Naca vents
raimo.toivio(at)rwm.fi
PostPosted: Thu Oct 06, 2011 10:16 am    Post subject: Naca vents Reply with quote
Bob and Pete
They work fine if adjust them just with a bit tender!
It is very easy if same time have a bit imagination that (The Knob) is a sweet clitoris. Do not broke it!
Maybe that (ability to use those Naca vents with Russian vertical spiral) is deep inside in a Finnish nature: we have lived thousands of years just west from Russia and our borderline is about 1000 miles long.
Raimo OH-XRT Finland
PS: if honest during the building phase I hated them. But there were so many things I would have liked to do otherway or change. But I had not competence to do so. And did not want to use even more money. Hey I had a complete aircraft kit they said! So I decided to go on with those vents. And using them gently they have worked just fine. If I remember correct these are new ones – I also did broke them when trying them first time...and that is why I strenghtened them some how – maybe by using large area washers or so.
RT
do archive!
Sent: Thursday, October 06, 2011 5:45 PM
Subject: Re: Ball Joints
Raimo,
On Oct 6, 2011, at 8:58 AM, Raimo Toivio wrote:
One limitation: we call that plastic screw “fucken Russian vertical spiral”. The end stops are weak and will broken easily.
That's why we dislike them. Cheep, crapy, miserable adjustments. They broke the first time I attempted to open/close them (thankfully, before they were installed). And they are not repairable. So they went into the dust bin and I bought outrageously expensive but completely functional vents (Ultimate Ventilators) from ACS.
Bob Borger
Rebuilding the instrument panel and working on a major weight reduction program for The Little Dragon Lady. She has to loose about 50 lbs (that's 3 Stone 8 for you guys in the UK). And the CG has to go back into the middle of the range. A new, light weight, low power, panel along with removal of the big alternator should take care of most of that.
Cel 817-992-1117
max8992
PostPosted: Fri Oct 07, 2011 12:04 am    Post subject: Naca vents Reply with quote
Hi There all,
As French we are used to play with clitoris, but I must admit that I broke one of the green Russian spiral. Has anybody one available? Do you think Europa delivers it (I didn’t ask yet)?
Cheers
Max Cointe
F-PMLH Tri Gear #560
912 ULS Airmaster 400 hours
mcointe(at)free.fr
De : owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] De la part de Raimo Toivio
Envoyé : jeudi 6 octobre 2011 20:13
Ŕ : europa-list(at)matronics.com
Objet : Re: Naca vents
Bob and Pete
RT
do archive!
Raimo,
Bob Borger
Cel 817-992-1117
Max8992
Europa XS #560 F-PMLH
pjeffers(at)talktalk.net
PostPosted: Fri Oct 07, 2011 5:35 am    Post subject: Naca vents Reply with quote
Hi Max,
Europa will probably be able to supply them but they get them from Aircraft Spruce in California.
Pete
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Max Cointe
Sent: 07 October 2011 09:01
Subject: RE: Naca vents
Hi There all,
Cheers
Max Cointe
mcointe(at)free.fr
Bob and Pete
RT
do archive!
Raimo,
Bob Borger
Cel 817-992-1117
http://forums.matronics.com
Checked by AVG - www.avg.com
10/06/11 [quote][b]
kheindl(at)msn.com
PostPosted: Fri Oct 07, 2011 6:40 am    Post subject: Naca vents Reply with quote
The vent mechanism is crap. Mine also broke long before I finished building.For a few dollars ACS supply a repair kit, which is unbreakable.
Karl
Date: Fri, 7 Oct 2011 14:31:40 +0100
.ExternalClass .ecxshape {;} .ExternalClass a:link {;} .ExternalClass span.ecxMSOHYPERLINK {;} .ExternalClass a:visited {;} .ExternalClass span.ecxMSOHYPERLINKFOLLOWED {;} .ExternalClass pre {;} .ExternalClass span.ecxPRFORMATHTMLCAR {;} .ExternalClass p.ecxMsoNormal, .ExternalClass li.ecxMsoNormal, .ExternalClass div.ecxMsoNormal {margin-bottom:.0001pt;font-size:12.0pt;font-family:"Times New Roman";} .ExternalClass a:link, .ExternalClass span.ecxMsoHyperlink {color:blue;text-decoration:underline;} .ExternalClass a:visited, .ExternalClass span.ecxMsoHyperlinkFollowed {color:purple;text-decoration:underline;} .ExternalClass pre {margin-bottom:.0001pt;font-size:10.0pt;font-family:"Courier New";} .ExternalClass span.ecxPrformatHTMLCar {font-family:Consolas;} .ExternalClass p.ecxPrformatHTML, .ExternalClass li.ecxPrformatHTML, .ExternalClass div.ecxPrformatHTML {margin-bottom:.0001pt;font-size:12.0pt;font-family:"Times New Roman";} .ExternalClass span.ecxEmailStyle21 {font-family:Calibri;color:#1F497D;} .ExternalClass span.ecxEmailStyle22 {font-family:Arial;color:navy;} (at)page Section1 {size:612.0pt 792.0pt;} .ExternalClass div.ecxSection1 {page:Section1;}
Hi Max,
Pete
Hi There all,
Cheers
Max Cointe
mcointe(at)free.fr
Objet : Re: Europa-List: Naca vents
Bob and Pete
RT
do archive!
Subject: Re: Europa-List: Ball Joints
Raimo,
Bob Borger
Cel 817-992-1117
   http://www.matronics.com/Navigator?Europa-List http://forums.matronics.com http://www.matronics.com/contribution
10/06/11
AirEupora
PostPosted: Fri Oct 07, 2011 6:54 am    Post subject: Re: Naca vents Reply with quote
The co-pilot's vent broke at the base of the plastic screw the first time I tried to open it after installing it. I used super glue , but there is a small opening when closed. I figured that I'd have to tape over it during the winter months or when I went to 12-13K.
Has anybody coming up with a good fix? I'm going to the paint shop in the next couple of weeks.
tennant
PostPosted: Fri Oct 07, 2011 7:27 am    Post subject: Re: Naca vents Reply with quote
I formed my own NACA vents and ended them at vents that I got from a car scrapyard. I think they are from a Ford Fiesta 1990's vintage.
Fantastic. Robust & lots of air.
I looked at the ones on offer at that time and thought that they were pretty junky & they do not seem to have improved!
Barry
Barry Tennant
D-EHBT
At EDLM - Germany
Trevpond(at)aol.com
PostPosted: Fri Oct 07, 2011 8:10 am    Post subject: Naca vents Reply with quote
Somebody mentioned a repair kit for the vent screw for ACS - any idea of a part number?
Cheers
Trev Pond
G-LINN
In a message dated 07/10/2011 14:35:53 GMT Daylight Time, pjeffers(at)talktalk.net writes:
Hi Max,
Pete
Hi There all,
Cheers
Max Cointe
mcointe(at)free.fr
Ă€ : europa-list(at)matronics.com
Bob and Pete
RT
do archive!
Raimo,
Bob Borger
Cel 817-992-1117
10/06/11
kheindl(at)msn.com
PostPosted: Fri Oct 07, 2011 1:04 pm    Post subject: Naca vents Reply with quote
I can't find a number, it was a long time ago. I don't even see the Naca scoop in the current catlogue.I happen to have a spare set I can let you have, if you are interested.
Cheers ,
Karl
Date: Fri, 7 Oct 2011 12:07:39 -0400
Subject: Re: Naca vents
Cheers
Trev Pond
G-LINN
Hi Max,
Pete
Hi There all,
Cheers
Max Cointe
mcointe(at)free.fr
Bob and Pete
RT
do archive!
Raimo,
Bob Borger
Cel 817-992-1117
10/06/11
trevpond(at)aol.com
PostPosted: Fri Oct 07, 2011 1:48 pm    Post subject: Naca vents Reply with quote
That will be marvellous.
Please email me: trevpond(at)aol.com (trevpond(at)aol.com) with the
Price including postage
Trev
On 7 Oct 2011, at 22:01, Karl Heindl <kheindl(at)msn.com (kheindl(at)msn.com)> wrote:
[quote] I can't find a number, it was a long time ago. I don't even see the Naca scoop in the current catlogue.I happen to have a spare set I can let you have, if you are interested.
Cheers ,
Karl
From: [url=mailto:Trevpond(at)aol.com]Trevpond(at)aol.com (Trevpond(at)aol.com)[/url]
To: [url=mailto:europa-list(at)matronics.com]europa-list(at)matronics.com (europa-list(at)matronics.com)[/url]
Cheers
Trev Pond
G-LINN
In a message dated 07/10/2011 14:35:53 GMT Daylight Time, pjeffers(at)talktalk.net (pjeffers(at)talktalk.net) writes:
Hi Max,
Pete
From: owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com) [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Max Cointe
Hi There all,
Cheers
Max Cointe
mcointe(at)free.fr (mcointe(at)free.fr)
De : owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com) [mailto:owner-europa-list-server(at)matronics.com] De la part de Raimo Toivio
Ă€ : [url=mailto:europa-list(at)matronics.com]europa-list(at)matronics.com (europa-list(at)matronics.com)[/url]
Bob and Pete
RT
do archive!
Raimo,
Bob Borger
Cel 817-992-1117
10/06/11
Remi Guerner
PostPosted: Fri Oct 07, 2011 11:48 pm    Post subject: Re: Naca vents Reply with quote
Hi Guys,
My solution to repair and improve the Naca vents was to remove the shut off system, make a fiberglass conduit and install adjustable aluminium vents.
Works fine. See attached pics.
Remi
F-PGKL
 Filesize:  76.23 KB
 Viewed:  9016 Time(s)
 Filesize:  65.64 KB
PostPosted: Sat Oct 08, 2011 4:27 am    Post subject: Naca vents Reply with quote
Hi Remi,
Nice looking job!
This is a very similar solution to ours. This works well and is a good
adaption of an appallingly unacceptable piece of expensive rubbish.
In the UK we would define this product as 'unfit for purpose' and as such
should be outlawed. (but I suppose it is still being sold)
Pete
roddyeuropa(at)aol.com
PostPosted: Sat Oct 08, 2011 6:51 am    Post subject: Naca vents Reply with quote
Mine too broke first time used them. Here is the repair which I did - now been working for 8 years without problems.
1) take a cs machine screw - like the longer ones used to attach the cowling.
2) countersink one of the large penny washers and attach the screw so you now have a machine screw with a large flat head. I think I welded and ground mine; araldite 420 might do it.
3) get rid of the plastic screw bit and grind/sand where it attaches to the vent flat
4) screw the machine screw into the black knob on the vent casing. It will cut its own thread
5) Put some araldite 420 on the washer/screw head and turn the knob until its is hard against the vent. Let it set and all done.
Roddy
G-IKRK
AirEupora
PostPosted: Mon Oct 17, 2011 6:54 am    Post subject: Re: Naca vents Reply with quote
I tried repairing these NACA vents and the repair has broken. I liked one of the ideals for fixing them from Remi, but the time and effort would have been to much. I'm lazy and want to go flying. I looked at what Roddy did and I liked his ideal, but my knob was to far gone.
I drilled out the knob and took a 10-32 bolt (AN4-6) and using resin and fibers glued the bolt into the knob. I then riveted a nutplate onto an AN-960 washer. I had to grind the edges off to fit in the hole inside of the NACA vent. That was glued too. I also ground down the nutplate to about half its normal length. I left a shoulder on the movable part of the vent where the bolt makes contact so that it would not blown out once I opened it in the air.
The one question I have? Is there enough air pressure on the movable vent to force it open?
