japhillipsga(at)aol.com Guest
Posted: Mon Aug 08, 2011 6:08 am Post subject: RV-8 Cowl Vents |
Dear Fellow RV-8 Builders, I now have 13 hours on my 0360 Lyc. Still having # 1 CHT get too hot before TOC. So I have to throttle back and stairstep up to altitude. Temps should be stable by now with 13 hours. So I bought from Avery the bottom cowl louvers to improve airflow. Talked to a couple RV-8 drivers both said the vents lowered CHTs about 20 degrees. Question is how is best to mount? What shape and size hole(s)? The bottom of the vent plate is flat while the cowl bottoms have compound curve surfaces. What is best for looks and effectiveness and strength? Hope to hear from someone, Bill of Georgia N288WP
| | - The Matronics RV8-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
Matt Dralle Site Admin
Joined: 08 Nov 2005 Posts: 26785 Location: Livermore CA USA
Posted: Mon Aug 08, 2011 9:53 am Post subject: RV-8 Cowl Vents |
At 07:04 AM 8/8/2011 Monday, you wrote:
| Quote: | Dear Fellow RV-8 Builders, I now have 13 hours on my 0360 Lyc. Still having # 1 CHT get too hot before TOC. So I have to throttle back and stairstep up to altitude. Temps should be stable by now with 13 hours. So I bought from Avery the bottom cowl louvers to improve airflow. Talked to a couple RV-8 drivers both said the vents lowered CHTs about 20 degrees. Question is how is best to mount? What shape and size hole(s)? The bottom of the vent plate is flat while the cowl bottoms have compound curve surfaces. What is best for looks and effectiveness and strength? Hope to hear from someone, Bill of Georgia N288WP
Hi Bill,
I have an IO-390 210hp on my RV-8 with the standard cowling. I don't have any trouble with CHT's (generally well under 400f) and my oil temps are generally in the low 180'sf. If I take off on a hot day at sea level and climb hard, I can get the CHT on the hot cylinder to go over 400 but by that time I'm at 8000 ft and simply decreasing my angle slightly will bring it back down. The only "non-stock" aspect of my installation is the giant oil cooler I added to the back of the baffle. Its about twice the size of the stock one.
Before you start cutting holes in your cowling, you might want to do some more investigation into the cause of the overheating. Might be indicative of something else. Plugged oil line to that cylinder, maybe a blocked fuel injector on that cylinder? Try swapping the injectors between the hottest and coolest cylinder and see what impact this has on the CHT.
Here's some info on the oil cooler installation that has worked well for me:
http://www.mattsrv8.com/users/display_log.php?user=MattsRV8&project=638&category=2972&log=90253&row=84
Matt
RV-8 #82880 N998RV "Ruby Vixen"
http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log
http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log
Status: 170+ Hours TTSN - Rebuilding Fuselage After Landing Mishap...
_________________ Matt Dralle
n223rv(at)wolflakeairport Guest
Posted: Mon Aug 08, 2011 2:28 pm Post subject: RV-8 Cowl Vents |
Bill,
Do you have the wheel pants and gear leg fairings installed? If not, I would not make any drastic changes until you get them installed. They will speed your plane up and provide less drag, of which you will get more airflow and less engine work.
On Aug 8, 2011, at 1:47 PM, Matt Dralle <dralle(at)matronics.com> wrote:
Hi Bill,
Matt
robin(at)PaintTheWeb.com Guest
Posted: Mon Aug 08, 2011 2:41 pm Post subject: RV-8 Cowl Vents |
That was our experience exactly (8A) but with oil temps, our CHT's were fine. Wheel pants & leg fairings added about 14 knots and reduced our oil temps about 15 degrees.
Robin
On Mon, Aug 8, 2011 at 3:25 PM, Michael Kraus <n223rv(at)wolflakeairport.net (n223rv(at)wolflakeairport.net)> wrote:
[quote] --> RV8-List message posted by: Michael Kraus <n223rv(at)wolflakeairport.net (n223rv(at)wolflakeairport.net)>
Bill,
On Aug 8, 2011, at 1:47 PM, Matt Dralle <dralle(at)matronics.com (dralle(at)matronics.com)> wrote:
> --> RV8-List message posted by: Matt Dralle <dralle(at)matronics.com (dralle(at)matronics.com)>
> Hi Bill,
> Matt
> Matt Dralle
> http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel
rget="_blank">http://www.matronics.com/Navigator?RV8-List
http://forums.matronics.com
le, List Admin.
Posted: Mon Aug 08, 2011 4:01 pm Post subject: RV-8 Cowl Vents |
Thanks fellows, the engine is new and only has 13 hours on it. I am still working on the damned intersections and pants, etc. I appreciate the advise not to install the louver vents until I see how she does with the undercarriage clean, Makes good sense, Bill
Speedy11(at)aol.com Guest
Posted: Tue Aug 09, 2011 7:35 pm Post subject: RV-8 Cowl Vents |
Bill,
I sure agree with Matt on this subject. I would investigate other causes for the high CHT before cutting up the cowling. I would cut the cowling only if all CHTs were too high.
His ideas are good ones and you also might try swapping the #1 and #3 CHT probes. Maybe #1 is reading high.
It is very odd that #1 cylinder would be your hot one. Did you add an air dam in front of it? If so, have you tried different size dams? Or removing the air dam?
Stan Sutterfield
In a message dated 8/9/2011 3:09:02 A.M. Eastern Daylight Time, rv8-list(at)matronics.com writes:
| Quote: | Before you start cutting holes in your cowling, you might want to do some more
Posted: Tue Aug 09, 2011 8:09 pm Post subject: RV-8 Cowl Vents |
Stan, I tested the CHT probes and they are correct. I have the standard Van's baffle wind dam in front of # 1 Cylinder. I trimmed about 5/8th inch off the top and noted a small drop in CHT tempt, but it did not even out with the other three jugs. I'll just not worry about it until after I get the wheel pants and leggings all installed. Thanks for the help, Bill
Posted: Wed Aug 10, 2011 8:30 am Post subject: RV-8 Cowl Vents |
Oh, my... I missed the part where you had installed the air dam baffle in front of #1! Get rid of that completely. The Baffle Plans say to start *without* this baffle and then add it IF #1 is running too cool. I never installed this air dam and have never had any problems with #1.
Matt
At 09:06 PM 8/9/2011 Tuesday, you wrote:
[quote]Stan, I tested the CHT probes and they are correct. I have the standard Van's baffle wind dam in front of # 1 Cylinder. I trimmed about 5/8th inch off the top and noted a small drop in CHT tempt, but it did not even out with the other three jugs. I'll just not worry about it until after I get the wheel pants and leggings all installed. Thanks for the help, Bill
Posted: Wed Aug 10, 2011 12:44 pm Post subject: RV-8 Cowl Vents |
Matt, I'll do that before I fly again. BTW How is the rebuild coming? We all expect to see her better and
faster than before. Thanks, Bill
Posted: Wed Aug 10, 2011 5:55 pm Post subject: RV-8 Cowl Vents |
The rebuild is coming alone nicely. Definitely going faster the second time. I'm shooting to re-test fly in the Spring. Just getting ready to start the wiring this weekend. With the wiring complete, how much more could there be? <smirk>
Matt
At 01:40 PM 8/10/2011 Wednesday, you wrote:
[quote]Matt, I'll do that before I fly again. BTW How is the rebuild coming? We all expect to see her better and
Posted: Wed Aug 10, 2011 7:07 pm Post subject: RV-8 Cowl Vents |
Bill,
I initially flew my RV with no dam in front of #1 cylinder. It was running about 30 degrees cooler than the others so I added a "ski ramp" air dam that is easily replaced. I can try different shapes and sizes until I get the temp just right. I've never liked the blunt, brute force air dams placed in front of cylinders, so I made a more aerodynamic, easily replaceable, easily modified air dam. You can see a photos and comments at http://www.rv-8a.net/2009Jul.htm and http://www.rv-8a.net/2010Jun.htm
Stan Sutterfield
In a message dated 8/10/2011 3:07:05 A.M. Eastern Daylight Time, rv8-list(at)matronics.com writes:
| Quote: | I tested the CHT probes and they are correct. I have the standard Va
heel pants and leggings all installed. |
