w_sweet(at)comcast.net Guest
Posted: Sun May 14, 2006 6:13 am Post subject: Di-Electric Grease; where used |
My other toy is a motorcycle, which has electronic everything. Some =
riders strongly advocate to apply dielectric grease the connectors for =
corrosion protection. But a dielectric is a non-conductor; seem =
counter-productive. What am I missing here?
Wayne
retasker(at)optonline.net Guest
Posted: Sun May 14, 2006 7:37 am Post subject: Di-Electric Grease; where used |
It has to be a non-conductor or you would short every pin to every other
pin. The purpose of the grease is to exclude oxygen and moisture - both
of which are needed to degrade the contacts.
Dick Tasker
Wayne Sweet wrote:
Please Note:
No trees were destroyed in the sending of this message. We do concede, however,
that a significant number of electrons may have been temporarily inconvenienced.
mprather(at)spro.net Guest
Posted: Sun May 14, 2006 8:03 am Post subject: Di-Electric Grease; where used |
Hi Wayne,
Here's my understanding:
Properly designed electrical connectors make gas-tight connections
between the conductors. This means that as well as squishing all of the
air out of the interface, closing the connection will also squish out
any other liquid/grease in the joint, including dielectric grease.
Applying dielectric grease to a properly designed connector will not
interfere with the conductive properties of the joint because the grease
will get squished out of the places where the joint is gas-tigth.
However, applying dielectric grease may stave off corrosion at the
margins of the joint. At the margins (edge) of a connection, there may
exist narrow (microscopic) crevices/voids, which can be the perfect
environment for corrosion of the materials used to make the connection.
Matt-
Wayne Sweet wrote:
Wayne
nuckollsr(at)cox.net Guest
Posted: Sun May 14, 2006 11:39 am Post subject: Di-Electric Grease; where used |
At 07:07 AM 5/14/2006 -0700, you wrote:
Wayne
Dow-Corning DC-4 and similar silicone greases are
excellent prophylactic treatments for exclusion of
moisture and other contaminants into connectors.
Waaaayyyy back when, we commonly filled the mating
spaces of coax connectors up on towers with DC-4 before
putting the connector together. Use sparingly. You don't
want it to ooze out and get the exterior all messy. The
stuff is VERY hard to get off and in the case of coax
connections, made it difficult to wrap with tape for
exterior water-barrier.
A coating the top insulator and terminal of a spark
plug before installing the spark plug wire would be
an assist for keeping moisture out of a potentially
vulnerable joint in the system. Same thing would be
good for coil end of wire.
Silicone greases migrate with time. Put a pea-sized
dab on a flat surface and come back a few months later.
You'll find a large silicone-grease wetted area around the
dab that continues to grow with time.
It's a neat stuff but I would use it reservedly with
respect to amount and location and only in areas where
a connection is likely to be exposed to extra-ordinarily
corrosive influences.
< with experiment. >
< --Lawrence M. Krauss >
