		javiercarrascob
				 Posted: Wed Jul 27, 2011 6:44 pm    Post subject: Mixing-Blending oil types |
				Hello Gang,
 Hope you are enjoying EAA week, I'm currently using Aeroshell 100W. for my M-14p powered Yak-55m.
 As you may know when you do cross country in a '55 there is not much room to bring oil with you.
 I find my self landing at FBOs that don't carry either Aeroshell 100W or 120w in summer (80w in winter). Not to mention Phillips 25w-60 is even harder to find (hence I use 100W).
 So
 Question 1: Can I mix/Blend Aeroshell 100w with 100? I understand that one is ashless dispersant and the other one is straigh mineral (no aditives)?
 Question 2 : Can I mix 100w with 80w when it starts to get cold?
 Question 3: Can I mix Aeroshell 100w with Phillips 25w-60?
 Thanks, Javier
 N5245H
  |  | - The Matronics M14PEngines-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?M14PEngines-List |
		MONTY(at)bpaengines.com Guest
				 Posted: Mon Aug 01, 2011 8:54 am    Post subject: Mixing-Blending oil types |
				You can mix AS 100W with AS 80W or either with AS xxx M.  You are
 correct.  Asxxx W is ashless despersant oil and xxx M is straight
 mineral oil without the additives that make it xxx W.  What you should
 not  do is mix synthetic oils with petroleum based oils.
 AS 100 W is good oil in my books.  That's what we use in our M14 test
 cell from the git-go.  Never had a problem.  Failure of rings to seat is
 usually not a problem caused by oil.  It is operator error as a general
 rule, can be unclean at assembly.  It is impossible to get cylinders (
 or anything else ) too clean.  If I could sterilize them I would.
 Monty Barrett
 BPE, Inc.
