Thom Riddle
Posted: Sat Aug 06, 2011 4:45 am Post subject: HD video |
Larry,
I just tried to view your video on my iPhone and it took
Me to the right page and shied me a still shot but had circle with a hash mark thru it indicating it would not play. So then went to a random vid
Thomo
(sent from iPhone 4)
On Aug 6, 2011, at 7:57 AM, "Larry Cottrell" <lcottrell1020(at)gmail.com (lcottrell1020(at)gmail.com)> wrote:
[quote] http://vimeo.com/27361845
I just got my new Tachyon XC HD micro camera yesterday. I made a short flight last evening to see what the picture quality is like. I did make some of the clips pretty short, trying to keep the size down for upload. First test is hopeful. It took me on my Baud rate about 60 minutes to upload this, not that much more than for the other camera.
Larry
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
Thom Riddle
Posted: Sat Aug 06, 2011 4:49 am Post subject: HD video |
Oops. .... To a random video on vimeo and was able to view it. My question is this. What format is your video in? Does vimeo convert uploaded videos to their own format (guessing not) or keep them in their native format. I have been ablest view your earlier videos on iPhone and iPad and my iMac.
Thom Riddle
Larry
Buffalo, NY (9G0)
- Anonymous |
russkinne(at)mac.com Guest
Posted: Sat Aug 06, 2011 7:03 am Post subject: HD video |
LarryFWIW your vimeo came thru fine on my Mac. Impressive little camera!
Russ
On Aug 6, 2011, at 7:57 AM, Larry Cottrell wrote:
| Quote: | http://vimeo.com/27361845
Larry
phactor9
Posted: Sat Aug 06, 2011 7:37 am Post subject: HD video |
I have a Tachyon OPS HD on order. Can't wait!
Did you fast forward or speed up the movie in any way? It looks twice normal speed. What procedure did you use to unload from the cam to your computer and then upload? What video editing software?
Phil H.
--- On Sat, 8/6/11,<l> wrote:
Subject: HD video
To: Undisclosed-Recipient(at)yahoo.com
Date: Saturday, August 6, 2011, 7:57 AM
Larry
| [quote][b]
Mic
Joined: 22 Jul 2011 Posts: 12 Location: Ashland, Oregon
Posted: Sat Aug 06, 2011 10:29 am Post subject: Re: HD video |
Larry, FWIW, I just viewed your video on my PC without a hitch. The HD quality is just great. Thanks for posting it. So, for my 2 cents, take as many videos as you like and I'll be watching for sure.
Michael
_________________ Mic
"It is far better to grasp the universe as it really is than to persist in delusion, however satisfying and reassuring."
— Carl Sagan
"Education is not filling a bucket, but lighting a fire."
— W.B. Yeats |
Thom Riddle
Posted: Sat Aug 06, 2011 12:22 pm Post subject: Re: HD video |
Larry,
I was at the hangar this morning when I tried to view your video on my iPhone and it did not work. I am home now and tried it on my iPad and it worked fine. I then tried it again on the iPhone and it still did not work. Since I upgraded the op sys on the iPhone last week but not yet done so on my iPad, I suspect my problem is localized to my newest op sys.
Great video quality! Flying close to the ground as you were doing in this video, makes 65-70 mph look like over a hundred if you are used to flying above 500' agl.
As always, thanks for your great videos.
Buffalo, NY (9G0)
- Anonymous |
pj.ladd(at)btinternet.com Guest
Posted: Sun Aug 07, 2011 2:54 am Post subject: HD video |
if you are used to flying above 500' agl.>>
That's interesting. What height agl do you guys usually fly? You always seem
to give your heights above sea level but the fact that you are at 10,000feet
doesn`t really mean much.
I flew for an hour last night. Almost no wind and the air was smooth.
Climbed out to about 1000ft.. Backed off the throttle as CHT`s were
climbing. Cruise is usually 2600rpm which gives about 70mph. Climbed to
1500ft to sniff around a couple of hot air balloons. They took pictures.
Dropped a bit lower to take a look at a farm strip with a couple of planes
on it. Watched one take off and followed him for a while.Climbed with him to
around 2000ft.
Wandered off to look at a large quarry hole. Got a slight bump from a last
lingering thermal coming off the hot stone face. This reminded me of landing
out in my glider many many years ago when I failed to find a thermal coming
from the same source. Flew hands off. Slight tendency to bank left. Nose
dropped gently until the vario showed 2knots down and then it rose slowly
and then repeated. Not self correcting so had to fly her again. About 15
miles from my strip at that point at 1700 ft agl so turned for home.
Throttled back and began to slide downhill until close to the strip.
Dropped to around 1000ft, No one else about. Straight in approach. Throttle
back, 50 mph, First stage of flap. A bit high, Second stage flap. She drops
comfortably into the slot. 500ft Back to first stage flap. 350ft Throttle
back a bit, Speed a little high, nose up a touch. Close throttle and nudge
the nose down a shade as we drift over the hedge. Taxy in, push her into the
hangar. Put the covers on and close up the hangar. Wife turns up and we go
to a local pub for a couple of pints and a steak..End of a perfect flight.
Pat
Thom Riddle
Posted: Sun Aug 07, 2011 3:33 am Post subject: Re: HD video |
Pat,
Depends upon where you live/fly. In western NY, we have to be careful of altitude for both legal and safety reasons. There is a lot of agricultural area here outside the cities but also lots of small towns and residences with precious little undeveloped area except for forests. The FAA says no closer than 500' from any person, structure or vehicle and 1,000' above "congested" areas is the normal minimum, except on departure and approach.
Where Larry lives and flies, I suspect there are few if any mobile/cell towers or other tall structures that could snag him and few people, vehicles or structures which would require 500' clearance to stay legal. Certainly no areas that the most liberal interpretation would be called "congested". BTW, the FAA does not define "congested area" but in court, sometimes the interpretation has been as few as 3 houses in close proximity to each other, or so I've heard. I have no intention of finding out the hard way. When flying on the Lake Erie or Lake Ontario shoreline (off shore a bit) I am comfortable getting down to 100' agl or sometimes a bit less. A sudden unexpected sneeze at 20' agl could ruin the flight.
Buffalo, NY (9G0)
- Anonymous |
Posted: Sun Aug 07, 2011 6:27 am Post subject: HD video |
Sounds like the end of a perfect day, not just a perfect flight -- your wife is a gem; to pick you up & feed you steak & a pint!
Tell her I said so
Your CHT's normally climb that much in a climb?
FWIW I usually fly at 500-1000 AGL because I Iike to look around, and take pictures. We must maintain 1000' over 'populated areas'
fair winds,
Russ
On Aug 7, 2011, at 6:52 AM, Pat Ladd wrote:
That's interesting. What height agl do you guys usually fly? You always seem to give your heights above sea level but the fact that you are at 10,000feet doesn`t really mean much.
I flew for an hour last night. Almost no wind and the air was smooth. Climbed out to about 1000ft.. Backed off the throttle as CHT`s were climbing. Cruise is usually 2600rpm which gives about 70mph. Climbed to 1500ft to sniff around a couple of hot air balloons. They took pictures.
Dropped a bit lower to take a look at a farm strip with a couple of planes on it. Watched one take off and followed him for a while.Climbed with him to around 2000ft.
Wandered off to look at a large quarry hole. Got a slight bump from a last lingering thermal coming off the hot stone face. This reminded me of landing out in my glider many many years ago when I failed to find a thermal coming from the same source. Flew hands off. Slight tendency to bank left. Nose dropped gently until the vario showed 2knots down and then it rose slowly and then repeated. Not self correcting so had to fly her again. About 15 miles from my strip at that point at 1700 ft agl so turned for home. Throttled back and began to slide downhill until close to the strip. Dropped to around 1000ft, No one else about. Straight in approach. Throttle back, 50 mph, First stage of flap. A bit high, Second stage flap. She drops comfortably into the slot. 500ft Back to first stage flap. 350ft Throttle back a bit, Speed a little high, nose up a touch. Close throttle and nudge the nose down a shade as we drift over the hedge. Taxy in, push her into the hangar. Put the covers on and close up the hangar. Wife turns up and we go to a local pub for a couple of pints and a steak..End of a perfect flight.
Pat
Posted: Mon Aug 08, 2011 1:20 am Post subject: HD video |
your wife is a gem; to pick you up & feed you steak & a pint!>
Aint it de trooth! Aint it de trooth?
Pat
Posted: Mon Aug 08, 2011 1:38 am Post subject: HD video |
<<There is a lot of agricultural area here outside the cities but also lots
departure and approach.>>
Hi Thom,
that would describe my area and the Flight Rules are the same. Fields are
probably smaller than yours but there is usually something big enough to get
into when it all goes quiet.
Pat
