Permanet Splicing RG400
jc-matronics_aeroelectric
PostPosted: Sun Jul 31, 2011 6:57 am    Post subject: Permanet Splicing RG400 Reply with quote
I am wondering if there is a way of permanently splicing together 2
sections of coax wire together. I realize I could use a male/female
connector. However, i would like to route this cable thru a wing
conduit, and the bulky connectors would just get in the way.
Thanks for any insights!
Jae
RV-10
PostPosted: Sun Jul 31, 2011 8:02 am    Post subject: Permanet Splicing RG400 Reply with quote
At 09:51 AM 7/31/2011, you wrote:
<jc-matronics_aeroelectric(at)jline.com>
2 sections of coax wire together. I realize I could use a
male/female connector. However, i would like to route this cable
thru a wing conduit, and the bulky connectors would just get in the way.
This only works well with heat-resistant,
modern coax like RG400 or RG142.
Slip 2 pieces of 1/2" heat shrink, 4 inches
long over ends to be spliced.
Strip back 1-1/2" of outer jacket and
push braids back to the end of the jackets.
Cut center conductors to 1" per side, then
strip 1/4" per side. Lap solder center
conductors. Wrap exposed joint with Teflon
pipe thread tape. It's okay if the tape
overlaps the ends of the center conductor
insulation and leaves a bit of a 'lump'.
Then take braid from one side and pull it
over the center conductor splice. Wrap
the last 1/2" with a few turns of fine strand
wire taken from some airframe wire. Solder
wire wrap very thinly to the braid. You're
wanting this to get 'fixtured' and 'smooth'
without getting 'thick'.
Pull the other braid over the fixtured
braid and repeat the fine-strand-wire wrap.
Then solder the braids to each other. Use
63/37 tin-lead solder.
Cover joint with one piece of shrink and heat
it. Cover with second piece of shrink and
heat that.
Yeah, this puts an 'impedance bump' in your feedline
that can be observed with the proper test equipment.
But if you had identical installations on the
airplane except for one pristine feedline and
one spliced feedline, you could switch back and
forth between them and observe no difference
in performance.
I used to do this with RG-58 . . . it's pretty
tricky due to low melting temperatures of the
PVC and PolyE insulations but it CAN be done
with practical success.
rparigoris
PostPosted: Sun Jul 31, 2011 8:16 am    Post subject: Re: Permanet Splicing RG400 Reply with quote
Hi Bob
Thx. for your explanation on how to splice coax cable.
Question:
What is airframe wire? Strands of stainless or plain steel control wire rope (control cable)? Or perhaps you mean thin copper strands of Tefzel wire that is hanging around?
"a few turns of fine strand wire taken from some airframe wire"
Thx.
Ron Parigoris
PostPosted: Sun Jul 31, 2011 9:18 am    Post subject: Permanet Splicing RG400 Reply with quote
At 11:16 AM 7/31/2011, you wrote:
--> AeroElectric-List message posted by: "rparigoris" <rparigor(at)suffolk.lib.ny.us>
Hi Bob
Question:
Sorry, 'hookup wire' is perhaps a better term.
A piece of 22AWG, M22759 will yield some nice
strands of 34AWG wire nicely suited to this
'fixturing' task.
When you're lap-splicing stranded wire, you
can use a strand from the base conductor
as shown . . .
http://tinyurl.com/dgg2nb
But in the coax-splicing task, you need to
acquire the fixture strands elsewhere.
Bob . . . [quote][b]
rparigoris
PostPosted: Sun Jul 31, 2011 9:53 am    Post subject: Re: Permanet Splicing RG400 Reply with quote
Hi Bob
Thx. for the reply.
Ron Parigoris
Do not archive.
PostPosted: Mon Aug 01, 2011 3:49 pm    Post subject: Permanet Splicing RG400 Reply with quote
Wow, thank you Bob for that detailed explanation. Now that I have the
"how" I have to decide if it's worth it.
Just checked on the price of RG400, and it seems to be around $2.50/ft.
Egads! I swear that is 2x more than what i paid for my original order
just a year ago!? That's $33 savings if i can splice the coax myself. Very Happy
Jae
RV-10
PostPosted: Tue Aug 02, 2011 6:58 am    Post subject: Permanet Splicing RG400 Reply with quote
the "how" I have to decide if it's worth it.
$2.50/ft. Egads! I swear that is 2x more than what i paid for my
original order just a year ago!? That's $33 savings if i can splice
Yeah, that stuff has gotten expensive . . . but
anything with copper in it has been given an excuse
to jump in price . . . even if copper is the least
expensive commodity in the product.
I'll poke around my surplus/used sources and see
if I can dig up some 400 at more attractive prices.
But for our purposes, the splice I described is
pretty easy to do and has no observable impact
on performance. For that matter, you could consider
RG58 for anything except GPS and Transponders.
That coax performed well for decades.
PostPosted: Tue Aug 02, 2011 7:21 am    Post subject: Permanet Splicing RG400 Reply with quote
Don't forget eBay. For example, if your run is 9' or
less, you can buy something like this:
http://tinyurl.com/4x3a3na
which is pre-assembled with connectors. But it's $10
with free shipping. Cut the connectors off and install
your own.
Also, consider the modern Poly coax LMR400. It's larger
in diameter but connectors for it are easy to get.
It's losses at the high frequencies are on par with
the fancier stuff and a whole lot cheaper. If the
size is not a turn off for your particular application:
http://tinyurl.com/3k86rvm
stuart(at)stuarthutchison
PostPosted: Wed Aug 03, 2011 3:39 am    Post subject: Permanet Splicing RG400 Reply with quote
G'day Bob,
I assume RG58 TNC/BNC connectors are fine for RG142, +142 or 400 coax? I don't understand why TNC connectors are listed at Aircraft Spruce for between $35 and $62 each, yet even silver-plated types are avaliable here in Australia (from RS) for around $10-15. What am I missing please?
Cheers, Stu
PostPosted: Wed Aug 03, 2011 7:09 pm    Post subject: Permanet Splicing RG400 Reply with quote
At 06:35 AM 8/3/2011, you wrote:
G'day Bob,
Yes.
Not a thing. There are coax connectors that are
essentially interchangeable but built and qualified
to different specifications . . . which for our
purposes doesn't matter. Prices on identical connectors
can vary widely too depending on the supplier's
volume, expertise and target customer base.
When we added those connectors to our wesite catalog
many moons back, I think I bought them in 100 lots
for something on the order of 95 cents and sold them
for $2. The exact came connector was commonly offered
at $3.50 in single lots. But if you bought a mil-qualified
connector in small quantities, it could be pretty
breathtaking without being any 'better' for what you're
needing to do.
http://www.alliedelec.com/search/productdetail.aspx?SKU=7131150
http://www.alliedelec.com/search/productdetail.aspx?SKU=7131003
