		| Author | Message |
		| asarangan(at)gmail.com Guest
				|  Posted: Sun Aug 28, 2011 8:10 am    Post subject: Tufnol bearings clearances |   |
				| Looking through the email archives, the alignment of the front and
rear tufnol bearings/bushings with the aileron torque tube appears to
 be a critical step in preventing control stiffness.
 There are no specific guidelines about this on the manual. I am mostly
 concerned about thermal expansion since the cockpit can see 70C
 difference from summer to winter. The torque tube is about 24" long
 and looks like zinc plated steel. For 70C, the thermal expansion will
 be about 22 mils. So I am thinking I need to insert 12mil shims on
 either side of the tufnol bearing before bonding the fork and the
 bushing, and then removing it after cure.
 Then there is also the question of tufnol expansion due to moisture.
 There is a chart on tufnol.com on how much tolerance should be allowed
 for water absorption. This is for prolonged immersion so it can be
 considered a worst case scenario. For the 1/2" bearing, this
 translates to about 0.8mm, or about 32mils.
 So putting both factors together, I am thinking of inserting 25mil
 shims on both side of the tufnol, for a total of 50mil play. Does this
 sound right?
 All of this could turn out to be a moot point if the flex in the
 cockpit module is a greater factor.
 Comments are welcome.
		| Back to top |  |
		| grahamsingleton(at)btinte Guest
				|  Posted: Sun Aug 28, 2011 2:47 pm    Post subject: Tufnol bearings clearances |   |
				| Andrew
You are right about the problems of thermal expansion etc. I had a problem due to the clearances being too close. Going from a warm hangar to cold air (flying) the roll control stiffened up, due to the aluminum contracting quickly and the rest of the airframe  slowly.  After an hour the controls had loosened up again.
 Graham
 To: Europa List <europa-list(at)matronics.com>
 Sent: Sunday, 28 August,  2011 17:07:32
 Subject: Tufnol bearings clearances
 --> Europa-List message posted by: Andrew Sarangan <asarangan(at)gmail.com (asarangan(at)gmail.com)>
 sound right?
 cockpit module is a greSearch & Download, 7-Day Browse, Chat, gt; http://forums.matronics.com
 _;                   -Matt Dralcontribution" =======
		| Back to top |  |
