		Francois Davel
				 Posted: Sun Oct 02, 2011 9:15 pm    Post subject: Yak 18T prop |
				Hi there Friends
 My prop is coming up for overhaul, and it will have to go to the guys here in South Africa, there is only one place that will do it....the sad news, I have heard of hassles being had after the overhaul....
 I am wondering what are the tricks to this overhaul? are the seals very specific? Is there anything that needs to be checked on before and after the work is done so I can be sure that the work has been done correctly!
 Cheers and thanks
 Francois Howick South Africa
  _________________ Round Engines RULE! |
		CD 2.0
				 Posted: Sun Oct 02, 2011 9:23 pm    Post subject: Re: Yak 18T prop |
				Francois.... what propeller and aircraft models are you referring to?
 This would help to provide a more specific answer to your question.
 Carl
  	  | Francois Davel wrote: | 	 		  Hi there Friends
 Cheers and thanks
 Francois Howick South Africa |
		Francois Davel
				 Posted: Mon Oct 03, 2011 2:22 am    Post subject: Re: Yak 18T prop |
				Hi there, my apologies.....it is the standard 2 blade wooden prop.
 My Prop log book says model V530TA-D35
 Cheers
 Francois
		cjpilot710(at)aol.com Guest
		GeorgeCoy
				 Posted: Mon Oct 03, 2011 4:21 am    Post subject: Yak 18T prop |
				We have hub parts including new seals, piston assemblies, cylinder dome
 assemblies, pitch change blocks and thrust bearings in stock if needed.
				 Posted: Mon Oct 03, 2011 8:40 am    Post subject: Yak 18T prop |
				Pappy,
 The Contact name at Aerostar is Christian Dragori. I have lost his #’s though.
 Doc
 From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of cjpilot710(at)aol.com
 Sent: Monday, October 03, 2011 6:54 AM
 To: yak-list(at)matronics.com
 Subject: Re: Re: Yak 18T prop
 Hope they don't put the "V" seals in backwards!!
 Pappy
				 Posted: Mon Oct 03, 2011 9:48 am    Post subject: Yak 18T prop |
				For those that are wanting to do this, it is a simple fabrication. The
 nose case must have the left side (as seen from the cockpit) round
 access panel. Usually found on Series II engines. But not always
 associated with Series II.
 Obtain a piece of clear Plexiglas, 1/4" thick, large enough to cover the
 opening in the nose case when the round access panel is removed. Cut the
 Plexiglas to size and secure it to the nose case with the screws/bolts
 removed from the metal access panel. You will need a new gasket. That's it.
 Dennis
 A. Dennis Savarese
 334-285-6263
 334-546-8182 (cell)
 Skype: Yakguy1
 www.yak-52.com
 On 10/3/2011 11:37 AM, Roger Kemp M.D. wrote:
  Pappy,
  though.
  Doc
  [mailto:owner-yak-list-server(at)matronics.com] *On Behalf Of
  *cjpilot710(at)aol.com
  *Sent:* Monday, October 03, 2011 6:54 AM
  *To:* yak-list(at)matronics.com
  *Subject:* Re: Re: Yak 18T prop
  Pappy
		pfstelwagon(at)earthlink. Guest
				 Posted: Mon Oct 03, 2011 3:44 pm    Post subject: Yak 18T prop |
				Great idea, but I think I would use Lexan- a lot  tougher.  TAP Plastic shops usually have small pieces.
  Frank  CJ-6A
				 Posted: Mon Oct 03, 2011 4:13 pm    Post subject: Yak 18T prop |
				Agree.
 A. Dennis Savarese
 334-285-6263
 334-546-8182 (cell)
 Skype: Yakguy1
 www.yak-52.com
 On 10/3/2011 6:41 PM, Frank Stelwagon wrote:
  	  | Quote: | 	 		   Great idea, but I think I would use Lexan- a lot tougher.  TAP Plastic
  Frank  CJ-6A
		CD 2.0
				 Posted: Mon Oct 03, 2011 5:23 pm    Post subject: Re: Yak 18T prop |
				Francois, sorry I didn't realize you mentioned the name of the aircraft in the title of the thread.
 Have you considered the option of doing the overhaul overseas and then just installing the finished product in SA? Just PM you some detailed info that should be quite helpful if you consider that option.
 Carl
  	  | Francois Davel wrote: | 	 		  Hi there, my apologies.....it is the standard 2 blade wooden prop.
 Cheers
 Francois |
