building a batter capacity tester
Michael Wynn
PostPosted: Sun Sep 11, 2011 1:56 pm    Post subject: building a batter capacity tester Reply with quote
I have been following the PC680 thread with great interest. I have a couple for my RV8 that have been sitting around longer than I had meant for them to sit. You know how construction goes.
I was going to build the capacity tester from the aeroelectric site:
http://www.aeroelectric.com/articles/battest.pdf
This looks pretty straightforward and I assume that I can get all the components from my local Radio Shack. The one thing I am foggy on is the 10 V. Zener diode in the schematic. Never having used these, are they sold by voltage or amperage or what. Specifically, how do I make sure I get the correct component?
Michael Wynn
RV 8 Wiring
San Ramon, CA
In a message dated 9/11/2011 12:09:07 P.M. Pacific Daylight Time, paulm(at)olypen.com writes:
[quote]--> AeroElectric-List message posted by: "Paul" <paulm(at)olypen.com>
Michael Wynn
RV 8
San Ramon, CA
retasker(at)optonline.net
PostPosted: Sun Sep 11, 2011 7:14 pm    Post subject: building a batter capacity tester Reply with quote
Pretty much any 10V zener diode will work there. Zeners are sold by voltage since that is their purpose (to control the voltage across their terminals). The other thing that is important is the
wattage rating, although in this case the power dissipated by the zener is so low (50mW) that any 10V zener you can buy will work.
Dick Tasker
MLWynn(at)aol.com wrote:
[quote] I have been following the PC680 thread with great interest. I have a couple for my RV8 that have been sitting around longer than I had meant for them to sit. You know how construction goes.
Michael Wynn
RV 8 Wiring
San Ramon, CA
Mauledriver(at)nc.rr.com
PostPosted: Mon Sep 12, 2011 2:52 am    Post subject: building a batter capacity tester Reply with quote
Just a quick update on my PC680 odyssey.... while 1 battery was beyond hope, 2 that I had removed for poor performance recovered enough to pass the minimum test as defined by the manufacturer -
>12.65 volts with no load,
> 9.6 volts (at)70F with 120amp load for 15 seconds
My oldest battery, a3+ year old Odyssey PC680 that has only been trickled charged, tests at 12.89volts with no load and 10.8 volts at end of load test.
A 'new' battery a neighbor gave me, the certified version of the PC680, 13.18 with no load and 10.0 volts at end of test
How did they recover? A couple of charges/discharges with a 10amp Schumacher charger (model XC10).
The 2 batteries I have installed in my '10 have 'recovered' too. Though I haven't had a chance to test them with the HF tester recently, batt1 has been discharged with extensive panel work and batt2 has given me 10+ starts. They've been charged on a number of 1 & 2 hour flights. They now both perform almost as desired, i.e. batt1 will run my panel for extended periods without losing the 3 GRTs due to low voltage, batt2 gets thru the first compression stroke on the first try... sometimes just barely and it is certainly not 'snappy'.
I can run with what I have for now. Cold weather may change things. My sense is that 1 or 2 fresh batteries will give me what I want in the end. A different starter may still be desirable for better starts in cold conditions.
PS - the certified version of the 680 labled "PowerSafe - SBS J16 from Enersys" seems to perform differently. Though it is physically identical except for color, it appears to have different characteristics under load. Not necessarily better.
Bill "smiling ear to ear with the new OBAM plane" Watson
On 9/11/2011 5:50 PM, MLWynn(at)aol.com (MLWynn(at)aol.com) wrote: [quote] I have been following the PC680 thread with great interest. I have a couple for my RV8 that have been sitting around longer than I had meant for them to sit. You know how construction goes.
Michael Wynn
RV 8 Wiring
San Ramon, CA
In a message dated 9/11/2011 12:09:07 P.M. Pacific Daylight Time, paulm(at)olypen.com (paulm(at)olypen.com) writes:
[quote]--> AeroElectric-List message posted by: "Paul" <paulm(at)olypen.com> (paulm(at)olypen.com)
PostPosted: Mon Sep 12, 2011 5:31 am    Post subject: building a batter capacity tester Reply with quote
Keep in mind that this is more of a battery
bench-marker as opposed to a quantitative
tester.
A battery's ability to deliver energy depends
on size, condition, temperature and load. A
battery 'rated' at 20AH will deliver that amount
of output when new and generally under a very
light load compared to how you intend to used it.
Consider the exemplar plot below
[img]cid:.0[/img]
This battery is 'rated' at 17 a.h. But it will
deliver that output only when loaded at .85A x
20 hours = 17 a.h. Your airplane's endurance
loads are more likely to be on the order of 4A
so you can expect about 3 hours of service or
12.75 a.h. of output. Of course, this is an as-new
performance value. You'll want to size and maintain
your battery to meed design goals when the battery
has just degraded to the point of needing replacement.
For most folks this is at 75 or 80% of new capacity.
So this particular battery could be used in a system
where endurance expectations are for 2 hours of
service at 4.25A.
The battery cap tester depicted in the book is
not intended to give you an accurate reading of
the battery's capacity. What it will do is let
you know when the battery has fallen so far below
its as-new condition as to require replacement.
If your new battery ran your exemplar load for say
200 minutes, then you would benchmark the replacement
at 150 minutes.
If you'd like to get real numbers at loads matching
your system's requirements, you'll need something like
http://www.westmountainradio.com/product_info.php?products_id=cba3&navcode=/cbaLink1
I've got a couple of these critters. They were used
to produce the plots like these
http://www.aeroelectric.com/Pictures/Curves/HF_aa_vs_Duracell.jpg
http://www.aeroelectric.com/Pictures/Curves/El-Cheeso_Battery_Test_3.jpg
The device can also be used as a voltage versus time
data acquisition system and get you information like
this.
http://www.aeroelectric.com/Pictures/Curves/schumacher_3.jpg
I would not discourage you from building the po' boy's
cap-checker. It's a useful tool within its limitations.
Radio Shack won't have a 10v zener. You'll have to get
it from a supplier with a broader range of product offerings.
I'll be back in my shop later today. Let me see if I've
got one in drawer I can send you.
 Filesize:  198.58 KB
 Viewed:  4590 Time(s)
Michael Wynn
PostPosted: Wed Sep 14, 2011 9:54 pm    Post subject: building a batter capacity tester Reply with quote
Hey Bob,
I was looking over the specs on the West Mountain battery analyzer you mentioned:
This is a very elegant piece of equipment. The information that it provides is certainly several magnitudes of more exact than the poor man's bench tester I was thinking to build. Further, it seems like something that my EAA chapter could put to more regular use than I would on my own. It is more than it would cost me to build the other, but not ridiculously expensive. Thank you for the direction.
With this piece of equipment, would there be any reason to also have a carbon pile load tester? Harbor Freight has one on sale for $49.95. It seems to me that I would get much more useful data from the West Mountain unit and could save on that expense.
Michael Wynn
RV 8 Wiring
San Ramon, CA
In a message dated 9/12/2011 6:32:41 A.M. Pacific Daylight Time, nuckolls.bob(at)aeroelectric.com writes:
tester.
service at 4.25A.
at 150 minutes.
this.
Michael Wynn
RV 8
San Ramon, CA
PostPosted: Thu Sep 15, 2011 6:09 am    Post subject: building a batter capacity tester Reply with quote
Subject: Re: building a batter capacity tester
Hey Bob,
Yeah, those are a really good value. I have two
of them. I wish they were a little more robust . . .
say good for 10+ amps while testing a 12v battery
but I HAVE used them to gather a lot of good data.
It was a couple of years into my ownership that it
suddenly occurred to me that they could be used for
long term voltage monitoring and plotting.
Set it up to 'test' a battery with a 0.01 amp
load and a very low 'cutoff voltage' then hook
the test leads to the source being monitored.
BOTH devices are useful for different reasons. But
they can be used together too.
LOAD testing is measure of a battery's internal
impedance . . . I.e. ability to carry a large load.
CAP testing is a measure of available energy at
the terminals under various loads . . . where
we know that useful energy is adversely influenced
by internal impedance. There's more than enough
ENERGY in a couple of alkaline lantern batteries
to start an engine and the West Mountain Radio
device would confirm that assertion. Problem is
that a string of "F-cells" wont dump that energy
at 200+ amps.
Your load tester can be used to check your car's
alternator too. Hook a voltmeter to the alternator's
b-lead terminal while putting a load on the battery
equal to the alternator's rated output with the engine
rpms above 2000 or so. The drop should be nominal . . .
perhaps 0.5 volts max. It might even go UP a bit!
The WMR cap tester will characterize your battery's
ability to support endurance loads for an interval
set my your design goals. The load tester cannot
measure or even help predict that.
I considered doing a kit product consisting of a
USB linked micro-controller and a really FAT mos-fet
but with no heat-sink. Modern computers have a really
great CPU heatsink and fan assembly that one can acquire
from dead computers. A bill of materials for the
hardware is about $15.00.
The hardware is simple . . . the software for
a graphical user interface and data plotting
is a significant task that I just don't have
time to address. If anyone out there is really
whippy in Visual C or some similarly capable
language, we might consider a joint venture
to offer a kit for a DIY cap meter with some
really nice features.
Bob . . . [quote][b]
