Kellym
Posted: Sat Sep 10, 2011 5:55 am Post subject: Transponder troubles |
Had strange occurrence with Salt Lake Approach yesterday. Initially,
when they said they couldn't see my transponder, I had a reply light.
Then they said they could see a 1200 code from it, not the 0363
assigned that I had dialed in. A bit later they saw the correct code,
and it continued to be okay until out of their airspace. Now I
departed the Phoenix area the day before, communicating with 2 radar
equipped towers that had no complaints on my transponder and were
giving me radar traffic callouts, so I know it was working. Not sure
how a transponder could possibly put out a 1200 code when set to
something else, and then revert to sending the selected code. I could
see one or two digits being wrong, but the whole code? I could only
think they had a weak signal, but checked after I landed and antenna
was clean. I guess I can check the coax connection, and reseat the
unit in its tray, but would rather not have to spend for an
unnecessary bench check. It is an old model with cavity tube, but has
been rock solid since it was aligned 8 yrs ago, passing every biennial
check. Any other thoughts?
| - The Matronics Avionics-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
KCHD |
fherr(at)cfl.rr.com Guest
Posted: Sat Sep 10, 2011 8:12 am Post subject: Transponder troubles |
Maybe there was another plane close by you (confusion by approach) or morse likely the controller simply messed up?
I would wait and see or run it over a few towered airports before I would do anything drastic.
My 2 cents
Francis
at6c(at)bellsouth.net Guest
Posted: Sat Sep 10, 2011 8:19 am Post subject: Transponder troubles |
It's ATC problem. I have had the same issue with ATC on a number of
occasions, if one radar site has a problem and nobody else does I wouldn't
be in a hurry to get to the repair shop.
George
Posted: Sat Sep 10, 2011 9:49 am Post subject: Transponder troubles |
Another + for it being an ATC problem. One of my neighbors used to fly
all over the central & southeast USA, & whenever he (and others) would
fly through Memphis airspace ATC would tell them that their transponder
wasn't working properly (no altitude, incorrect altitude, etc etc). The
various transponders seemed to work fine around other class B/C
airspace, & all had problems whenever they entered Memphis airspace.
Charlie
peteohms
Posted: Sat Sep 10, 2011 12:55 pm Post subject: Transponder troubles |
Not saying this happened to you but my transponder transmitted the wrong
code once. A tech told me to turn the knobs once in awhile because they
can develop a dirty contact since I fly around on 1200 all the time.
Pete
_________________ Pete
Leander, TX
Kitfox III, 912ul, Grove |
wjrhamilton(at)optusnet.c Guest
Posted: Sun Sep 11, 2011 4:33 pm Post subject: Transponder troubles |
Kelly,
What kind of transponder?
Cheers,
Bill Hamilton
Pete
McMullen<kellym(at)aviating.com>
Kellym
Posted: Sun Sep 11, 2011 4:53 pm Post subject: Transponder troubles |
A Narco AT-50.
On 9/11/2011 6:29 PM, William J Hamilton wrote:
Quote: |
Kelly,
Cheers,
Bill Hamilton
KCHD |
Posted: Sun Sep 11, 2011 8:03 pm Post subject: Transponder troubles |
Kelly,
The reason I asked is that, down here in AU, we have seen some interesting problems with early King transponders, including transmitting codes other than that selected, and incorrect Mode C replies.
Some are now subject to to an AD, which effectively means replacement, but I have not heard of any similar problems with Narco.
Cheers,
Bill Hamilton
Quote: | Kelly McMullen <kellym(at)aviating.com> wrote:
A Narco AT-50.
Quote: |
Kelly,
Cheers,
Bill Hamilton
