redrocketrider
Joined: 13 May 2011 Posts: 67 Location: Nervino airport
Posted: Sun Jul 03, 2011 6:38 am Post subject: RPM/912 |
Hello Kitfox flyers, For those of you who have the 912 and 3 Blade 68" GSC prop, Do you see more than 5K RPM or more on take off from field elevations of 5K, we typically see 8 to 9 K density alt days up here in the High Sierras. So from sea level we lose 5" Manifold pressure. Our kit fox is only able to turn 4500 Rpm static at 5 K field elevation and stays about the same on climb out, the prop pitch is 15 degrees. Any and all comments are welcome and we appreciate your input and replies. Thanks Bob and Toodie
_________________ Keep the dirty side down/Blue skies. Bob |
Roger Lee
Posted: Sun Jul 03, 2011 7:35 am Post subject: Re: RPM/912 |
Hi Bob,
You should set the prop pitch to achieve 5500-5550 rpm WOT flat and level at your normal cruise altitude. This will give you the best all a round performance for all flight characteristics. To much pitch like yours does equate to loss of climb, more fuel and higher engine temps. Too little pitch gives you good climb, but you loose cruise and fuel economy. Balance of all the flight characteristics is the key for normal flight operations. Don't get hung up on static it is just a starting point to getting things dialed in. You care more about WOT during flight.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
Av8r3400
Joined: 22 Sep 2008 Posts: 83 Location: North Central Wisconsin (KRRL)
Posted: Sun Jul 03, 2011 11:12 am Post subject: Re: RPM/912 |
less than 5200 rpm with full throttle in a 912 leads to excessive cylinder pressure and could seriously damage your engine.
FYI
_________________ Thanks,
Av8r3400
Kitfox Model IV-1200 W/912UL & IVO
Kitfox Model IV-1050 W/912UL & Warp
YouTube Videos |
clint_bazzill(at)hotmail. Guest
Posted: Sun Jul 03, 2011 4:41 pm Post subject: RPM/912 |
Not at5 5000 feet with a MP of 24 inches
Clint
Av8r3400
Posted: Sun Jul 03, 2011 8:41 pm Post subject: Re: RPM/912 |
Altitude was never specified during the seminar that I got that information from. Pressure differential from inside the combustion chamber versus the ambient pressure surrounding the engine is where the damage would come from, IMO.
Av8r3400
YouTube Videos |
