David d.
Joined: 04 Jul 2011 Posts: 60 Location: Fitzgerald Ga.
Posted: Sun Jul 24, 2011 12:04 pm Post subject: No N number |
There is a kolb on barnstormers for sale. It was converted from a tandem seating to a side by side.
The ad also says the N number will have to be removed. It also said the inspection was not completed.
I have read recently that if some inspection was not completed on time that the FAA would not reissue, even to a new owner.
Can anyone comment on this N number issue, or am i confusing it with something else.
David d.
gtaylor35918(at)roadrunne Guest
Posted: Sun Jul 24, 2011 1:08 pm Post subject: No N number |
Dave,
Not too long ago I sold a FS 1 back to the person I bought it off of
because I found out from the FAA that if it was not certified by Jan. 2010
and had a airworthy certificate that I could not register it, and If I could
not get it below the 254 lb. ultralite weight that I would not legally be
able to fly it. I gave 3000 for the plane and I have about 8 or 9 grand in
my Private/IFR ticket so I decided it wasn't worth the risk of my license to
fly the FS even though it was fun to fly. For what it's worth I plan to find
one that is legal to fly. If you can't keep the N-number then it/s just a
lawn ornament.
elleryweld(at)aol.com Guest
Posted: Sun Jul 24, 2011 4:14 pm Post subject: No N number |
I talked with a FAA Rep in my area and they are willing to bend a bit to help some people out
Ellery Batchelder Jr.
gliderx5
Posted: Sun Jul 24, 2011 4:34 pm Post subject: No N number |
David
The N number is usually not a problem, but that is just the registration that shows that you own it. The difficult part is the airworthiness certificate. The January 2010 deadline that for light sport. You can still register it as an experimental amateur built any time, as long as you can document that it was built by amateurs. This will require a builders log, including photos of the building process. If the seller has that information then it should not be a huge deal to get the airworthiness certificate. If he does not have it, then you probably will not be able to make it legal to fly.
Malcolm Morrison
http://home.comcast.net/~mmorrison123/index.htm
Sent: Sunday, July 24, 2011 4:04:37 PM
Subject: Kolb-List: No N number
--> Kolb-List message posted by: "SS568" <david(at)PaulowniaTrees.com>
David d.
http://forums.matronics.com/viewtopic.php?p=347588#347588< - List Contribution Web Site -
David d.
Posted: Sun Jul 24, 2011 5:22 pm Post subject: Re: No N number |
Do I have this right?
If I go to see about a used LSA, then it is not necessary for it to have an N number, but desirable.
It should have a current air worthiness cert. but if not?
Or if the air worthiness is out of date?
David d
rickofudall
Posted: Sun Jul 24, 2011 5:40 pm Post subject: No N number |
No, David, you have it wrong. The problem is that it was registered as an LSA but the airworthiness certificate was never issued (I looked up the N number). It is not legal to fly as it is and because it was previously registered as an LSA it can't be legally re-registered as an Amateur built now. So, unless you need spare parts, or you want a really nifty lawn ornament, leave it be.
Rick Girard
On Sun, Jul 24, 2011 at 8:22 PM, SS568 <david(at)paulowniatrees.com (david(at)paulowniatrees.com)> wrote:
| Quote: | --> Kolb-List message posted by: "SS568" <david(at)PaulowniaTrees.com>
David d
http://forums.matronics.com/viewtopic.php?p=347614#347614
le, List Admin.
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
byoungplumbing(at)gmail.c Guest
Posted: Sun Jul 24, 2011 7:38 pm Post subject: No N number |
guess I have not seen the tail number,,,, if it was registered as a lsa,,, why cant it remain a lsa? I am having trouble understanding why it cant remain in the lsa category,, if the owner wanted to keep the n number,,, why cant a new n number for lsa be issued?
what would have made the previously registered lsa airworthiness invalid?
I have not done any research,,, but if the tail number was reserved,,, and never granted because the inspection was never done,,,, could it be a experimental armature built by reserving a new tail number and having the inspection finalized? as long as the documentation is complete to comply with the experimental classification. or reserve a new n number and have it inspected lsa or experimental...
if the plane was an old fat ultralitght,,, and never registered before the deadline,,, I could understand,,, but once registered lsa it still should be good.
I dont know what I am missing here.
before I jumped to any conclusions,,, I would call get a hold of the builder and find out the details,, and not guess at what is going on then call the fisdo and get an answer before I spent my money.
does an air worthiness ever go out of date,,,, or just need an annual inspection, or was an faa re registration letter sent out and ignored... I believe there was a grace period to renew,,, or another time frame to reapply.
confused,,, which is not as hard as it use to be.
boyd young
mkiii utah
quote
David
Richard
rickofudall
Posted: Sun Jul 24, 2011 8:01 pm Post subject: No N number |
Here's the data from the FAA data base. Aircraft Description Serial Number D R B 2Type Registration Individual Manufacturer NameKOLB Certificate Issue Date09/04/2007 ModelFIRESTAR Expiration Date09/30/2012 Type Aircraft Fixed Wing Single-EngineStatus ValidPending Number Change NoneType Engine 2 CycleDate Change Authorized NoneDealer NoMFR Year NoneMode S Code 51066413Fractional Owner NO Registered Owner Name BOWMAN DANNY R Street 717 N MORGAN ST CityMEADVILLE StatePENNSYLVANIA County CRAWFORDZip Code 16335-2122 CountryUNITED STATES Airworthiness Engine ManufacturerUnknown ClassificationUnknown Engine Model UnknownCategory None A/W DateNone
The A/W certificate was never issued. The last date to do that was January 31st 2010. You can't get it now.
21.191 Experimental certificates.
Experimental certificates are issued for the following purposes:
(i) Operating light-sport aircraft. Operating a light-sport aircraft that—
(1) Has not been issued a U.S. or foreign airworthiness certificate and does not meet the provisions of §103.1 of this chapter. An experimental certificate will not be issued under this paragraph for these aircraft after January 31, 2008; (this was extended to 2010 PROVIDED the aircraft was registered by the 2008 date)
I've asked both the local FSDO and the Light Sport Branch in Oklahoma City if there is ANY way they will issue an E-AB certificate for one of these aircraft and the answer is always NO.
Rick Girard
On Sun, Jul 24, 2011 at 10:35 PM, b young <byoungplumbing(at)gmail.com (byoungplumbing(at)gmail.com)> wrote:
| Quote: | guess I have not seen the tail number,,,, if it was registered as a lsa,,, why cant it remain a lsa? I am having trouble understanding why it cant remain in the lsa category,, if the owner wanted to keep the n number,,, why cant a new n number for lsa be issued?
boyd young
mkiii utah
quote
David
Richard
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
rmurrill(at)cox.net Guest
Posted: Sun Jul 24, 2011 8:14 pm Post subject: No N number |
I would not call the local Fisdo...Congress just laid most of them off and any that are there are probably pretty pissed ... I have talked to a guy at EAA headquarters several times...lost his name, but he is their guru of odd ball experimental licensing I think he has seen just about every non standard scenerio....If it can be fixed he will know how and will make recommendations as to how to approach local FAA offices.
bob
Sent: Sunday, July 24, 2011 8:35 PM
Subject: Re: Re: No N number
boyd young
mkiii utah
quote
David
Richard
rickofudall
Posted: Sun Jul 24, 2011 8:18 pm Post subject: No N number |
Boyd, I didn't answer the last part of your question. IF you do not re-register an E-LSA that was issued an airworthiness certificate under the "fat ultralight" provision, i.e. FAR 21.191 i (1) in the time allotted and allow the registration to expire its airworthiness certificate is null and void AND IT CANNOT BE RE-ISSUED (caps for emphasis, not yelling). Why? Because the provision has expired, as have all the forms that serviced that provision. There is no path to reissue an airworthiness certificate, now. It's an unintended consequence of the re-registration scheme. I know Edsel is probably tired of repeating this, but you can check it with him at the Light Sport Branch. I haven't asked in a year, who knows, maybe there's been a miracle and FAA's Legal Dept. has found a way. But that's the answer that I got and it was confirmed by Roger Lee on the Rotax engines forum and several others. Please don't shoot the messenger. I didn't make the mess, I don't work for the FAA.
Rick Girard
On Sun, Jul 24, 2011 at 10:59 PM, Richard Girard <aslsa.rng(at)gmail.com (aslsa.rng(at)gmail.com)> wrote:
| Quote: | Here's the data from the FAA data base. Aircraft Description Serial Number D R B 2Type Registration Individual Manufacturer NameKOLB Certificate Issue Date09/04/2007 ModelFIRESTAR Expiration Date09/30/2012 Type Aircraft Fixed Wing Single-EngineStatus ValidPending Number Change NoneType Engine 2 CycleDate Change Authorized NoneDealer NoMFR Year NoneMode S Code 51066413Fractional Owner NO Registered Owner Name BOWMAN DANNY R Street 717 N MORGAN ST CityMEADVILLE StatePENNSYLVANIA County CRAWFORDZip Code 16335-2122 CountryUNITED STATES Airworthiness Engine ManufacturerUnknown ClassificationUnknown Engine Model UnknownCategory None A/W DateNone
Rick Girard
boyd young
mkiii utah
quote
David
Richard
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
Posted: Sun Jul 24, 2011 10:11 pm Post subject: No N number |
Rick Girard
i am not going to shoot anyone,,,, i just didn't understand,,,, it just seemed to me that if it was regisered lsa,,,, it could be re registered lsa..
it is not my plane,,, not my problem.. just trying to understand
thanks/
boyd
Posted: Mon Jul 25, 2011 4:44 am Post subject: No N number |
For sure, that is not a "buy it and fly it" airplane. -which is the smartest way to get an experimental, just write a checkfor a purty one. I don't know much about those old and arcane LSA regs, and don't care to, and I imagine more than a few
novices have been burnt buying an experimental that is "registered" but has no AW certificate.
then again, if you are an ambitious lad, you might buy that pile for a song (say $500) strip it down, clean and prime it,
take pictures of all the parts sitting on tables in your garage, Put them back together, cover and paint and then
register and apply for an AW cert. on YOUR new experimental airplane.
BB
On 25, Jul 2011, at 2:08 AM, b young wrote:
| Quote: | Please don't shoot the messenger. I didn't make the mess, I don't work for the FAA.
Rick Girard
thanks/
boyd
Dana
Posted: Mon Jul 25, 2011 4:48 am Post subject: No N number |
The provision to register a plane as E-LSA was a one time thing, intended to legalize all the "ultralight trainers" and other fat ultralights... but the entire process, including the inspection, had to be.completed by the deadline.
It _may_ be possible to register it as E-AB if you can provide build documentation. Probably it depends on the local FSDO. I have a friend who registered a Quicksilver GT-500 as E-AB after flying it as a UL for 20 years... but he really was the original builder.
-Dana
b young <byoungplumbing(at)gmail.com> wrote:[quote] Please don't shoot the messenger. I didn't make the mess, I don't work for the FAA.
Rick Girard
thanks/
boyd
David d.
Posted: Mon Jul 25, 2011 7:31 am Post subject: Re: No N number |
Greetings again to all
This has been a great exchange of info. I have belonged to many forums(non aviation) and this one has them all beat as to content and attacks on other posters.
Attack the message and not the messenger is an excellent guideline.
Now to be sure that I have this straight:
1. If I go to look at a LSA (used). Then before kicking any tires etc. ask for a N number. And it associated paperwork.
2. Then ask for the AW certificate, and see that it is in date.
I presume it is not legal to fly without these two.
Is there anything else , other than a bill of sale?
David d.
Thom Riddle
Posted: Mon Jul 25, 2011 7:45 am Post subject: Re: No N number |
David,
For a registered aircraft to be legal for flight, the AROW documents must be in the aircraft:
A - Airworthiness certificate
R- Registration certificate
O - Operating Limitations
W- Weight and Balance information (current)
It must also have a current (within last 12 calendar months) condition inspection recorded in the aircraft logbook.
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
David d.
Posted: Mon Jul 25, 2011 5:04 pm Post subject: Re: No N number |
Thanks to all I have a better understanding of what to look for when looking at a used craft.
This info may have saved me a lot of misery. And most likely helped others also.
I will keep my AROW close by.
David d.
