rickofudall
Posted: Mon Jul 04, 2011 5:47 am Post subject: Bad day at Black Rock |
Well it was an interesting evening here, last. The short story is that I lost power on climb out at about 300 ft. Had a hell of a cross wind that had me crabbed about 30 degrees already so I only had another 150 degrees of the impossible turn left. I made the turn all right, but without time for a sufficient flair and ripped the left main gear off. I don't know the extent of the damage yet, it could be an easy fix or the fuselage truss may be junk. I hope I can salvage it, just have to wait and see. The good thing is I got away without a scratch, although I can feel a twinge in my right clavicle area. Probably just pulled a muscle. CRAP!
Rick Girard
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
991.83 KB |
6459 Time(s) |
1007.46 KB |
6459 Time(s) |
908.19 KB |
6459 Time(s) |
Kirkds
Posted: Mon Jul 04, 2011 6:25 am Post subject: Re: Bad day at Black Rock |
I have an Mark3 classic airframe kit for sale.
Posted: Mon Jul 04, 2011 7:48 am Post subject: Bad day at Black Rock |
The cage I bought to use on my MkIII looked about like that when I got it.You will need at least one socket tube and a bag o cutoff disks. Usually the associated little brace tubes pop off at the welds.
You can bend them right back and reweld.
Any idea of the lost power cause?
BB
On 4, Jul 2011, at 9:44 AM, Richard Girard wrote:
[quote]Well it was an interesting evening here, last. The short story is that I lost power on climb out at about 300 ft. Had a hell of a cross wind that had me crabbed about 30 degrees already so I only had another 150 degrees of the impossible turn left. I made the turn all right, but without time for a sufficient flair and ripped the left main gear off. I don't know the extent of the damage yet, it could be an easy fix or the fuselage truss may be junk. I hope I can salvage it, just have to wait and see. The good thing is I got away without a scratch, although I can feel a twinge in my right clavicle area. Probably just pulled a muscle. CRAP!
Rick Girard
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
<Right front 2.jpg><Right forward.jpg><Left forward.jpg>[b]
Dennis Thate
Posted: Mon Jul 04, 2011 9:48 am Post subject: Re: Bad day at Black Rock |
Sorry to hear this, but happy you got lucky and made a skillful landing and were not injured.
Hope you will post the cause of the power failure. When you know for sure what caused it to happen.
_________________ Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute. ~Gil Stern |
rickofudall
Posted: Mon Jul 04, 2011 10:03 am Post subject: Bad day at Black Rock |
How much do you want for it and where are you located?
Rick
On Mon, Jul 4, 2011 at 9:25 AM, Kirkds <kirkds(at)dishmail.net (kirkds(at)dishmail.net)> wrote:
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
rickofudall
Posted: Mon Jul 04, 2011 10:08 am Post subject: Bad day at Black Rock |
Pilot error. I'm pretty sure the toggle switch for the boost pump got set to off when I did a mag check. That's the hardest thing to swallow about the whole thing.
Rick
On Mon, Jul 4, 2011 at 10:45 AM, robert bean <slyck(at)frontiernet.net (slyck(at)frontiernet.net)> wrote:
| Quote: | The cage I bought to use on my MkIII looked about like that when I got it.You will need at least one socket tube and a bag o cutoff disks. Usually the associated little brace tubes pop off at the welds.
BB
Rick Girard
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
tp://forums.matronics.com
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
Kirkds
Posted: Mon Jul 04, 2011 10:33 am Post subject: Re: Bad day at Black Rock |
Since my email account won't let me send messages from Quebec I'll reply on list as it is working fine. The kit is in Michigan and the price is $3000.00. I'll be home by the weekend.
zeprep251(at)aol.com Guest
Posted: Tue Jul 05, 2011 4:02 am Post subject: Bad day at Black Rock |
Rick,
When ever I bent the gear legs on the Firestar,the twinge I felt was a little lower,just below my left hip,about where my wallet was.Glad you are OK.
G.Aman MK3C Jabiru 2200A
rickofudall
Posted: Tue Jul 05, 2011 10:47 am Post subject: Bad day at Black Rock |
Can you send some pictures when you get home? What all is included? Was construction started or is it a disassembled aircraft? And we are talking about a Kolb Mk III, correct?
Rick
On Mon, Jul 4, 2011 at 1:33 PM, Kirkds <kirkds(at)dishmail.net (kirkds(at)dishmail.net)> wrote:
| Quote: | --> Kolb-List message posted by: "Kirkds" <kirkds(at)dishmail.net (kirkds(at)dishmail.net)>
http://forums.matronics.com/viewtopic.php?p=344888#344888
le, List Admin.
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
Kirkds
Posted: Tue Jul 05, 2011 11:27 am Post subject: Re: Bad day at Black Rock |
I'll send pics and info when I get home.
