lgold(at)quantum-associat Guest
Posted: Fri Oct 07, 2011 10:47 am Post subject: Electric aircraft issues |
Bob, or anyone else out there in Aeroelectric land with Li-Ion battery knowledge,
I have started to build, what I hope will be, an electric aircraft. The kit, a Cumulus motor glider, with a 20:1 glide ratio is ideal, and I have non-explosive A123 batteries. The 560 batteries, 25HP/100V electric motor, and controller should weigh in about the same as and fly as long as it would with the prescribed Rotax engine. With a potential to fly about 2000 cycles (read 2000 flights), these batteries will cost about 20% of the cost of mogas… if I can figure out how to configure the batteries and charge them properly.
I could use a lot of advice regarding the battery pack architecture, charging, and maintaining these Li-Ion batteries. I need to know how to weld or solder the batteries into packs (I am thinking 32 packs places in series; each pack having 16 or 17 cells in parallel). I need to find an inexpensive way to charge them (I am thinking I could charge the 8 packs at a time; 30V (at) 50A for up to 45 minutes) but need to understand more about charging and balancing.
A123 won’t give me the time of day since they changed their focus to sell batteries only to auto manufacturers so any words of wisdom would be helpful.
Les
Posted: Fri Oct 07, 2011 12:39 pm Post subject: Electric aircraft issues |
Les
I wish that the bright light at the end of
the tunnel was not an oncoming train.
There has been an intense interest in lighter/
more energetic batteries for aircraft since
Cessna bolted batteries and generators to the
C-140 many moons ago.
There have been some fits and starts on lithium
devices with mixed results. There ARE lithium
products flying on a number of air transport
category aircraft. Until a short time ago,
Cessna had sold several Citations with lithium
starting batteries aboard. Cessna had invested
mucho bux in a development program that for all
intents and purposes, produced an airworthy
product. Then we have these two documents:
SL525C-24-02A-R01
SB525C-24-05
The background on these publications seems to
stand on a battery fire in a factory airplane
that caused extensive damage and was difficult
to control.
It seems that the battery monitoring system may
have failed to predict and warn against a 'normal'
recharge of a badly depleted battery. Hence an
field investigation into software issues. The
other document speaks to what's necessary to replace
a lithium battery with either lead-acid or ni-cad
with only a logbook entry. This document does
not speak to a Cessna program that proposes to replace
all lithium products from the field.
I'm not ready to recommend that anyone bolt
a lithium device to their airplane. When the
big guys are stubbing their toes in spectacular
ways, I think it unwise to think that we are
well advised to expand a technology (that
is still an experiment) into our fun machines.
By the way, I think the cells involved in the
battery fire were the Lithium Iron devices from
A123. The fat lady hasn't even been handed the
sheet music much less received a curtain call.
I'll continue to track this series of events.
It sound like you'd like to be involved in the
development of a next generation aircraft. There
are a number of good texts on battery management.
I'll see if I can get some titles and sources
for you.
handainc(at)madisoncounty Guest
Posted: Fri Oct 07, 2011 1:08 pm Post subject: Electric aircraft issues |
I'd be interested in information about building battery packs and
welding or soldering those batteries into battery packs. I just bought a
Li-on pack for my CPAP machine - $359! I'd love to try building my own
battery pack for a couple of purposes if I can do so safely and gain
some education.
M. Haught
On 10/7/2011 3:34 PM, Robert L. Nuckolls, III wrote:
<nuckolls.bob(at)aeroelectric.com>
knowledge,
be helpful.
Les
SL525C-24-02A-R01
SB525C-24-05
to control.
for you.
H.Marvin Haught Jr.
Haught& Associates, Inc
Huntsville, AR 72740
Posted: Fri Oct 07, 2011 1:41 pm Post subject: Electric aircraft issues |
I'm thinking that getting to the team is working on Monnett's Waiex project would be where some of the most current and directly applied knowledge could be found.
On 10/7/2011 2:43 PM, Les Goldner wrote: [quote] <![endif]--> <![endif]-->
Les
sportav8r(at)gmail.com Guest
Posted: Fri Oct 07, 2011 3:09 pm Post subject: Electric aircraft issues |
There's a vendor on HFPack who is pretty knowledgable about the A123's as he sells them to hams interested in pedestrian mobile operations - not that he knows anything about aircraft, but he probably has the typical ham operator's willingness to help a fellow experimenter all he can - a lot like Bob N, here
Google it.
-Bill B
On Fri, Oct 7, 2011 at 5:38 PM, Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)> wrote:
[quote] I'm thinking that getting to the team is working on Monnett's Waiex project would be where some of the most current and directly applied knowledge could be found.
On 10/7/2011 2:43 PM, Les Goldner wrote: | Quote: |
Les
ist" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
tp://forums.matronics.com
Posted: Sat Oct 08, 2011 6:57 am Post subject: Electric aircraft issues |
<snip>
| Quote: | Cessna had invested
SL525C-24-02A-R01
SB525C-24-05
I note that my cut-n-paste of these two citations
did not carry the http: links with them. I'm
away from the office but will re-post the
links to these to documents when I get back.
It may well be that there's a bright future for
lithium technology in airplanes. Here's a
supplier of off the shelf devices that has
developed quite a following in the recreational
vehicle and motorcycle markets.
http://www.shoraipower.com/
Their batteries are fitted with special
connectors that service a specialized
charger/cell-balancing accessory. While
not 'required' . . . it's very existence
suggests that these batteries are not
drop-in replacements for lead-acid.
http://www.shoraipower.com/downloads/shoraiLfxInstallGuide.pdf
But as we all know and personally feel,
the worst thing you can experience in
flight is smoke/fire. Cessna thought they
had cracked that nut. Both Cessna and
the FAA were ready to allow these batteries
aboard John Q Public's airplane.
Obviously, there are some issues yet to be
resolved so that probability for a repeat
incident in flight drops to that magic
one-event-per-billion flight hours that the
FAA is so fond of.
The "oncoming train" remark was inappropriate
. . . energy exploitation has evolved from
basking in the sun to burning wood, burning
pig fat/whale oil and upward to splitting
atoms. Each step offered more concentrated
and energetic releases of heat. Each step
also came with elevated risks.
No doubt risk mitigation for the lithium
technologies will eventually prove adequate.
aerobubba(at)earthlink.ne Guest
Posted: Sun Oct 09, 2011 6:12 am Post subject: Electric aircraft issues |
Right off the top of my head, I can think of 3 freighter losses linked to Li batteries. One got on the ground and burned on the runway for about 4 hours, without loss of life. The other two didn't end so well. In all cases, the batteries were palletized for shipping, not even part of an active circuit. You can also google a video of a laptop sitting on the floor at LAX, and watch it erupt. It's pretty spectacular.
FWIW, at least one of the planes in my past was configured with the NiCads outside the primary structure. Absolute worst case, a runaway battery could exit the bottom of the composite blister without doing more grievous harm. I don't think it would have even depressurized the plane.
Something to consider-
Glen Matejcek
Posted: Sun Oct 09, 2011 6:59 am Post subject: Electric aircraft issues |
Which speaks to the evolution of a technology . . .
I recall working a MU2 accident down in TX that
involved a ni-cad battery fire . . . that would
have been in the 70's. We eventually learned how
to live amicably with that technology's worst
traits. Unfortunately, some of the lessons came
with very high costs.
I've not done a detailed study of incidents but
I sense a trend suggesting that the lithium
cells are particularly vulnerable to mischief when
allowed to deeply discharge and are then recharged
with the systems normal power source that is also
capable of running the whole system.
The Shorai folks caution against an energetic
recharge of a deeply depleted battery. The task
of bringing up a dead battery is best accomplished
by their proprietary charger/cell-balancing product.
I wonder if the laptop fire at LAX wasn't produced
in a computer being recharged by a pax during a
stop between planes. Batteries on airplanes tend
to be deeply discharged more often than not . . .
and then the pax hopes to get 'er charged back
up between flights.
So it seems likely that if one chooses to use
the Shorai (or any other product) for an
airplane, it is most likely to perform as advertised
for a cranking battery where the alternator picks
up system loads and replenishes a few percent of
discharge each flight cycle.
If one DOES experience an alternator failure,
then by all means, use what ever energy the battery
contains in carrying out plan-B. Upon reaching the
ground, remove the battery from the airplane for
specialized recharging in a less-risky environment.
The Cessna ramp fire probably involved a disorderly
Jim Berry
Posted: Sun Oct 09, 2011 9:24 am Post subject: Re: Electric aircraft issues |
Bill Dube, who used to post to this site re his LED lights, probably has as much experience as anyone with the A123 batteries. He uses them in his battery powered dragster motorcycle (www.killacycle.com) and Bonneville racer. Search the archives for his take on using & charging these batts.
Jim Berry
RV-10
rparigoris
Posted: Sun Oct 09, 2011 12:36 pm Post subject: Re: Electric aircraft issues |
Hi Bob
You mentioned:
"The Shorai folks caution against an energetic
recharge of a deeply depleted battery."
This is not only true of a Lithium battery, but charging a discharged lead acid battery with a high powered alternator that's trying to maintain a constant voltage (just got aeroplane or car running from a jump start) is not very easy on the battery.
How could one limit the charging amps going into the battery yet still allow the alternator to carry any loads?
Ron P.
Posted: Sun Oct 09, 2011 2:06 pm Post subject: Electric aircraft issues |
On 10/09/2011 03:36 PM, rparigoris wrote:
Hi Bob
You mentioned:
Ron P.
That was my 1st reaction, as well. Achieving it should be as simple (not
to be confused with cheap...) as the alternator feeding a switching
power supply which feeds only the custom charging circuit for the battery.
Posted: Mon Oct 10, 2011 4:02 am Post subject: Electric aircraft issues |
Hi Bob-
| Quote: | I recall working a MU2 accident down in TX that
was that the one involving a runaway battery that severed the pitch control system?
Do Not archive
Glen Matejcek
shenglu
Posted: Tue Oct 11, 2011 6:54 pm Post subject: Re: Electric aircraft issues |
I can think of three ships with lithium loss. One is on the ground, there is no loss of life, burnt down the runway about 4 hours. The other two did not end so well.
_________________ Gadgets | Flash Memory |
Posted: Wed Oct 12, 2011 8:00 am Post subject: Electric aircraft issues |
At 09:54 PM 10/11/2011, you wrote:
Do you know of any Internet stories that describe
these events?
Also, welcome to the AeroElectric-List. Where
are you located? Are you building an airplane?
Posted: Fri Oct 14, 2011 6:50 pm Post subject: Electric aircraft issues |
Bob:
Glen: was that the one involving a runaway battery that severed the pitch control system?
No . . . at least I don't think so. This airplane
used two sets of 24 volt ni-cads that were hooked
in series to get 48 volts to start the engines; then
reconnected in parallel for normal ops. My mentor, Ken
Razak asked me to look at the series-parallel switching
system as a potential root cause of the battery fire.
The pilot got the airplane down on the ground from about
10K onto the grass adjacent to a runway. All souls got
out and the fire crews were able to quickly put out
the fire.
Since the system was behaving normally for a departure
and climb to 10K there was little reason to suspect that
the series-parallel switching system was 'stuck' in an
abnormal condition. But given the paralleled generators
capable of putting many amps into those nice little light
weight batteries, it was far more likely that the battery
array suffered thermal runaway and went into self destruction.
This was the era of before-battery-overheat-monitors.
Some years later, a technician I hired to work with me
in the video business mentioned a burned airplane he helped
restore in Tx. Turns out it was the same MU-2,
Posted: Fri Oct 14, 2011 6:57 pm Post subject: Electric aircraft issues |
Hi Bob
You mentioned: "The Shorai folks caution against an energetic
Ron P.
It's not terribly difficult. We've had generator
regulators that could not only limit the generator's
output current . . . but the can current-balance to
paralleled generators.
It would not be difficult to design a regulator that
would limit re-charge current to the battery. This would
call for a scheduled reduction of bus voltage while the
really beat battery catches it's breath. The voltage
would not be so depressed that it hampered normal system
operations . . . but such a regulator would have prevented
ni-cad fires and eliminated the need to add the battery overheat
monitor to ni-cad fitted airplanes.
Bob . . . [quote][b]
