stickandrudder1(at)comcas Guest
Posted: Sat Jul 16, 2011 6:44 pm Post subject: Electrical System Drawing |
Attached is a draft electrical schematic based primarily on Bob Nuckolls' Z-13 electrical system drawing. Note that I plan on using an internally regulated Plane Power 30A backup alternator, which is supposed to be out by Oshkosh. If not, I'll use the B&C SD-20. The reason for the second 7.2 AH battery is to insure field current to the backup alternator in the event of main battery failure. I have thought of using a second full sized battery as the AUX, which I would connect in parallel with the main battery for more cranking power.
Questions I have are:
Is an Avionics bus & switch unnecessary or is it still a good idea? I like the idea, and I know the GTX 327 is supposed to be powered off during engine start. Also the GTN 6xx install doc says it should be on an Avionics bus. Others have suggested (and even said that Bob Nuckolls doesn’t think much of the idea in his book – although I couldn’t find anywhere he discussed it) that the avionics bus is unnecessary with modern avionics, adds complexity and additional potential points of failure. Bob doesn’t show it on the drawings I’ve studied, so I’m wondering.
What are the failure modes of the EBUS Diode? Will it ever fail open? If it fails and allows reverse current, what is the best way to detect the failure?
My schematic has a battery bus drawn, but I really don't see a need for it. Other than a clock and interior lights, is there something that I have placed on another bus that really should be on a battery bus?
What about the location of the backup alternator?
I show it connected to the essential bus instead of the un-switched side of the battery contactor, in the event of a dead short in the battery. I'm not sure if that's a failure mode I need to even consider.
Another thing I’ve though of is although I haven’t done a load analysis yet, but I’m pretty sure with a 30A backup alternator, I could combine the Avionics and E-Bus busses (the only things that would be added to the E-BUS would be Com2, Transponder and audio panel.
Any comments and criticism of the design would be greatly appreciated.
The aircraft I am building is an RV-7A. The mission is day/night IFR.
Thanks Paul
 Download |
| Filename: |
Drawing7.pdf |
56.26 KB |
| Downloaded: |
345 Time(s) |
Posted: Sat Jul 16, 2011 6:50 pm Post subject: Electrical System Drawing |
Thanks Paul
 Download |
| Filename: |
Drawing7.pdf |
56.26 KB |
| Downloaded: |
348 Time(s) |
Posted: Sun Jul 17, 2011 7:09 am Post subject: Electrical System Drawing |
Go to AeroElectric.com and do a search on avionics
master. The original ideas behind the birth of the
avionics master was a figment of the designer's
imagination. The enduring rationale for the AV
master is not based on physics or facts.
They don't fail.
Do you have an electrically dependent engine?
Those items should be on a battery bus.
If you're going to have two alternators and
two batteries, suggest Z-14 instead.
I know there are compelling notions of "doing
it a little bit better" but as your list of
questions illustrates, making changes generates
new uncertainties. The Z-figures have already
been subjected to the same questions over the
last 20+ years. By now they are 99.9% free
of unknowns.
Suggest you study Z-14 and develop a list
of questions that address and perceptions
you have of not meeting design goals for
your airplane. It's much more comfortable
to start with a proven recipe for success
and then see if serious design goals are
not being met.
If it were my airplane, I'd save a LOT of
dollars, weight and worry with Z-13/8. That
system offers overall reliability that a
King Air doesn't have. Only in the last 20
years has Z-12 found its way onto type certificated
aircraft in large quantities. The vast majority
of TC aircraft use the same architecture as
a 1946 C-140A Your concerns about failures of diodes
and batteries suggest that you're not
comfortable with the idea that reliability of
these things is very high when used with
understanding.
It's far better that you have a SIMPLE
system you understand than a NOT SO SIMPLE
system born of mis-understanding.
Posted: Sun Jul 17, 2011 11:00 am Post subject: Electrical System Drawing |
| Quote: | | Attached is a draft electrical schematic based primarily on Bob Nuckolls' Z-13 electrical system drawing. Note that I plan on using an internally regulated Plane Power 30A backup alternator, which is supposed to be out by Oshkosh. |
Do you really NEED that much back-up power?
What are the load analysis numbers for the
minimum loads to get you to airport of intended
destination while saving the battery for
approach to landing?
Another thing I’ve though of is although I haven’t done a load analysis yet, but I’m pretty sure with a 30A backup alternator, I could combine the Avionics and E-Bus busses (the only things that would be added to the E-BUS would be Com2, Transponder and audio panel. |
Loan analysis needs to be first . . . before
you size alternators. Also, keep in mind that
intermittent loads like landing lights, transmit
current are not continuous running loads.
Can you get your ENDURANCE loads down to 8A
or less?
If you do a search of unhappy events in the cockpit
leading to bent airplanes and/or bleeding people,
the percentage of total incidents involving electrical
system failures is exceedingly small. A majority of
those instances could have been mitigated by
better pilot understanding and good preventative
maintenance.
It's comforting to add redundancy on top of band-aid
on top of worry issue . . . but all of these have
costs of ownership. I passed a big pile of first-aid
kits in the pharmacy at Walmart last week. I think they
were $5. If Wallyworld sells them, they must move out
the door in significant numbers. I've been driving
for over 50 years, owned dozens of cars and probably had
at least a half-dozen first-aid kits of one form or another.
I can recall no single instance of ever using the contents
of such kits . . . nor finding myself in a position of
wishing I had one.
You are far more likely to enjoy a high order of
reliability by careful study of what's need should
any single device fail . . . and developing a plan-B
for that failure. The goal is not to keep everything
lit up all the time, only those things needed for
getting to airport of intended destination so that
the battery alone will get you on the ground with
lights a blazing both inside and outside the cockpit.
Every serious accident we've studied here on the list
that grew of out electrical systems issues had
root cause in poor craftsmanship and/or poor judgement
and lack of understanding of the system. Adding more
hardware will generally not do much to offset those
human frailties.
Bob . . . [quote][b]
