				 Posted: Wed Aug 31, 2011 6:48 pm    Post subject: Precision Airmotive fuel injection - flow divider and the ca |
				I have the Precision Airmotive EX-5VA1 fuel injector.  The flow divider
 on  top of the engine has a nozzle with a cap on it.  At this point, I
 don't know it's function but at some point, someone I trusted told me
 that the little black cap on the nozzle should be removed.
 I noticed that there is a blue fuel stain around that area and am now
 wondering about the function of the nozzle (vent), whether it should be
 capped, etc.
 I see a mechanic tomorrow for some consultation but would welcome any
 insight.
 PS, I'm thinking very seriously of attending the Airflow Performance
 fuel injection class to get a little smarter about the system and to
 tune for lean of peak.  Anyone done this?  Worthwhile?
 Bill Watson
		rleffler
				 Posted: Thu Sep 01, 2011 1:44 am    Post subject: Precision Airmotive fuel injection - flow divider and the ca |
				I haven't attended, but everyone I've talked to that had attended, spoke
 very highly of both Don and the class.  The other advantage is that you have
 an opportunity to get your injection system balanced.  I am planning on
 attending as soon as I'm flying.
 Bob (disappointed Bill stopped his comments in his signature)
  _________________ Bob Leffler
N410BL - Phase I
		Space Cadet
				 Posted: Thu Sep 01, 2011 6:38 am    Post subject: Re: Precision Airmotive fuel injection - flow divider and th |
				I'm pretty sure that "nozzle" is the same as in my standard set-up, and it's a fuel pressure pick-off point.  Since Van's pulls that closer to the pump on their setup, that should be capped off permanently (AN fitting).
 Dwight
		rv10flyer
				 Posted: Thu Sep 01, 2011 3:31 pm    Post subject: Re: Precision Airmotive fuel injection - flow divider and th |
				That port is for measuring fuel pres like Dwight said. Fuel pres at this point is converted to fuel flow in some applications. If you have a new Lyc you had to remove an 1/8" plug, just use that to plug this hole. Use appropriate sealant.
  _________________ Wayne G. |
		AirMike
				 Posted: Fri Sep 02, 2011 6:42 am    Post subject: Precision Airmotive fuel injection - flow divider and LOP |
				Lean of peak - is that the procedure where one converts fuel savings into profits for cylinder/valve manufacturers ?
  _________________ See you OSH '18
Q/B - sold. |
				 Posted: Fri Sep 02, 2011 7:11 am    Post subject: Precision Airmotive fuel injection - flow divider and the ca |
				No, Lean of Peak is the procedure where one converts profits for Oil Companies into more flying time for RV-10 owners.  It's a really cool process!
 Jesse Saint
 Saint Aviation, Inc.
 jesse(at)saintaviation.com
 C: 352-427-0285
 F: 815-377-3694
		arplnplt(at)gmail.com Guest
				 Posted: Fri Sep 02, 2011 9:45 am    Post subject: Precision Airmotive fuel injection - flow divider and the ca |
				Actually it's the opposite.
 David Leikam
 RV10
 Flying
