stearman456
Posted: Fri Aug 12, 2011 6:10 am Post subject: One Noisy Mag |
This past week I decided to tackle some radio noise in my '49 Aeronca Champ. Although I can transmit just fine (Narco Comm 111) there was always some background ignition noise when receiving (you need to be about only 15 miles away to hear an ATIS clearly). But when you switch over to just the right mag (Bendix mags) the noise goes away. The noise is ignition noise, it varies directly with the rpm, and I believe it's radiated noise as it varies with the radio volume control.
If you disconnect the P lead from the left mag's filter (Lone Star Aviation’s Magneto filters) the noise goes away completely and the radio is perfect. The P leads were shielded wire, probably 16 gauge, and the shields were grounded to the mag cases. Checking the mag switch (AAF A-7 type) I found that the shields were also grounded at the switch. "Aha!" says I. "exactly what Bob said never to do." So I reached in with a pair of side cutters and cut the connections to the shields. Rolled her back outside, started her up and... no change - still a noisy left mag.
Deciding that the P lead itself must be chafed or the shielding was open somewhere I removed both leads and made up two new ones from 18 gauge shielded wire, and carefully added a second wire (not just a pigtail) to connect the shielding to the mag case on the respective mag. Installed them last night, rolled her back outside and... no change! Same quiet right mag/noisy left mag. I couldn't see it being the switch itself but even so I swapped the leads on the switch and the noise followed the lead, so it's not the switch. Just for fun I even tried disconnecting the shielding on the left hand lead and, though it didn't improve, it didn't seem to make it any worse either. The only difference I can come up with between the mags is the left mag has the impulse coupling on it (re-read your article about mag switches in the EAA magazine, Bob. Lots of good info there - thanks) but that shouldn't have anything at all to do with it.
I'm stumped. Should I perhaps use heavier wire for the P leads, or is this an actual mag problem?
Thanks in advance.
Dan
warbirds(at)shaw.ca
Posted: Fri Aug 12, 2011 9:05 am Post subject: One Noisy Mag |
good point
If I read this experiment correctly, the left mag filter is still
wired to the p-connection on the mag itself . . . but the
wire going to the magneto switch is disconnected from the
other end?
switch. "Aha..." says I. "exactly what Bob said never to do."
Not so much a problem for noise. But it provides a second
ground path between crankcase and airframe that parallels
all other grounds . . . there is a potential for burning your
p-lead wire as described in the 'Connection.
So this experiment has the shielded wire grounded
a the magneto (probably to the filter mounting screw)
at one end and to the GRD terminal of the magneto
switch at the other end?
the mag cases on the respective mags.
Okay
it's not the switch. The only difference I can
should have anything at all to do with it.
Good deduction
No, actual size of the wires is unimportant.
24AWG would 'function'. The general rule of thumb
for operational wires (not instrumentation) under
the cowl is 20AWG or heavier . . . for mechanical
robustness.
What we may be witnessing is the innate perversity
of shielded wires . . . at least in the eyes of
many builders. Shielding is 99.9% effective in
breaking the electro-static coupling mode and about
1% effective in breaking a radiated coupling mode
depending on the frequencies involved.
EXCEPTION: Plug wires with shields connected to
ground at both ends behave more like transmission
lines . . . like your coax from antenna to radio.
In this case, there is considerable attenuation
of the electro-static coupling of a fast-rise high-
voltage spark pulse. Further, they break the
wire's ability to be an efficient antenna. Modern
plug wires will have resistance wire as the center
conductor which has little effect on spark energy
but really whacks the wire's performance as an antenna.
This is the ONE place where shielding is indicated for
both coupling modes . . . if you put an effective
RFI filter on a plug wire, the plug wouldn't fire!
The shields behave more as an 'enclosure' since the
wires are short and the shields grounded a very
low-impedance ground (crankcase).
The filters on both p-leads that break the radiated
coupling mode before the trash gets out onto the p-
leads. So if your noise goes away when the engine is
run without a p-lead connected to the filter . . .
then a reasonable deduction is that the filter is not
doing its job.
The fact that noise goes away with a p-lead
disconnected also says your plug wires are good.
I've never personally seen a filter go bad but
they're a spares item in most inventories so it
must happen now and then. Try swapping the filters
between mags . . . If this makes a difference as
to which mag is noisy, you might want to replace
both. One tired ol' filter going t-u may be a
portent of things to come for the other one as
well.
Good detective work!
stearman456
Posted: Fri Aug 12, 2011 1:58 pm Post subject: Re: One Noisy Mag |
Hi Bob,
Thanks for the help.
other end?
Yes, the P lead was disconnected from the filter, so when the engine was running with no P lead to the switch the filter was still connected to the mag itself.
The P lead wire itself is grounded at the mag switch (the switch itself has a ground wire to the fuselage frame) but the shielding for the P lead is only grounded at the mag case to one of the screws.
I'll swap the filters around tonight and let you know how that goes. Really appreciate the help.
Dan
warbirds(at)shaw.ca
[/i]
stearman456
Posted: Fri Aug 12, 2011 9:04 pm Post subject: Re: One Noisy Mag |
Hi Bob,
That was it - I swapped the mag filters and now I have a noisy right hand mag and a quiet left hand one. Don't know why I didn't think of that, though they're not all that old. Must have had a dud right out of the box because it's always been like that and I installed those filters about five years ago, but... that happens sometimes. Two new filters are on order. Thanks for the help - sure appreciate it.
Dan
warbirds(at)shaw.ca
Posted: Sat Aug 13, 2011 10:00 am Post subject: One Noisy Mag |
At 12:04 AM 8/13/2011, you wrote:
Quote: |
Hi Bob,
sometimes. Thanks for the help - sure appreciate it.
Pleased to be of service. You were getting close
by yourself. The detective work was on point.
user9253
Joined: 28 Mar 2008 Posts: 1938 Location: Riley TWP Michigan
Posted: Sat Aug 13, 2011 6:44 pm Post subject: Re: One Noisy Mag |
Quote: | Checking the mag switch (AAF A-7 type) I found that the shields were also grounded at the switch. "Aha!" says I. "exactly what Bob said never to do." So I reached in with a pair of side cutters and cut the connections to the shields |
Some magneto switches have a terminal labeled GND to which the shields are attached. This GND terminal is not an actual airframe ground. The shields need to be connected to this terminal in order for the switch to short out the P leads. The mag switch operation should be verified to be sure there is not an always hot mag.
Joe
_________________ Joe Gores |
doramsey(at)gmail.com Guest
Posted: Sun Aug 14, 2011 1:05 pm Post subject: One Noisy Mag |
Bob, should all aircraft have these magneto filters? What is the criteria and what is the recommended choice?
On Fri, Aug 12, 2011 at 12:59 PM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
[quote]--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
--> AeroElectric-List message posted by: "stearman456" <warbirds(at)shaw.ca (warbirds(at)shaw.ca)>
good point
other end?
The P leads were shielded wire, probably 16 gauge, and the shields were grounded to the mag cases. Checking the mag switch (AAF A-7 type) I found that the shields were also grounded at the switch. "Aha..." says I. "exactly what Bob said never to do."
Deciding that the P lead itself must be chafed or the shielding was open somewhere I removed both leads and made up two new ones from 18 gauge shielded wire, and carefully added a second wire (not just a pigtail) to connect the shielding to the mag cases on the respective mags.
Okay
Installed them last night, rolled her back outside and... no change! Same quiet right mag/noisy left mag. I couldn't see it being the switch itself but even so I swapped the leads on the switch and the noise followed the lead, so it's not the switch. The only difference I can come up with between the mags is the left mag has the impulse coupling on it (re-read your article about mag switches in the EAA magazine, Bob. Lots of good info there - thanks) but that should have anything at all to do with it.
Good deduction
robustness.
doing its job.
well.
http://www.matronics.com/Navigator================================================
http://forums.m====================== -Matt Dralle, List Admin.
Posted: Sun Aug 14, 2011 1:32 pm Post subject: One Noisy Mag |
At 04:01 PM 8/14/2011, you wrote:
Quote: | Bob, should all aircraft have these magneto filters? What is the criteria and what is the recommended choice? |
If you got an ignition system noise you don't
like you may need a filter. It depends on the
propagation mode of the particular installation.
But if you have no noises, then there's no
value in adding a filter.
Nearly all aircraft flying ADF or Loran will have
magneto p-lead filters. A portion of other aircraft
will have them for reasons of demonstrated value.
Many are flying happily without them.
(o o)
===========o00o=(_)=o00o=========
< Go ahead, make my day . . . >
< show me where I'm wrong. >
[/b] [quote][b]
raymondj(at)frontiernet.n Guest
Posted: Sun Aug 14, 2011 3:31 pm Post subject: One Noisy Mag |
Bob,
Sorry to say, you won't find any aircraft flying LORAN these days.
Raymond Julian
Kettle River, MN
"And you know that I could have me a million more friends,
and all I'd have to lose is my point of view." - John Prine
(o o)
Posted: Sun Aug 14, 2011 6:37 pm Post subject: One Noisy Mag |
At 06:27 PM 8/14/2011, you wrote:
Quote: |
Bob,
Yeah, too bad. A single receiver set up to receive
both LORAN and GPS along with the appropriate filter
software could have provided the ultimate navigation
reference. GPS works good when there are thunderstorms
and no sunspots, LORAN works good when GPS is degraded.
Further, it was harder to jam and a whole lot less expensive
to build and maintain. But then, folks who know more about
airplanes than we do must know best.
