Fuel tank vents
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pulsar-List
rockford67
PostPosted: Mon Aug 15, 2011 4:49 pm    Post subject: Fuel tank vents Reply with quote
Hey Pulsar owners
Ran into a guy today who worked on my plane before I bought it and h told me I had a fuel problem.
Seems one of the vent lines was blocked They tried to poke through as far as they could but couldn't get to the blockage. So... Now what? He seemed to think putting in a new vent was better than ripping open the wing - I agree!
What about a vented fuel cap? Thoughts? Suggestions?
Chris
- The Matronics Pulsar-List Email Forum -
http://www.matronics.com/Navigator?Pulsar-List
mortweaver(at)sbcglobal.n
PostPosted: Mon Aug 15, 2011 5:57 pm    Post subject: Fuel tank vents Reply with quote
Have you already tried clearing the line with high air pressure...like 80-100 lbs? Depending on the location of your fuel filler cap, the opening may be opposite and close to where the vent line enters the top of your fuel tank. If need be, I can with the aid of an inspection mirror, reverse feed a small diameter stiff wire through a wing fuel filler opening into the vent line on my XP. Hopefully your blockage is not in one of the 90 degree bends near the wing tip. You may very well have an insect that has swelled after contact with fuel and is creating a rigid blockage. I would go to the trouble of making an adapter to insert through the wing fuel filler where the pointed tip could be held firmly on the end of the vent tube and high pressure air be applied to blow back through the line. Good luck.
Dave Weaver
--- On Mon, 8/15/11, rockford67 <cphorsten(at)yahoo.ca> wrote:
Subject: Fuel tank vents
To: pulsar-list(at)matronics.com
Date: Monday, August 15, 2011, 7:49 PM
--> Pulsar-List message posted by: "rockford67" <cphorsten(at)yahoo.ca (cphorsten(at)yahoo.ca)>
Hey Pulsar owners
Chris
http://forums.matronics.com/viewtopic.php?p=349568#349568
http://www.matronics.com/Navigator?Pulsar-; - MATRONICS WEB FORUMS -http://www.matronics.com==================
rockford67
PostPosted: Mon Aug 15, 2011 6:09 pm    Post subject: Re: Fuel tank vents Reply with quote
Thanks Dave... I'm not sure how they tried to release the blockage. All he said was they tried to reach it but came up against a wall. Whether that was a bend in the line or the actual blockage I don't know, and I take it they pushed from the outside in. I've had a mud dauber block up my pito tube on my cessna. Pain in the but!
I take it you've had a similar experience. I'm going to get a mirror and see what I can see inside the tank. Wouldn't all the vent lines be in the same place?
Chris
leubanks(at)sunflower.com
PostPosted: Mon Aug 15, 2011 7:46 pm    Post subject: Fuel tank vents Reply with quote
Just a suggestion but I once cleared a fuel vent on a Pulsar using a guitar
string. Those are very flexible and made it through the bends that went into
the fuselage tank. I pushed while turning it by hand and it cleared out a
plug that was restricting the vent inside the tank. I think that I also
modified the end of the string so that it had a slight cutting edge to it.
Larry Eubanks
kymc(at)internode.on.net
PostPosted: Mon Aug 15, 2011 8:40 pm    Post subject: Fuel tank vents Reply with quote
Once you have the blockage cleared a neat trick to stop it happening again is to use a split pin slightly smaller than the vent tube - just put a small kink in one side of the pin so that it stays in the vent tube. Put a ribbon on it to remind you to remove before flight but if you do forget air can still get past the pin so you won't collapse your tank.
Stops any insects from getting and also does not create "bad" things from happening if you forget. I use that method and works just fine.
As far as getting the blockage out try getting some very small flexible cable from a hardware place and feed in while turning.
cheers
Kym
Australia
On 16/08/2011, at 1:14 PM, Larry Eubanks wrote:
Just a suggestion but I once cleared a fuel vent on a Pulsar using a guitar string. Those are very flexible and made it through the bends that went into the fuselage tank. I pushed while turning it by hand and it cleared out a plug that was restricting the vent inside the tank. I think that I also modified the end of the string so that it had a slight cutting edge to it.
Larry Eubanks
gregsmi
PostPosted: Tue Aug 16, 2011 4:50 am    Post subject: Fuel tank vents Reply with quote
Larry, we finally know why your guitar sounds a little sharp.
Let's go flying.
Greg
In a message dated 8/15/2011 10:46:21 P.M. Central Daylight Time, leubanks(at)sunflower.com writes:
--> Pulsar-List message posted by: "Larry Eubanks" <leubanks(at)sunflower.com>
Larry Eubanks the ies ay - MATRONICS WEB FORUMS - List Contribution Web Site p;
kelly.p.crowley(at)boeing
PostPosted: Tue Aug 16, 2011 5:31 am    Post subject: Fuel tank vents Reply with quote
LOL. That was funny!
From: GREGSMI(at)aol.com [mailto:GREGSMI(at)aol.com]
Sent: Tuesday, August 16, 2011 07:49 AM
To: pulsar-list(at)matronics.com <pulsar-list(at)matronics.com>
Subject: Re: Pulsar-List: Fuel tank vents
Let's go flying.
Greg
PostPosted: Tue Aug 16, 2011 5:46 am    Post subject: Fuel tank vents Reply with quote
Maybe if I had a real guitar instead of just one string it might sound better too. This is real boring. plunk plunk plunk plunk plunk plunk plunk. I wrote that song myself though.
I'll fly if the weather gets a little calmer. Gusts to 25 today!
Larry
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pulsar-List All times are GMT - 8 Hours
