Bob Turner
Posted: Sun Oct 23, 2011 2:42 pm Post subject: Re: Panel Choice |
Kelly,
Actually, if you fly only VFR, there is no requirement for a pitot-static or transponder inspection. Of course, you may not use the transponder, which means no Class B or C, not above 10,000', etc. Which is why I thought maybe I misunderstood Tim's post. Did he mean biannual (which is what he wrote) meaning instrument currency every 6 months? Tim?
_________________ Bob Turner
RV-10 QB |
Strasnuts
Joined: 10 Feb 2009 Posts: 502 Location: Salt Lake City, UT
Posted: Sun Oct 23, 2011 3:04 pm Post subject: Panel Choice |
I actually was adding 700$ that I believe was the cost for the XM package I purchased. 600$ is the g3x bundle.
On Oct 23, 2011, at 17:57, "Bob Turner" <bobturner(at)alum.rpi.edu> wrote:
Just to add on to "apples to apples..."
Don't forget the quoted $1300 includes xm weather (up to $600/yr depending on subscription). I don't think anyone else was including that cost in their discussion.
OTOH: Is anyone NOT doing biennial pitot/static/transponder inspections, as I thought Tim was implying? To not do so would restrict you to below 10,000', 30 nm away from all Class B, and no Class C, areas.
Bob Turner
RV-10 QB
http://forums.matronics.com/viewtopic.php?p=355811#355811
_________________ 40936
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours |
Kelly McMullen
Posted: Sun Oct 23, 2011 3:10 pm Post subject: Panel Choice |
There is if you base like I do under a Mode C veil. I'm well familiar
with the rules.
Anyone know if there is any potential for damage to solid state
pressure sensors used for airspeed in EFIS systems like a mechanical
airspeed can be damaged if you take pressure up to high altitude while
leaving pitot pressure at surface?
On Sun, Oct 23, 2011 at 3:42 PM, Bob Turner <bobturner(at)alum.rpi.edu> wrote:
Kelly,
Bob Turner
RV-10 QB
http://forums.matronics.com/viewtopic.php?p=355817#355817
A&P/IA, EAA Tech Counselor
KCHD |
Posted: Sun Oct 23, 2011 3:27 pm Post subject: Panel Choice |
Kelly,
The EFIS pressure sensors seem to be immune to rapid changes. The guy who does our checks does nothing but static checks--not even repairs, just checks. He says the new stuff can go as fast as the pressure will change. I've seen him slam EFIS around in a way that would bust a mechanical instrument in a heartbeat and it just keeps working, mine included. The hardest part now is disconnecting the mechanical airspeed!
Dave Saylor
AirCrafters
140 Aviation Way
Watsonville, CA 95076
831-722-9141 Shop
831-750-0284 Cell
On Sun, Oct 23, 2011 at 4:08 PM, Kelly McMullen <apilot2(at)gmail.com (apilot2(at)gmail.com)> wrote:
[quote] --> RV10-List message posted by: Kelly McMullen <apilot2(at)gmail.com (apilot2(at)gmail.com)>
with the rules.
On Sun, Oct 23, 2011 at 3:42 PM, Bob Turner <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)> wrote:
> --> RV10-List message posted by: "Bob Turner" <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)>
> Kelly,
> Bob Turner
> RV-10 QB
" target="_blank">http://www.matronics.com/Navigator?RV10-List
MS -
e -
     -Matt Dralle, List Admin.
nukeflyboy
Joined: 05 Jan 2008 Posts: 162 Location: Granbury, TX
Posted: Sun Oct 23, 2011 6:25 pm Post subject: Re: Panel Choice |
There are two different databases which seem to cause confusion. The one required to fly legal IFR is for the 430/530/650/750 or whatever certified navigator you are using. If you fly IFR you can't get around this cost, even for paper.
The other one is just for the backdrop on the moving map in the EFIS. Updates are free from GRT/AFS. With a G650/750 IFR subscription the EFIS moving map updates are free for the G3X. If you have a 430/530 then you pay an additional subscription to update the EFIS.
I do not know the frequency of updates for the moving map in a GRT/AFS system.
_________________ Dave Moore
RV-6 built and sold
RV-10 built and flying |
orchidman
Joined: 10 Jul 2006 Posts: 277 Location: Oklahoma City - KRCE
Posted: Mon Oct 24, 2011 3:24 am Post subject: Re: Panel Choice |
| nukeflyboy wrote: | | I do not know the frequency of updates for the moving map in a GRT/AFS system. |
Not sure about GRT but AFS, the maps are updated every 28 days.
_________________ Gary Blankenbiller
RV10 - # 40674
(N2GB Flying) |
Jim Combs
Joined: 24 Jan 2010 Posts: 141 Location: Lexington, Ky
Posted: Mon Oct 24, 2011 3:47 am Post subject: Panel Choice |
Sean, yes to be fair we all have to pay the darn recurring fees for the data updates. I can see the fees for XM radio, they have to pay to build, launch and fly the satellites. But the other data is (I think) supplied by the FAA. One can download approach plates in PDF form directly from the FAA.Gov website for free. The other data (Airport info, tower data also is from the FAA. So the question I have
is what is the value add from the data suppliers (Garmin, Jepp) that warrants the large expense.
Jim C
D Not Archive
On Sun, Oct 23, 2011 at 7:01 PM, Seano <sean(at)braunandco.com (sean(at)braunandco.com)> wrote:
[quote]--> RV10-List message posted by: Seano <sean(at)braunandco.com (sean(at)braunandco.com)>
On Oct 23, 2011, at 17:57, "Bob Turner" <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)> wrote:
> Bob Turner
> RV-10 QB
le, List Admin.
_________________ RV-10 -> N312F - Flying as of 12/2008 |
Strasnuts
Posted: Mon Oct 24, 2011 5:49 am Post subject: Re: Panel Choice |
I don't think anything warrants the big expense for the data but it is worth it for me to have the G3X.
AOPA supplies the airport directory. The flight charts are geo-referenced and are government. NAVDATA is from Jeppesen and includes N,C,and S America. Obstacles are from Garmin (i believe). SAFETAXI is from government charts and is geo-reference. Terrain is from Garmin and shows N, C, and S America.
I have had absolutely no issues with the G3X/GX Pilot since I wired it and installed it. When I wish it had a certain functions, the next update bundle has it in it plus more options. The cost of the data is high but reliability, ease of use, company history/size and having everything from the same company "talk" to each other is nice in the cockpit and is why I bought the G3X.
Although, I do have a separate D6 for AHRS/Magnetometer back-up.
780 Hours
dmaib@me.com
Joined: 25 Apr 2006 Posts: 455 Location: New Smyrna Beach, Florida
Posted: Mon Oct 24, 2011 6:16 am Post subject: Re: Panel Choice |
| Jim Combs wrote: | � So the question I have
Jim C
[b] |
Simple supply and demand. capitalism at work. So Jim hits it right on the head: why do they get to sell, for profit, data that is generated by taxpayer dollars? Corrupted capitalism??
_________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
Tim Olson
Posted: Mon Oct 24, 2011 6:43 am Post subject: Panel Choice |
Not that I'd EVER want to defend Jeppesen, but, the actual
programming and linking of the approaches, created from
the waypoints the feds have, is actually done by Jepp for
these navigator devices. So that's where the value add
comes in. If you just solely use Government data, all
you'll really have, in electronic form, is a bunch of
waypoints or fixes. Sure, for a VFR pilot, that's fine,
because you'll now have your airport data and some
fixes and intersections, but, it doesn't give you anything
to actually fly an approach USING your system. (i.e.
no coupled approaches) Yes, the feds do this for their
paper charts, but the programming is different for each
navigator device, so Jepp takes the data and builds
the approaches into the various devices required format.
So without Jepp doing that, your options are limited.
Now that said, the Aspen stuff I guess is all done by
Seattle avionics. They use the gov't data to build
the databases for the Aspen stuff and do the approaches
too. Can they do it for other devices? Sure, they
absolutely can. But, they won't, and that's because
they would get sued by Garmin and Jepp if they stepped
on their toes and started doing this for the Garmin
devices. They could do it for systems like the
Chelton system...they still may get sued, but they
would be at a lower risk of that, but then they
have 2 problems....1 is that they take on liability,
and 2 is that they won't make a huge profit on the
effort to make it worthwhile because there aren't that
many systems out there. It takes a certain quantity
of systems to make it worthwhile.
If an individual had the talent, and time, the government
data is available, and by taking countless hours of time,
you could script it so that you could generate an
actual Garmin db out of it if you reverse engineer
the format, but keeping up with the changes on
a 28 day cycle would make it a full time job....so
you probably couldn't do it nationwide without
dedicated staff.
So really, there is value add for people who want to
actually fly IFR, doing coupled approaches. If you
want to go VFR only, it is far less valuable, and
the economical alternative is to do an annual database
update on your EFIS, and use an iPad navigating VFR
and keeping that data current.
On 10/24/2011 9:16 AM, dmaib(at)me.com wrote:
> Jim C
> [b]
Simple supply and demand. capitalism at work. So Jim hits it right on the head: why do they get to sell, for profit, data that is generated by taxpayer dollars? [Evil or Very Mad] Corrupted capitalism??
David Maib
RV-10 #40559
http://forums.matronics.com/viewtopic.php?p=355862#355862
dlm34077(at)q.com Guest
IIRC flying IFR in the big birds requires three independent ways to keep the
dirty side down in IMC. I accomplished this with a Chelton system as primary
and a GRT Sport system as backup. The tie breaker is the Trutrak autopilot
that can with its own solid state gyros ignore all inputs from the EFIS
systems and fly the aircraft independently. The EFIS systems each have their
own single dependency but their dependencies are different. Obviously all
three systems must share in some fashion the primary and backup electrical
system. I buy the Jepp/Chelton updates for the Cheltons for $550 annually;
GRT updates are free and Trutrak has updated my Digiflite software without
charge several times.
Posted: Mon Oct 24, 2011 6:49 am Post subject: Panel Choice |
As a retired IT guy, they can charge what they like to massage the data and
insert it into their hardware. Certainly someone could write something
comparable/compatible and perform the function but why go to the
effort/expense to produce and maintain same?
Bob Turner
Posted: Tue Oct 25, 2011 2:13 pm Post subject: Re: Panel Choice |
Dave,
Your numbers have been bothering me so I went back and looked at my avionics purchases.
I bought almost exactly what you describe as the GRT system (2 displays, 1 air data computer, xm wx, IO-540 engine instruments including fuel flow) for $11.1K minus a 5% discount, or $10.6K - a lot less than you quoted, and comparable with the G3X. Possible differences: I got the standard size, not larger size, displays (+$1.2K for two). I also got an HX and a HS, e.g., synthetic vision on only one display. I couldn't reason the extra $2K for two HX's when the second display is used for engine instruments most of the time.
Something you failed to mention: GRT is the only system that will continue to give you engine information if the EFIS fails.
I'm sure you'll be happy with your choice. Just wanted to point out the cost differences are closer than you thought.
RV-10 QB |
nukeflyboy
Posted: Tue Oct 25, 2011 6:39 pm Post subject: Re: Panel Choice |
Bob,
That's good info. You are correct about the engine monitor being independent from the EFIS which is not the case with the others. As far as cost goes the suppliers keep adjusting their prices so you need to use current data. Mine is already obsolete and it is only 2 months old. There is also a seemingly infinite number of combinations and this adds to the headache. The value of these discussions is to get the relevant data out in the open so the next guy is better prepared to ask the right questions.
RV-6 built and sold
Strasnuts
Posted: Tue Oct 25, 2011 6:50 pm Post subject: Re: Panel Choice |
With G3X you can have two EFIS screens fail and still get engine info. The GSU would have to fail or three screens.
780 Hours
Strasnuts
Posted: Wed Oct 26, 2011 5:51 am Post subject: Re: Panel Choice |
I had to clear one more thing up. I just checked all of my data subscription prices so here they are for comparison:
G3X Bundle 500.00 navdata, flightcharts, safetaxi, obstacle, terrain,
Airport directory
XM 745.55 XMWX Aviator with XM Select (1 Year Plan)
430W 385.00 Yearly NAVDATA for IFR
What bums me out about this is the bundling now for G3X with the GTN6XX/7XX is 924.00 and you can get it all through Garmin. As of now I have to buy the G3X from Garmin and the 430W separately from Jeppesen.
Also, my GX pilot will work individually if the EFIS goes TU.
780 Hours
jump2(at)sbcglobal.net Guest
Posted: Wed Oct 26, 2011 6:51 am Post subject: Panel Choice |
Just to let you know I just got off the phone with Garmin even though I have a G500 and dual 430w's they won't give me the lower price either because thay are not the new GTN.
Jeppesen does give you a lower price for the second 430.
The new GTN are coded so the card can be used in only one specific unit and not swapped around.
So I buy the nav data from Jep and will keep the Ipad up to date and update the 696 once a year.
Patrick Thyssen
N15PT 383hrs
--- On Wed, 10/26/11, Strasnuts <sean(at)braunandco.com> wrote:
Subject: Re: Panel Choice
Date: Wednesday, October 26, 2011, 8:51 AM
--> RV10-List message posted by: "Strasnuts" <[url=/mc/compose?to=sean(at)braunandco.com]sean(at)braunandco.com[/url]>
Airport directory
40936
http://forums.matronics.com/viewtopic.php?p=356026#356026
http======================== [quote][b]
