Jabiru Voltage Regulator Wires Mislabeled?
messydeer
PostPosted: Tue Aug 23, 2011 9:20 am    Post subject: Jabiru Voltage Regulator Wires Mislabeled? Reply with quote
Hello:
I noticed my voltage regulator for my Jabiru 3300 has the red and yellow wires in different places than what the Jab schematic says. The schematic, taken from the Jabiru manual, says the top 3 wires in the plug are pale blue, black, and pale blue, in positions 1, 2 and 3 respectively. That agrees with my plug. But Jabiru says the bottom 3 wires are green (4), yellow (5), and red (6) whereas my voltage regulator has red in the #4 position, and green in the #6 position.
I'm assuming I should go by the colors of the wires, figuring they either mislabeled the schematic, or inserted the wrong wires in the plug. I have long since removed this plug and replaced it with fast on terminals. Pic of this with the schematic is attached.
PS: (edit) It was pointed out that I was looking at the back of the plug and not the front. Viewing from the front makes everything work out fine. No mislabeling.
Jabiru voltage regulator schematic vs my regulator.pdf
 Filename:  Jabiru voltage regulator schematic vs my regulator.pdf
 Filesize:  1.02 MB
 Downloaded:  414 Time(s)
Dan
