psm(at)att.net Guest
Posted: Sat Jul 09, 2011 2:06 pm Post subject: First Flight. |
I completed the first flight of my XL today. It went just fine, but
there were a number of small squawks to fix.
I wound up flying in the middle of the day and the sky was clear but the
air was unstable. I was not able to hold an attitude to do precise
measurements of airspeed or other parameters. Takeoff and landing went
just fine. I used 1/2 flaps for takeoff and full flaps for landing.
The nose was a little sticky on takeoff, so next time I think I will try
doing it with full flaps.
I think I had the tachometer setting on the Dynon EMS wrong. It
indicated I was doing 3800 RPM in a low cruise which just doesn't make
any sense. I had it set for 4 counts per revolution (the suggested
value in the Dynon book) and I think I will try 6 next time. I
controlled engine power by watching the cylinder head temperatures.
That left me at perhaps 1/2 power max for most of the flight.
I climbed to 5,000 feet and tried to do a couple of stalls - one with
and one without flaps. In both cases I was unable to get the nose to
drop, but the plane mushed and lost altitude much in the style of a
Piper. Indicated airspeeds in the mush was something around expected
values of 38 dirty and 45 clean. Again I couldn't maintain any airspeed
for long enough to be sure of the exact reading.
I also learned I need to install a trim tab on the rudder. I had to
hold left rudder for most of the flight to keep the ball centered. I
also need to darken the skin/panel above the instrument panel to improve
visibility when going toward the sun. The reflections made it hard to
see out front.
All in all it was a fine first flight. It will probably be a couple of
days before I am ready to try it again.
Paul
Camas, WA
XL in flight test - N773PM
merlin
Joined: 05 Oct 2008 Posts: 15 Location: Fair Play, S.C.
Posted: Sat Jul 09, 2011 2:17 pm Post subject: First Flight. |
Don't use any flaps for takeoff. Full flaps will only make the nose heavier for takeoff.
& congratulations on the 1st flight...hope you have many more. I hope to be there in about 2 years.
JW
Sent: Sat, July 9, 2011 6:03:28 PM
Subject: First Flight.
--> Zenith601-List message posted by: Paul Mulwitz <psm(at)att.net (psm(at)att.net)>
I completed the first flight of my XL today. It went just fine, but there were a number of small squawks to fix.
I wound up flying in the middle of the day and the sky was clear but the air was unstable. I was not able to hold an attitude to do precise measurements of airspeed or other parameters. Takeoff and landing went just fine. I used 1/2 flaps for takeoff and full flaps for landing. The nose was a little sticky on takeoff, so next time I think I will try doing it with full flaps.
I think I had the tachometer setting on the Dynon EMS wrong. It indicated I was doing 3800 RPM in a low cruise which just doesn't make any sense. I had it set for 4 counts per revolution (the suggested value in the Dynon book) and I think I will try 6 next time. I controlled engine power by watching the cylinder head temperatures. That left me at perhaps 1/2 power max for most of the flight.
I climbed to 5,000 feet and tried to do a couple of stalls - one with and one without flaps. In both cases I was unable to get the nose to drop, but the plane mushed and lost altitude much in the style of a Piper. Indicated airspeeds in the mush was something around expected values of 38 dirty and 45 clean. Again I couldn't maintain any airspeed for long enough to be sure of the exact reading.
I also learned I need to install a trim tab on the rudder. I had to hold left rudder for most of the flight to keep the ball centered. I also need to darken the skin/panel above the instrument panel to improve visibility when going toward the sun. The reflections made it hard to see out front.
All in all it was a fine first flight. It will probably be a couple of days
vk3eka(at)bigpond.net.au Guest
Posted: Sat Jul 09, 2011 2:46 pm Post subject: First Flight. |
Paul,
I agree with Jeffery, I don't use flaps on take off. Full flaps on landing
makes for a nice approach and landing.
Well done on the first one.
Cheers
Peter
Wonthaggi Australia
http://zodiac.cpc-world.com
Posted: Sat Jul 09, 2011 2:59 pm Post subject: First Flight. |
Paul,
Regarding the rudder, if you find that rudder is needed for most of the
flight, you might find that the rudder cables need adjusting to keep the
aircraft straight when the nose wheel steering rod attachments are in the
vee of the nose gear bottom bearing.
I have found that the rudder is not used much in general flight.
Peter
Wonthaggi Australia
jlatimer1(at)cox.net Guest
Posted: Sat Jul 09, 2011 3:28 pm Post subject: First Flight. |
Paul
Congratulations!!!!
Jerry
HDS 912 100 hrs
bryanmmartin
Posted: Sat Jul 09, 2011 3:34 pm Post subject: First Flight. |
I usually take off with no flaps and just pull back on the stick at 60 MPH to rotate and it flies off fine.
On Jul 9, 2011, at 6:03 PM, Paul Mulwitz wrote:
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus re-drive.
do not archive.
_________________ --
Bryan Martin
do not archive. |
Posted: Sat Jul 09, 2011 3:57 pm Post subject: First Flight. |
Thanks to everyone for the nice comments.
Peter, your comment about the rudder cables seems like it makes sense.
I couldn't figure why a full flying rudder would need a trim tab.
Perhaps I will try tweaking the cables first instead.
I guess I need to try taking off with no flaps as well as full flaps.
After all this is test flying. The Jabiru is a large engine for this
plane and makes it so overpowered I don't think it will have any problem
climbing with full flaps.
Paul
On 7/9/2011 3:57 PM, Peter W Johnson wrote:
Paul,
Peter
Wonthaggi Australia
rsteele(at)rjsit.com Guest
Posted: Sat Jul 09, 2011 4:23 pm Post subject: First Flight. |
Paul, Congratulations!
I hope it was worth all the difficulties.
So how does it fly compared to the Echo? Do you think the Echo
prepared you for first flight?
Ron
Posted: Sat Jul 09, 2011 5:02 pm Post subject: First Flight. |
Hi Ron,
Yes, it was worth all the difficulties. I flew a plane today that would
have never existed if not for my efforts over the last six years. That
makes it the longest project I have ever done. (Well, I've managed to
stay married to the same woman for 41 years . . .)
I can't really say how the Zodiac compares to the Echo. Today's flight
was not my best. The turbulence and my lack of familiarity with the
actual plane meant it was a pretty sloppy flight - at least by my
standards. In the large scheme of things I guess the two planes are
very similar. I'll try to do a detailed analysis of differences I noticed.
It took considerably more runway to get into the air than the Echo
takes, and still the nose jumped up rather than a nice smooth transition
from rolling down the runway to a nice climb profile. Takeoff (with
flaps) in the Echo is a matter of smoothly adding power and rotating as
soon as the power is in. With just one person it lifts off in around
300 feet of ground roll. I would estimate the runway needed today to be
closer to 600 feet in the same configuration and with a lot more
horsepower available.
One noticeable difference is the position of the main gear. The Echo
has the main gear located nearer to the CG than the Zodiac does. On
landing it is very easy to keep the Echo's nose gear in the air until
almost stopped. Holding the nose up after landing the Zodiac was a lot
harder. I managed to do it for a few yards (maybe 20 or so) but the
nose really wants to come down. I think this has a lot to do with the
low wing vs. high wing configuration. If the main gear were in the same
relative place on the Zodiac then stepping on the step to climb up on
the wing would cause the tail to hit the ground. I've seen some designs
that deal with this problem by putting the step in front of the wing
instead of behind it.
I think the Zodiac has a higher climb rate. This is only a guess since
the incorrect tachometer kept me from using full throttle and having
consistent power. A Jabiru powered Zodiac should climb a lot faster
than a Rotax powered Echo. There is 30 percent more power available to
convert to climb rate.
Visibility of the surrounding area is much better in the Zodiac. The
bubble canopy means everything above the horizon is easy to see and only
the wings and nose interfere with the view downward. In the Echo you
sit with your head at the same level as the wing roots. That means you
can't see much of anything to the side because the wings are in the
way. You really need to roll right to look for traffic before making a
left turn in the Echo. This is not an issue in the Zodiac.
I found it difficult to hold the Zodiac in the exact attitude I wanted.
This is just probably a "Training" issue. I also had difficulty doing
turns at the bank angle I wanted. I tended to roll too steeply into the
turn.
Oh . . . and the Jabiru sounds so much better than the Rotax engine. It
starts smoothly while the whole world shakes and rattles when starting a
Rotax. After you get it going, the Rotax seems to have a significant
ancestry in the sewing machine community while the Jabiru sounds just
great. Of course, this is just my opinion and I am certainly biased.
I suspect I will be able to do a much better comparison after I have
logged a few more hours in the Zodiac - especially if I get a nice calm
day to fly.
Paul
On 7/9/2011 5:20 PM, Ronald Steele wrote:
Ron
carlossa52(at)gmail.com Guest
Posted: Sat Jul 09, 2011 5:31 pm Post subject: First Flight. |
Paul, congratulations on your achievement.
How did the Jabiru behave in the temperature department?
Carlos
On 9 July 2011 18:03, Paul Mulwitz <psm(at)att.net (psm(at)att.net)> wrote:
[quote]--> Zenith601-List message posted by: Paul Mulwitz <psm(at)att.net (psm(at)att.net)>
Posted: Sat Jul 09, 2011 6:54 pm Post subject: First Flight. |
Hi Carlos,
Thanks for the kind words.
The Jab seemed to cool pretty well. I don't know how much power I was
generating, but each time the engine showed cylinders getting too hot
(over 350 F) I reduced power. I understand it will not generate as much
heat as the engine gets more broken in.
Paul
On 7/9/2011 6:28 PM, Carlos Sa wrote:
| Quote: | Paul, congratulations on your achievement.
Carlos
Ron Lendon
Posted: Sat Jul 09, 2011 7:48 pm Post subject: Re: First Flight. |
Congratulations Paul,
I know it has been a long and tiring process getting this airplane airworthy for you and I have much respect for the way you have gone through these details.
Fly Safe,
_________________ Ron Lendon
CH 601 XLB
N601LT - Flying
Corvair Engine Prints:
Posted: Sat Jul 09, 2011 8:39 pm Post subject: First Flight. |
Thanks, Ron.
Yes it has been a long path - one with treacherous curves. I'm afraid I
made a lot of enemies along the way. Perhaps now some of them realize I
wasn't just out to make their lives miserable.
Hopefully we can all be happy Zodiac owners and fliers now.
Paul
On 7/9/2011 8:48 PM, Ron Lendon wrote:
Fly Safe,
PatrickW
Joined: 27 Oct 2006 Posts: 380 Location: Fort Worth, Texas
Posted: Sun Jul 10, 2011 4:22 pm Post subject: Re: First Flight. |
Magnificent accomplishment, Paul.
Thanks for sharing your experience. Looking forward to hearing about Phase 1...
- Pat
Posted: Sun Jul 10, 2011 6:53 pm Post subject: First Flight. |
Thanks, Pat.
For now I am thinking the best thing for me to do is work on my pilot
skills and integration with my Zodiac. Yesterday I could barely control
the airspeed and attitude and I need to get a handle on that before I
can do any real testing.
I spent today fixing most of the squawks from yesterday's flight.
Perhaps I will fly again tomorrow and see how all the fixes came out.
One point of interest. I have a wood propeller and it really needed to
have its bolts retorqued after the first flight. Each one took a bout a
quarter turn to get back to the desired torque - 18 ft. lbs. in my
case. The Sensenich data said this would be necessary but I didn't
think it would take so much.
Paul
Camas, WA
XL with one whole hour of flight logged.
Afterfxllc(at)aol.com Guest
Posted: Sun Jul 10, 2011 7:28 pm Post subject: First Flight. |
Paul
Before you re torque you should loosen the bolts and let the wood relax and then re torque you will be surprised to here it pop and crack when you do. If you torque it when it is humid the wood swells and then when it is dry they will lose some torque also.
In a message dated 7/10/2011 10:54:11 P.M. Eastern Daylight Time, psm(at)att.net writes:
| Quote: | --> Zenith601-List message posted by: Paul Mulwitz <psm(at)att.net>
Thanks, Pat.
Paul
Camas, WA
| Quote: | --> Zenith601-List message posted by: "PatrickW"<pwhoyt(at)yahoo.com>
- Pat
Patrick Hoyt
601XLb/Corvair
N63PZ - 99.999% done....
http://forums.matronics.com/viewtopic.php?p=345831#345831
don.honabach(at)pcperfect Guest
Posted: Mon Jul 11, 2011 10:03 am Post subject: First Flight. |
Paul,
| Quote: | > I found it difficult to hold the Zodiac in the exact attitude I wanted.
On my 601HDS, I found that it was sensitive to altitude changes as well. One thing I noticed is that the stick is very easy to bias with your hand. In all fair weather cases, whenever altitude hold is an issue for me, I always find that I'm pushing or pulling the stick and not noticing since the controls are so light. I've eventually found that steering with my hand holding the bottom part of the Y leads to super easy altitude holds, as does just using my finger tips ...
Congrats on your first flight!!!
Don
Posted: Mon Jul 11, 2011 10:13 am Post subject: First Flight. |
Thanks, Don.
That sounds like good advice. When I had non-pilots try to fly the
Tecnam I had I told them it was a 2 finger airplane. That tended to
work quite well.
I'm sure I will be fine with a few more hours. I am just paying the
price now for not getting a checkout before flying my own plane. It was
unreasonable for me to think I could just jump in and fly it like I was
born in it. I don't feel like I had any safety issues to fix, just a
lack of perfection on the first try.
Paul
On 7/11/2011 11:02 AM, Don Honabach wrote:
| Quote: | Paul,
Don
Posted: Mon Jul 11, 2011 10:27 am Post subject: First Flight. |
Hey Paul,
Where are you based? Probably too close to do your 40 hours and go to Oshkosh this year for you (???). Any thoughts on flying out next year?
BTW, took me ~11 years to finish my 601HDS. I thought it was funny that you hinted that 6 years was a 'long time'. For me, you are Mr. Speedy I'm still trying to figure out how I managed to take a '400 hour' build time and stretch it to 11 years!!!
Don
Posted: Mon Jul 11, 2011 11:01 am Post subject: First Flight. |
Hi Don,
I am indeed going to Oshkosh this year. I will not be flying my Zodiac
there. I'm taking Delta Airlines to Appleton.
My Zodiac will probably be ready to fly to OSH next year, but I'm not
sure I will. It is around 2500 miles each way. That is a big trip in a
seat that fits more like a suit of clothes than a lounge chair.
I originally decided to go because I had a lunch date with Sabrina, but
she seems to be mad at me about something or other and is giving me the
teenaged-girl cold shoulder. I guess I'll have to find other folks to
have lunch with.
I signed up for the electric symposium again. I went to the one last
year and didn't learn much of value for a home builder considering
building an electric powered plane. Perhaps this year's effort will be
more on target. At last year's symposium I did get talked into joining
the ASTM F37 committee which deals with LSA standards. That has been
interesting - to say the least.
I'll be accessing email in the evenings while at OSH, so if anybody
wants to get together for lunch (or to beat me up for all my
transgressions over the last few years) then email is the way to contact
me. I also ordered tickets for the Heintz dinner Wednesday night but
I'm not sure I will have the nerve to go. Perhaps if I find some body
armor to wear . . .
Paul
Camas, WA
On 7/11/2011 11:26 AM, Don Honabach wrote:
| Quote: | Hey Paul,
BTW, took me ~11 years to finish my 601HDS. I thought it was funny that you hinted that 6 years was a 'long time'. For me, you are Mr. Speedy;-) I'm still trying to figure out how I managed to take a '400 hour' build time and stretch it to 11 years!!!
Don
