rockford67
Posted: Sat Jul 16, 2011 8:40 am Post subject: Gross Weight increase |
Hey Pulsar owners,
I've just bought a Pulsar XP with a an 80hp R912. I'm wondering if anyone has any documentation about increasing the gross weight? It's currently at 1060 and I'd like to go to 1100 or possibly as high as 1140?
Thanks for any tips,
Chris
| | - The Matronics Pulsar-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Pulsar-List |
ccoulter(at)wavecable.com Guest
Posted: Sat Jul 16, 2011 9:27 am Post subject: Gross Weight increase |
On Sat, 16 Jul 2011 09:40:11 -0700
"rockford67" <cphorsten(at)yahoo.ca> wrote:
Hey Pulsar owners,
Chris
http://forums.matronics.com/viewtopic.php?p=346670#346670
Leave it where it is.
Clarke >
Un/Subscription,
Forums!
Admin.
bernard.wilder2(at)gmail. Guest
Posted: Sun Jul 17, 2011 10:37 am Post subject: Gross Weight increase |
Does your plane have wood or composite covered wings ? ? ?
Bernie Wilder
On Sat, Jul 16, 2011 at 12:40 PM, rockford67 <cphorsten(at)yahoo.ca (cphorsten(at)yahoo.ca)> wrote:
[quote]--> Pulsar-List message posted by: "rockford67" <cphorsten(at)yahoo.ca (cphorsten(at)yahoo.ca)>
Hey Pulsar owners,
Chris
ist Un/Subscription,
www.matronics.com/Navigator?Pulsar-List" target="_blank">http://www.matronics.com/Navigator?Pulsar-List
ronics.com/" target="_blank">http://forums.matronics.com
Matt Dralle, List Admin.
esalehto(at)yahoo.com Guest
Posted: Sun Jul 17, 2011 9:05 pm Post subject: Gross Weight increase |
Hi Chris,
I have Pulsar XP and my GW is 1060. I have as well Rotax 912UL, 80 hp engine.
Esa
To: pulsar-list(at)matronics.com
Sent: Saturday, July 16, 2011 11:40 AM
Subject: Gross Weight increase
Hey Pulsar owners,
Chris
/Navigator?Pulsar-List" target="_blank">http://www.matronics.com/Navigatosp; - MATRONICS WEB FORUMS -
= --> http://ww=======================
rockford67
Posted: Tue Jul 19, 2011 6:16 am Post subject: Re: Gross Weight increase |
Well, it seems there is no great desire to increase the load on the Pulsar's out there. My local inspector suggested that if the right calculations could be done, reducing the G limits could allow for more weight. I guess no one has done it. The higher G limits of the Pulsar suggest that there is some margin there but I'm not about to be the test pilot. Have to wonder about what the heavier examples are doing though? Mine weighs an unconfirmed 620 lbs which I think is heavy, but have a look at the one on Barnstormers for sale which weighs in at 800-something with a 1200 gross. After full fuel he has less than 250lbs left.
So, maybe the right question should be, what sort of things will reduce the empty weight? With a vacuum pump and a six pack, plus a radio and transponder there is definitely room to shed a few pounds, but I'd like to keep all these! A Dynon is a possibility and it would eliminate the pump. Some lighter radios are possible. But all this comes at great expense. I'd like to get the weight to 600lb but is that realistic? How many owners have Pulsars that weigh in at 600lbs or less? And if they do, what sort of equipment do they have?
Chris
pilot623(at)gmail.com Guest
Posted: Tue Jul 19, 2011 7:50 am Post subject: Gross Weight increase |
Chris,
For weight comparisons, you need to know the exact model and possibly the
serial number of the other planes. I don't have the info but I'm sure
someone here can tell you when and how the various models changed and how
that relates to expected empty weight. Mine is a Series 2 with Rotax 912S
and weighed in at 685 lbs empty when first built. Like most planes, it has
gained weight over time with the addition of another auto pilot, CS prop,
fire repairs, etc. To compensate, I have lost a little weight.
Jim
rockford67
Posted: Tue Jul 19, 2011 8:28 am Post subject: Re: Gross Weight increase |
Hey Jim,
Mine is an XP 912. Serial # 462. I have composite spars and skins, and a heavier duty nose gear (one with an aerodynamic shape instead of a tube).
My manuals are a dec 1994 revision.
Another local guy suggested that body filler has added significant weight to some examples. I never did check his weight but his was a beauty with dynon, avmap, and some nice innovations for flap handle, ventilation, etc.
My biggest challenge is that I need a stainless firewall and the current one is aluminum. Engines gotta come out. I need a gascolator too and carb heat. It's just the regs here in Canada - no exceptions.
C
briana(at)xtra.co.nz Guest
Posted: Tue Jul 19, 2011 11:14 am Post subject: Gross Weight increase |
Chris,
Mine is #456, xp with 912 engine. It has a few "improvements" including an ss firewall, electric flaps, etc and weighs in at about 648 lbs. Can carry two lightweights like me, full fuel and a little baggage. Never felt the need for a greater weight limit.
Brian
On 19/07/2011, at 4:16 PM, "rockford67" <cphorsten(at)yahoo.ca> wrote:
Chris
http://forums.matronics.com/viewtopic.php?p=347029#347029
w7ikt(at)fly-web.us Guest
Posted: Tue Jul 19, 2011 11:42 am Post subject: Gross Weight increase |
When I built my XP serial #394 I stated the gross weight as 1100lb.
Composite Spars and skins on the wings.
On a certified plane you would need and STC and form 337 to change the gross weight.
Since experimentals do not have STC's or 337's a log book entry should make the change.
The FAA could consider it a major change and require 5 or 10 hours of test flying without passengers.
On the question of is the plane strong enough to handle the gross weight increase consider Bernie unplanned high speed test flight way over red line.
God Bless
Bob Heiser
On 7/19/2011 10:49 AM, pilot623 wrote: [quote] [quote]--> Pulsar-List message posted by: "pilot623" <pilot623(at)gmail.com> (pilot623(at)gmail.com) Chris, For weight comparisons, you need to know the exact model and possibly the serial number of the other planes. I don't have the info but I'm sure someone here can tell you when and how the various models changed and how that relates to expected empty weight. Mine is a Series 2 with Rotax 912S and weighed in at 685 lbs empty when first built. Like most planes, it has gained weight over time with the addition of another auto pilot, CS prop, fire repairs, etc. To compensate, I have lost a little weight. Jim --
Posted: Tue Jul 19, 2011 1:10 pm Post subject: Gross Weight increase |
There are people who are flying their Pulsars a little heavy. Haven't heard of one breaking yet.
Of more concern to me was the CG calculation. With my XP if I load to max gross and then run the wing fuel cells way down, I bust the aft CG limit.
Bernie Wilder
Bernie Wilder
On Tue, Jul 19, 2011 at 11:49 AM, pilot623 <pilot623(at)gmail.com (pilot623(at)gmail.com)> wrote:
[quote]--> Pulsar-List message posted by: "pilot623" <pilot623(at)gmail.com (pilot623(at)gmail.com)>
Chris,
Jim
freedom4life(at)xtra.co.n Guest
Posted: Tue Jul 19, 2011 1:50 pm Post subject: Gross Weight increase |
[quote] My Pulsar XP weighed in at 568lb when first constructed. 1060lb was the design limit for my model. Like all aircraft it has gained weight since with a constant speed prop and several other fitments. I have done the conversions into pounds to see what I sometimes carry and there have been times when it has been loaded to 1150lb. The main thing I have found you need to watch at these weights is the stall becomes more of a snap than a docile departure and as Bernie says if get low on fuel your CoG goes a little too far rearward. I am nearly always carrying 60lb in the luggage compartment as I take my Border Collie with me everywhere plus tools, tie downs and first aid kit etc. The dog weighs 44lb of this lot. So they will carry the load but I don't take it into any turbulence or throw it around when I am over gross.
Cliff McChesney
ZK KFC
Bernie Wilder
Bernie Wilder
Chris,
Jim
alan99gill(at)yahoo.co.uk Guest
Posted: Tue Jul 19, 2011 11:57 pm Post subject: Gross Weight increase |
Sent: Tuesday, 19 July 2011, 22:48
Subject: Re: Pulsar-List: Re: Gross Weight increase
Cliff McChesney
ZK KFC
Bernie Wilder
Bernie Wilder
Chris,
Jim
sonja.englert(at)juno.com Guest
Posted: Wed Jul 20, 2011 6:18 am Post subject: Gross Weight increase |
Increasing the gross weight increases the wing spar stresses and reduces the margin for the landing gear. The Pulsar has a 4.4 g limit load factor, so basically the wings are capable of lifting 4.4 x 1060 lb = 4664 lb. If you increase the gross weight for example by 100 lb, the limit load factor would be reduced to 4.0 g. It is actually not quite as simple as this, but this shows essentially what happens. I would not recommend doing it.
Sonja
____________________________________________________________
57 Year Old Mom Looks 27!
Mom Reveals $5 Wrinkle Trick That Has Angered Doctors!
http://thirdpartyoffers.juno.com/TGL3131/4e26e37ddd6cce2ab8st05duc
Posted: Thu Jul 21, 2011 4:53 pm Post subject: Gross Weight increase |
On Tue, 19 Jul 2011 07:16:47 -0700
Chris
My XP Series I is 600 lbs. I understand the Series III comes in at about 700. Mark Browns 582 is under 500.
Clarke
Un/Subscription,
Forums!
Admin.
Posted: Thu Jul 21, 2011 4:58 pm Post subject: Gross Weight increase |
On Tue, 19 Jul 2011 17:08:51 -0400
Bernard Wilder <bernard.wilder2(at)gmail.com> wrote:
| Quote: | There are people who are flying their Pulsars a little
heavy. Haven't
XP if I load to max
the aft CG limit.
Bernie Wilder
Bernie Wilder
> Chris,
>and possibly the
>but I'm sure
>2 with Rotax 912S
>most planes, it has
>weight.
> Jim
With me and my wife and 2 galons of fuel ( worst case) we
can only have 30 lbs of luggage or we go aft CG.
Clarke
[quote]> --
Posted: Thu Jul 21, 2011 6:55 pm Post subject: Gross Weight increase |
Pulsar XP N12RV composite wings and spars VFR panel w autopilot 570 lb empty.
I was careful when building to use just enough resin to wet the glass and used peel ply paper towels and sand bags to absorb the extra resin whenever possible.
Most of the extra weight is likely extra resin - hard to remove now.
God Bless
Bob Heiser
On 7/21/2011 7:52 PM, HUGH COULTER wrote: [quote]--> Pulsar-List message posted by: "HUGH COULTER" <ccoulter(at)wavecable.com> (ccoulter(at)wavecable.com)
"rockford67" <cphorsten(at)yahoo.ca> (cphorsten(at)yahoo.ca) wrote:
| Quote: | --> Pulsar-List message posted by: "rockford67" <cphorsten(at)yahoo.ca> (cphorsten(at)yahoo.ca)
Chris
My XP Series I is 600 lbs. I understand the Series III comes in at about 700. Mark Browns 582 is under 500. |
Clarke
Un/Subscription,
Forums!
Admin.
rockford67
Posted: Thu Jul 21, 2011 7:45 pm Post subject: Re: Gross Weight increase |
Bob I think you are right about the resin. Possibly one of the single biggest weight problems. Always been a metal airplane guy, but now that I've this glass bird I'm watching some you tube videos about layups etc. Seems the important thing is to use as little resin as possible. The extra resin doesn't add any strength. Wish I could still buy a new Pulsar kit. Would be fun to give it a try from scratch.
C
