Flaperon Adjustment
dons701
PostPosted: Mon May 30, 2011 4:06 am    Post subject: Flaperon Adjustment Reply with quote
Hello to everyone!
Has anyone changed or experimented with the 16mm (by the
plans) difference between the outer and inner flaperons as measured at the
trailing edge. I understand that this distance can be adjusted for leveling the
plane side to side, or for hands off flight. What other results could be gained by adjusting the
measurement between the flaperons??
Thanks,...Don B
Zenith 701 #76120
Jabiru 2200A #2456 95 hours
Sensenich Wood 64-PJ-36 Prop
dougsnash
PostPosted: Mon May 30, 2011 5:28 am    Post subject: Flaperon Adjustment Reply with quote
As I understand it, the purpose of the step between the inboard and outboard
flapperons is to provide a washout effect during stalls.  If you reduce the step
then you will reduce the ability to keep the wings level during a stall using
the flapperons.  Also, the stall might become more abrupt as it will happen over
the whole wing instead of building from the inboard to outboard.
Doug MacDonald
CH-701
NW Ontario, Canada
Hello to everyone!
by adjusting the
Thanks,...Don B
Zenith 701 #76120
Jabiru 2200A #2456  67 hours
mikeweesner
PostPosted: Mon May 30, 2011 5:49 am    Post subject: Flaperon Adjustment Reply with quote
On Mon, 30 May 2011 06:25:48 -0700 (PDT)
outboard.
Doug MacDonald
CH-701
NW Ontario, Canada
there are very few bad ideas in experimental aircraft,but this is one of them,it would rank alongside intentionally being outside you cg.
<burdon1(at)comcast.net>
Hello to everyone!
the
as measured at the
by adjusting the
Thanks,...Don B
Zenith 701 #76120
Un/Subscription,
Forums!
Admin.
dons701
PostPosted: Tue May 31, 2011 5:26 am    Post subject: Re: Flaperon Adjustment Reply with quote
Thanks, Doug and Mike
While I currently do not have any flight issues with my plane, I was curious to find if anyone increased or decreased - equally - away from the factory setting of 16mm. While checking my 701 I found one side slightly less than the other, (previous owner), which did improve hands off flight.
I was curious if anyone deviated or experimented from the factory settings for what kind of problem and what was their result. Thanks...Don B
Zenith 701 #76120
