Power Stabelizer
dan(at)azshowersolutions.
PostPosted: Mon May 30, 2011 2:09 pm    Post subject: Power Stabelizer Reply with quote
I was curious if anyone has had any experience with these units? Their purpose is to allow the glass panels to be turned on prior to and during engine start dampening a power spike or surge. If I remember right in Bob's book, he indicates this usually should not be a concern. What is the concensus? Thanks,
Dan B
http://www.tcwtech.com/IPS-12v.htm
stuart(at)stuarthutchison
PostPosted: Tue May 31, 2011 4:53 am    Post subject: Power Stabelizer Reply with quote
G'day Dan,
I like it a lot and bought one for additional avionics protection, but then
switched to the Independent Battery Backup System (IBBS) instead. I'm no
authority on this, but I believe that the inherent protection devices in
avionics will supress most volate spikes/current surges, but the cumulative
effect of even small spikes/surges can reduce the performance of the
equipment and eventually lead to early retirement. The IBBS (4Ah NiMH with
built-in charging) - achieves the same function and supplies backup power as
well, for a small weight penalty.
Kind regards, Stu
F1 Rocket VH-FLY http://www.mykitlog.com/RockFLY
www.teamrocketaircraft.com
PostPosted: Tue May 31, 2011 4:58 am    Post subject: Power Stabelizer Reply with quote
Sorry, I meant "voltage" spikes ... dislexia kicking in.
iamgodlisten(at)hotmail.c
PostPosted: Tue May 31, 2011 6:40 am    Post subject: Power Stabelizer Reply with quote
The first key may be to follow the money. In this case the "patented technology in the IPS system" is money. All patents are money.
It is unlikely that tcwtech.com is contributing a unique solution to a previously undiscovered electrical condition that has not been already considered.
Alvin Voigt, Ashford, WA – PDT iamgodlisten(at)hotmail.com (iamgodlisten(at)hotmail.com)
PostPosted: Tue May 31, 2011 7:58 am    Post subject: Power Stabelizer Reply with quote
One of the reasons for asking the question Alvin...thanks for your input. The thing that got me thinking about it was a post on another site indicating how they would not be without a protection device like the IPS. I know discussions about these systems have been briefly hashed here (reading the archives), however, the question is still lingering in my brain cell. I have no doubt or argument that these "stabelizer" systems are probably a great add-on...if not for anything else the battery backup one gains. My quest is to decide if this type of system is NEEDED for the spike/surge aspects as advertized. I know, I know...that is like asking about the noise if a tree falls in the woods with no one to hear it. Has anyone tried sneeking into the woods unseen? It is my understanding that many of the schematics most of us here have followed to wire our ships address these spikey issues (thinking fuses, diodes, crow-bars, etc). To go one step more, do not each one of the glass instrument manufactuers have internal (or external) protections built in? Feel free to PM me if you would rather not voice publicly.
Dan B
--- On Tue, 5/31/11, Alvin Voigt <iamgodlisten(at)hotmail.com> wrote:
Subject: Re: Power Stabelizer
Date: Tuesday, May 31, 2011, 8:36 AM
ist" rel=nofollow target=_blank>http://www.matronics.com/Navigator?AeroElectric-List
et=_blank>http://forums.matronics.com
llow target=_blank>http://www.matronics.com/contribution
PostPosted: Tue May 31, 2011 8:59 am    Post subject: Re: Power Stabelizer Reply with quote
It is acceptable to have the FlightDEK-D180 turned on during engine start.
Above is a quote from page 2-1 of the Dynon FlightDEK-D180 Pilot’s User Guide.
At least one manufacturer agrees with Bob N and is not concerned with old wives' tales.
Joe
Joe Gores
rnewman(at)tcwtech.com
PostPosted: Tue May 31, 2011 9:28 am    Post subject: Power Stabelizer Reply with quote
I was just going to let this forum play out the Q & A regarding our products on its own. But I cannot let unsupported comments just linger.
The TCW power stabilizer does resolve a real issue and is, as far as we know, a unique solution to a real problem. The IPS series of products take input bus voltages from 5-15 volt and ensure that the output is at least 12 volts. The IPS system is DC:DC power converter and is rated to run at its name plate conditions all day long. Many electronics systems including EFIS and engine monitors do not work well or at all when the bus voltage falls below 9-10 volts. When you crank the engine in your plane it is likely that the battery terminal voltage will fall to 6-7 volts. If you were interested in having these types of equipment up during engine cranking you will need to do something about this condition. Using alternate batteries is a perfectly viable solution, however all batteries are a maintenance issue and they weigh quite a bit more than our IPS products. You will find in the Garmin install manual for their G-900x and G3x series of avionics that the TCW IPS system is shown in the wiring diagrams as a method of resolving this problem with low voltage conditions.
Yes it is true we did receive a patent for technology(7,868,478) it covers some of the specific workings of our product and we believe it protects some of the very nice electrical behavior we have worked into the design. No we did not invent the DC:DC converter, we did however make improvements upon it that make it very well suited for the engine starting application I described above. In doing so I believe we have made a contribution to resolve a real problem and that the solution was unique.
We are very proud of our products, we have invented them, we designed them, we patented them, and we manufacture them in the USA. We deliver value to our customers and are glad to discuss their real benefits and technical merits at any time.
Sincerely,
Bob Newman, owner
TCW Technologies, LLC.
PostPosted: Tue May 31, 2011 6:47 pm    Post subject: Power Stabelizer Reply with quote
At 08:49 AM 5/31/2011, you wrote:
I'm no authority on this, but I believe that the inherent protection
devices in
Not true. Spikes and Surges is non-quantified. The bus
voltage of any DC vehicle is all over the place as a matter
of normal operations. It can drop to 6v for milliseconds
during starter motor inrush events but that event is not
hazardous to any piece of electronics. It might trigger
some form of reset activity in systems where the designers
did not anticipate this routine, once-per-flight-cycle event
that occurs in the airplane's parking spot.
It's a certainty that this product performs as advertised.
The question to be asked and answered is what is the $return$
on investment for having added the feature. I know of no
such devices on any TC aircraft. Modern avionics have their
own, wide-range input DC-DC converters built in. I'm aware of
no avionics installations suggesting "power smoothing" to
improve behavior for brown out effects or as a hedge against
premature failure.
To accomplish meaningful evaluation of goodness, "spikes" and
"surges" should be quantified as to amplitude, waveshape and
frequency. It seems likely that a detailed report of such
forces would also reveal the systems that are likely to generate
the antagonistic effects. Once the antagonists are accurately
described, only then can one deduce whether a panel mounted
product crafted to DO-160 design goals would benefit from additional
protection from those antagonists.
One might think that the starter motor is the greatest
probably for generating a perturbance on the bus . . . and they'd
be right. I've documented starter-engage battery-voltage sags on
everything from my wife's SL-1 Saturn to C-150 to Beechjets. They all
do it. It lasts but a few milliseconds. No other noteworthy
disturbances have been noted. I've not encountered a system
designed for installation on a DC powered vehicle where the
manufacture said that his product would benefit from glass-smooth
power.
I've designed dozens of devices and evaluated hundreds more
where we simply hook the critter to the bus . . . what ever
you or your airplane throws at it is of no particular
concern with the exception of gross over-voltage. That why
we DO have ov protection on engine driven power generators.
PostPosted: Wed Jun 01, 2011 12:11 am    Post subject: Power Stabelizer Reply with quote
Thanks Bob,
I like the idea that my EFIS won't reboot during engine start - cos I want
to see the oil pressure right about then.
Either way, I'm a newbie to this forum and feel very fortunate to have such
experienced and articulate guys to help numpties like me steer a true
course.
I assume then that OV is the reason confusers (computers) are susceptible to
lightning activity without a 'surge' protector?
Kind regards, Stu
PostPosted: Wed Jun 01, 2011 7:15 am    Post subject: Power Stabelizer Reply with quote
At 04:08 AM 6/1/2011, you wrote:
<stuart(at)stuarthutchison.com.au>
Thanks Bob,
Do you KNOW that it will? There are thousands of discussions
based on the "possibility" of a system rebooting based on
the experiences and perhaps third-hand observations of others.
A lot of band-aids have been pasted onto OBAM aircraft in
response to a worry for experiencing some condition that
is not well identified or explained. It may be that the
rumor started simply because some pilot was pushing his
battery too far past it's service life . . . or perhaps
it was too small. A battery that gets replaced when the
capacity drops below battery only design goals is still
quite capable of starting the engine. But a battery with
no endurance goals (like in Z-13/Cool may get so soggy that
some systems start complain about bus voltage depression during
starter engagement. This might well be the pre-flight
warning that says it's time to replace the battery.
course.
Can't do that . . . we know nothing about the specifics
of your airplane's configuration nor your personal philosophy
for operating and maintaining it. What we can do is help
you sort through much common knowledge or public consensus
that is mere floobydust.
We can suggest that you add no prophylactic feature
until you know you need it. If you're duplicating a
configuration that is demonstrated to benefit from some
add-on accessory, fine. But the four-color brochures
and worry-hype that promotes many products may have
no foundation in reality for how your airplane is
going together.
Finally, what we can do is offer tools for deducing
the root cause of an observed problem and either
eliminating that cause by design or masking it with
some add-on accessory.
Short answer: don't buy anything that you don't find
on a C-150 or hundreds of RV's already flying until
you KNOW you need it.
As others have pointed out, that's a whole different
world than the DC power system for your air vehicle . . .
or car. But in that world too, purchasing additional 'surge
protection' is more worry-hype than useful protection.
People who build devices that plug into walls KNOW
much about the hazards associated with that source.
The so-called 'surge protection' offered by Office-
Max add-ons are metal oxide varistors, the same
20 cent devices ALREADY installed in the power
supply for your computer . . . the same devices
that will become toast if the line behind your
house takes a direct strike.
