David d.
Joined: 04 Jul 2011 Posts: 60 Location: Fitzgerald Ga.
Richard Pike
Posted: Mon Jul 04, 2011 6:49 pm Post subject: Re: Newbie |
They all fly similarly, but the general feeling is different inasmuch as the Firestars with their narrow cockpit give a different sensory experience than the MKIII variants with their wide cockpits and room to dump stuff in the seat next to you. Also when taking off and landing, the MKIII variants feel wide and "planted," while the Firestar variants feel narrower, and a bit more teetery on their narrower gear. Landing my MKIII seems almost a no-brainer in taildragger terms, while the FSII is more classic taildragger, if you are not on your game, it is more likely to let you know it.
A lot depends on if you like to haul "stuff" around with you when you fly. The one is narrow and ergonomically challenging if you like a lot of electronic bells and whistles, the other has lots more room, panel, and places for electronic junk to be mounted.
I have equal access to a FSII with a Rotax 582 and a MKIII Classic with a Rotax 582, both handle similarly in the air, the FSII will fly the same speed as the MKIII at about 4-500 rpm less due to it's cleaner fuselage shape. Which works out to about 1 GPH less in fuel burn, and less in flight noise from the slower prop. But I fly the MKIII anyway, I just like it a bit better. Purely subjective.
Richard Pike
MKIII N420P (420ldPoops)
zeprep251(at)aol.com Guest
Posted: Tue Jul 05, 2011 4:24 am Post subject: Newbie |
Welcome Dave,
There are a lot of old timers on the list.Let us know where you are and one of the listers will give you a ride in a Kolb
G.Aman MK3C Jabiru 2200a 630 hrs-class of "38"
David d.
Posted: Tue Jul 05, 2011 6:15 am Post subject: Re: Newbie |
Thanks Richard,
One thing that is puzzling. Some 2 place Kolbs have one stick, others have 2.
It would seem that flying with the stick off center would be a bit challenging as the stick is not directly between the legs. Particular in time of hair raising, such as a crosswind landing.
Am I right in that only the Mark 3 has dual sticks (centered)?
Can the others be modified to bring the one stick over or change to two?
David d.
David d.
Richard Pike
Posted: Tue Jul 05, 2011 11:14 am Post subject: Re: Newbie |
| SS568 wrote: | Thanks Richard,
David d. |
Originally they all had just the one stick in the middle and it is not challenging at all. After a few flights, it seems like it is right where it needs to be, and the place between the legs is good for a radio and switch rack. And I don't have to try and get my leg over a stick.
Apparently the dual stick is now common, if I remember right (always a problem) the Hauck guys came up with the dual arrangement, and I think it is possible to retrofit. John? Others? Verify? Or am I all wet?
One thing I moved; the original throttle for the MKIII which was in the middle, replaced it with an add on quadrant on the left sidewall, which I like much better. Kolb details are easy to tinker with, if you want it different, change it.
http://www.bcchapel.org/pages/0003/kolb.htm
Richard Pike
Mike Welch
Posted: Tue Jul 05, 2011 11:49 am Post subject: Newbie |
Richard,
IIRC, you are correct that John H was somehow involved in the dual stick design option.
I think he said he, his brother Jim, and maybe Dennis came up with the design.
Although having dual sticks is an option, I guess it's not for everyone. I seriously thought
about going that route, but didn't like the idea of crawling over it, so I just stayed with the
"single center stick".
Speaking of 'crawling' over. I aslo relocated the center throttle to the left side of the
pilot seat...but I decided to mount it to the door frame. Now, when I open the door,
the throttle swings out of the way completely! For me, the less crawling over stuff,
the better.
| Quote: | Apparently the dual stick is now common, if I remember right (always a problem) the Hauck guys came up with the dual arrangement, and I think it is possible to retrofit. John? Others? Verify? Or am I all wet?
Richard Pike
Posted: Tue Jul 05, 2011 12:27 pm Post subject: Newbie |
design option.
design.
Folks:
My only involvement in the first set of dual controls in a Kolb aircraft was
coming up with the requirement and testing the finished product.
Brother Jim Hauck designed and fabricated the dual controls for my MKIII in
1991. He built the jigs, offered them to Kolb Aircraft, but they were not
interested in our dual controls.
Some time later Kolb Aircraft came up with their own design of dual
controls.
Brother Jim gave his dual control jigs to The New Kolb Aircraft Company.
All dual controls being produced by TNK and Kolb Aircraft are Jim Hauck dual
controls. Our late friend, Seth Mathews of Tallahassee, Florida, gave us
engineering expertise for the project, but the idea was mine, and the
majority of the project was the result of Brother Jim's expertise.
I fly my MKIII from the right seat, use the right stick between my legs and
the normal Kolb throttle in the center bewteen the seats. I long ago
removed the left stick to make it easier for passengers to board my MKIII.
I like my arrangement better than the center stick and throttle, or flying
left seat and moving the throttle to the left side. I have no problem
adjusting to either configuration, and have been flying both systems for
many years.
My biggest problem is adjusting to operation of the flap with my right hand.
I keep reaching for the handle with my left hand when I start flying from
the left seat.
_________________ John Hauck
Titus, Alabama |
Richard Pike
Posted: Wed Jul 06, 2011 4:20 am Post subject: Re: Newbie |
| John Hauck wrote: |
the left seat.
Titus, Alabama |
I understand. My car has the garage door opener in the console, the wife's car has it above the rear view mirror. Which means that whenever I am approaching the garage, the right hand is waving around uncertain of where to mash.
Richard Pike
