Sealing Baggage Rear Bulkhead
fdombroski
PostPosted: Wed Oct 26, 2011 1:05 pm    Post subject: Sealing Baggage Rear Bulkhead Reply with quote
I am getting a significant draft in the back seat from the channels on the bulkhead at the aft end of the baggage compartment. What has been used to seal the gaps created by the corrugated grooves?
Frank
Frank Dombroski
Multiple Offender RV-8, 7A, 10 x 2
RV-10 2.0 N46VT 2015
KSMQ Somerset Airport NJ
rene(at)felker.com
PostPosted: Wed Oct 26, 2011 3:09 pm    Post subject: Sealing Baggage Rear Bulkhead Reply with quote
I have an interior from Abbey at Flightline. Part of the kit is a cover
that goes over the bulkhead and extends to the cabin wall. It limits the
amount of air that gets through.
Rene' Felker
N423CF
801-721-6080
jesse(at)saintaviation.co
PostPosted: Wed Oct 26, 2011 4:10 pm    Post subject: Sealing Baggage Rear Bulkhead Reply with quote
Do you have your door seals on yet? If not, that will probably make the difference.
Jesse Saint
I-TEC, Inc.
jesse(at)itecusa.org
www.itecusa.org
www.mavericklsa.com
C: 352-427-0285
O: 352-465-4545
F: 815-377-3694
Frank
Frank Dombroski
RV-10 N10FD Flying
RV-8 N84FD Finished and sold :-{
http://forums.matronics.com/viewtopic.php?p=356049#356049
Albert Gardner
PostPosted: Wed Oct 26, 2011 4:45 pm    Post subject: Sealing Baggage Rear Bulkhead Reply with quote
I filled them with RTV, left it a little proud, covered the edge of the bulkhead with clear tape so that the RTV would not stick to the frame, and then installed the bulkhead and let the RTV cure.
Albert Gardner
Yuma, AZ
N991RV
Jesse Saint
I-TEC, Inc.
www.itecusa.org
www.mavericklsa.com
C: 352-427-0285
O: 352-465-4545
F: 815-377-3694
> Thanks
> Frank
> Frank Dombroski
> RV-10 N10FD Flying
RV-9A N872RV
RV-10 N991RV
Strasnuts
PostPosted: Wed Oct 26, 2011 4:54 pm    Post subject: Re: Sealing Baggage Rear Bulkhead Reply with quote
I have the 4 vents that are built from the plans plus the 4 vents in the overhead console. I have the mcmastercarr seal that seals up all around the doors. Sometimes I wonder where all the air is going or if it is pressurizing the cabin:). It might be nice to have those open so there is somewhere for the air to go. Built in outflow valves. Maybe I'm crazy. I guess in the winter it would be nice to close them up. The tail has all the holes but I sealed up most in the forward fuselage.
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours
gengrumpy(at)aol.com
PostPosted: Wed Oct 26, 2011 6:09 pm    Post subject: Sealing Baggage Rear Bulkhead Reply with quote
I used a sheet of 1/2 inch foam rubber treated with fire retardant and glued it to the back of the 2 removable bulkhead pieces.
Solved the problem for me.
Got my foam from Flightline Interiors.
grumpy
N184JM
Frank
Frank Dombroski
RV-10 N10FD Flying
fdombroski
PostPosted: Wed Oct 26, 2011 6:42 pm    Post subject: Re: Sealing Baggage Rear Bulkhead Reply with quote
The doors are sealed. I have the 4 fuse vents, plus 4 overhead vents. I have plenty of airflow in the summer. At altitude, and during the winter the cold air from the tail cone is flowing aggressively past the rear baggage bulkhead. This is the corrugated structure.
Looks like 1/2 inch foam is the probable solution.
Frank
Frank Dombroski
rv10flyer
PostPosted: Fri Oct 28, 2011 5:05 am    Post subject: Re: Sealing Baggage Rear Bulkhead Reply with quote
I sealed off aileron pushrod openings, wing spar openings, still need to do baggage bulkhead and elevator pushrod at rear spar.
Wayne G.
