Koger Sunshade
Martin Olliver
PostPosted: Tue Oct 25, 2011 11:25 am    Post subject: Koger Sunshade Reply with quote
I have been thinking about fitting a Koger sunshade to my Europa to use on the odd day of sunshine that passes for summer in the UK! One of the benefits of the Koger is that it will reflect sunlight with the silvered finish.
Fitting should not be a problem as the company can supply a bolt on type as against the double sided tape which is the standard fitting method.
My main worry is the clearance at head height, this for me is limited at best.
The other thing is to ensure that the sunshade retracts well behind the door openings to ensure ease of entry / exit of crew.
Any one with any experience of this type of sunshade and it's possible down side?
Photos of sunshades can be found by google "Koger sunshades"
Thank you.
Martin.
Last edited by Martin Olliver on Sun Oct 30, 2011 12:26 am; edited 1 time in total
nigel henry
PostPosted: Tue Oct 25, 2011 12:32 pm    Post subject: Sunshade Reply with quote
forget blinds use solar film so you can see the plane that might be above lots of options xxxx Nigel
or my LAA baseball Cap and glasses
[quote] Subject: Sunshade
Date: Tue, 25 Oct 2011 12:25:11 -0700
--> Europa-List message posted by: "Martin Olliver" <martflynut(at)aol.com>
Thank you.
Martin.
http://forums.matronics.com/viewtopic.php?p=355979#355979
Martin Olliver
PostPosted: Wed Oct 26, 2011 12:20 am    Post subject: Re: Sunshade Reply with quote
True Nigel but I already have tinted windows.
