Tim Olson
Posted: Wed Jul 13, 2011 12:22 pm Post subject: Rapco brake linings and discs now available |
As you know if you've read my write-ups, I've been
bugging Rapco for 4 or 5 years to start making the
66-112 brake linings for us so we have an alternate
price and supply. The Cleveland ones go in and out
of stock too often and the price is top dollar.
I got a set of the new Rapco linings and replaced
my discs at the same time since I scored one of
them on the first brake pad run....running the rivets
into the discs.
So here's a write-up with pictures of the new
discs.
http://www.myrv10.com/N104CD/maintenance/20110711/index.html
If you haven't seen the brake lining replacement write-up,
also follow the link to that one from within this page.
Tim Olson - RV-10 N104CD
rv10flyer(at)verizon.net Guest
Posted: Wed Jul 13, 2011 1:38 pm Post subject: Rapco brake linings and discs now available |
Desser sells the Rapco's as a reminder.
Tim Olson
Kellym
Posted: Wed Jul 13, 2011 3:14 pm Post subject: Rapco brake linings and discs now available |
Desser gave me a very nice deal on tires and tubes, buying their
standard recaps exchanged for worn out cores. I've had very good service
from their recaps here in Aridzona heat, much better than new tires.
IIRC the exchange price gave about $10 credit for each core.
KCHD |
Deems Davis
Posted: Fri Jul 15, 2011 6:44 am Post subject: Rapco brake linings and discs now available |
When I ordered new(recapped) Tires and Leakgard tubes from Dresser, based on
advice from this list I ordered a replacement set of RAPCO pads from Dresser
(aka VansRVTires) as well. I intended to replace the brake pads at my last
annual when I was doing the tires. However, I noticed that the pad were 1/4"
SHORTER in length than the old pads. The rivet holes align perfectly and
they are stamped/marked with the correct part number. I put them aside as
there was plenty of pad left on the existing pads, and intended to call
Dresser and ask ... why?? IMO the -10 is not blessed with brakes that are
TOO big and I wsn't interested in loosing any braking ability. Seeing this
thread reminded me that I haven't called. Anybody else notice this or have
more info chime in.
Deems
Tim Olson
Posted: Fri Jul 15, 2011 8:06 am Post subject: Rapco brake linings and discs now available |
Weird...mine were the same size. I wonder what the mixup was...
Tim. (enroute home from osh!)
more info chime in.
Deems
Posted: Fri Jul 15, 2011 7:14 pm Post subject: Rapco brake linings and discs now available |
yes, they are smaller but they will last longer than what you had before,
from what I was told.
Pascal
partner14
Posted: Fri Jul 15, 2011 7:57 pm Post subject: Rapco brake linings and discs now available |
I put on a set that Pascal gave me.... noticed they were slightly smaller.... but they seem to do the job just fine.
Don McDonald
On Jul 15, 2011, at 8:11 PM, "Pascal" <rv10flyer(at)verizon.net> wrote:
yes, they are smaller but they will last longer than what you had before, from what I was told.
Pascal
40636 |
