		Barry
				 Posted: Sun Jun 26, 2011 8:43 am    Post subject: James Cowl-Kitplanes Article |
				My wife Amy wrote about the latest mod we have made to our SJ cowl
 and plenum setup. I have done some local and cross country flights
 and are happy with the results.
   My biggest problems before the new plenum and larger rings was I
 could not do a quick turn in warm conditions that we have in FL.
 without climbing out at a fast airspeed 140-150 kias with full power
 and keep #5 and #6 CHT under 400f and oil temp under 220f.
 After a stop with 100 OAT, we were able to climb at 130 kias and keep
 the CHT's around 390f and the oil at 205f. At cruise at 8000-10,000'
 ROP or LOP I could
 keep CHT's 380-390f and oil temp at 195f, burning 16gal/hr ROP at 184
 ktas and LOP at 11.5 gal/hr at 173 ktas.
 As Amy stated, we have louvers on the bottom and sides of the cowl
 and have opened up the bottom of the cowl for more exit area. It is
 very important to seal around the plenum and the engine, and have a
 smooth transition from the rings to the ramp for the baffles.
 I have 1 slick mag and 1 EIS EI. I feel the EI is a must for running
 LOP smoothly.
 Sam is all about helping out if ya have a problem so give him a call;
 and call or email me if ya have any questions. Blue Skys Barry
		dlm34077(at)q.com Guest
				 Posted: Sun Jun 26, 2011 9:43 am    Post subject: James Cowl-Kitplanes Article |
				For those who are seeing high CHTs, have you removed the air dams on #1 an
 #2? Even in current weather only three of the six are between 360F and 380F
 for a 100-105 kt climb. Picking up 115 kt climb will lower them to below
 360F. One of the keys is to dial back the prop to 2200-2250 RPM; and run
 "oversquare" if necessary. We usually climb at 500-800 fpm at 105 KIAS using
 65% and 12-13 gph. Additional fuel flow does not seem to lower CHTs but
 reduced rpm does. We routinely cruise 9000-13000 at 55% LOP with 150+ KTAS
 and about 9 gph. At LOP the CHTs all drop to high 200s/low 300s and EGTs
 drop to just below 1420F. I used standard cowl, standard baffling except
 used the 1/8" red silicone instead of the 3/32" black Vans supplied. Also I
 did not seal the airbox to the cowl and removed the air dams.
 my 2 cents in Phoenix
		greghale
  Joined: 10 Jan 2007 Posts: 91 Location: Tulsa, Oklahoma
				 Posted: Mon Jun 27, 2011 9:48 am    Post subject: Re: James Cowl-Kitplanes Article |
				My CHT's were also running high in Oklahoma.  I trimmed my front cylinder blocking plates as Tim Olson did, and my #1 cylinder that was running high has dropped to 330 degrees (was running 380).  I did notice that doing this caused my #5 & 6 cylinder tempertures to rise.  During the summer I climb out at 115kts and power set at 23'/2300.  This helped keep my CHTs in the 350 degree range.  At cruise running LOP all the CHTs are running 330-350 at 10000'.
 Greg...
  _________________ Greg Hale rv10 -- N210KH
www.nwacaptain.com |
				 Posted: Mon Jun 27, 2011 10:17 am    Post subject: James Cowl-Kitplanes Article |
				Greg, you have the Van's cowl that was actually designed for the plane.
 The James cowl has undersized inlet area so running LOP and cooling the
 CHT/Oil is more difficult when one is choking the system through reduces
 inlet area. Try sprinting with your mouth & one nostril closed = James
 Cowl & Plenum.
 Robin
		AirMike
				 Posted: Tue Jun 28, 2011 7:52 pm    Post subject: James Cowl-Kitplanes Article |
				I agree with Dave. I have the standard Vans engine cowl, but I cut back the air dams and show good temps except a bit high on #6.
  _________________ See you OSH '18
Q/B - sold. |
