-22-12-Volt-Li-Ion-Compact/dp/B000WI9CIG/ref=pd_bxgy_hi_img_c
-GV
In a message dated 05/28/11 14:47:36 Pacific Daylight Time, Robin(at)PaintTheWeb.com writes:
| Quote: | .aolmailheader {font-size:8pt; color:black; font-family:Arial} a.aolmailheader:link {color:blue; text-decoration:underline; font-weight:normal} a.aolmailheader:visited {color:magenta; text-decoration:underline; font-weight:normal} a.aolmailheader:active {color:blue; text-decoration:underline; font-weight:normal} a.aolmailheader:hover {color:blue; text-decoration:underline; font-weight:normal}
Robin
bicyclop(at)pacbell.net Guest
Posted: Sat May 28, 2011 9:26 pm Post subject: Small Drill Driver Recommendation |
The Panasonics are mostly NiMH, but are great drills. The balance is very good, high torque, great chuck, great clutch, charge fast. I like to have a half inch chuck 'cos you can chuck up pieces of tubing and square up the end on the scotchbrite wheel when you're making spacers and such. Not a small drill, but very useful.
Pax,
Ed
On 5/28/2011 2:43 PM, Robin Marks wrote: [quote]
Robin
