		cjhukill(at)cox.net Guest
				 Posted: Sun Oct 30, 2011 5:26 am    Post subject: Recreational pilot |
				When I built my RV-8 ten years ago, I had an engine  built that produced 210 HP, but was limited by placards to 180 for the purpose  of qualifying it to be flown under the Recreational pilots license. Back then  AOPA was trying to get the Feds to allow that class of pilot to operate under  the medical self certification exemption that is allowed for sport pilots,  glider and balloon pilots. The restrictions back then would also require a fixed  pitch prop, so I put one of those on as well.
  The Feds didn't go for it then, but said they would  re-evaluate after the Sport pilots exemption has been in effect for about ten  years. Well in the last ten years, there has been zero medical deficiency caused  accidents for sport pilots. Now, again the EAA and AOPA lawyers are submitting  to the FAA an exemption to allow the Rec pilots to self certify. The aircraft  requirements would once again allow for a max of 180HP, but not a restriction  for fixed pitch prop. The 2 seat restriction is also removed, and replaced with  "one Passenger". So my question is...How does the RV10 perform with the reduced  payload of 1 pax and 180HP? It would be interesting to experiment with a flying  RV10 that was limited by how far in you push the throttle to see if it would be  practical to placard your engine instruments to allow you to operate under those  conditions without a medical. Even  if the Feds required modifications to  your IO540 to physically limit you to 180, at what altitude? The rules would  require you to operate under 10,000 msl, but you could probably still pull 180HP  at that altitude with your downrated motor. And you could still have the other  80 HP available for emergencies down low.  A pilot with a medical could  simply remove whatever limiting devise is require (placards) and fly it like a  normal RV10. It would be nice to have that flexibility and would open your  machine up to a whole other class (market) of pilots.
  Chris Hukill
		bhughes(at)qnsi.net Guest
				 Posted: Sun Oct 30, 2011 8:30 am    Post subject: Recreational pilot |
				Chris,
 I would expect a climb rate of 600-700 fpm at 180 HP with fwf weight equal to the io 540. Lighter fwf may make the rear baggage area worthless.
 Bobby
 On Oct 30, 2011, at 8:37 AM, "Chris Hukill" <cjhukill(at)cox.net (cjhukill(at)cox.net)> wrote:
  	  | Quote: | 	 		    When I built my RV-8 ten years ago, I had an engine  built that produced 210 HP, but was limited by placards to 180 for the purpose  of qualifying it to be flown under the Recreational pilots license. Back then  AOPA was trying to get the Feds to allow that class of pilot to operate under  the medical self certification exemption that is allowed for sport pilots,  glider and balloon pilots. The restrictions back then would also require a fixed  pitch prop, so I put one of those on as well.
  Chris Hukill
		Kelly McMullen
				 Posted: Sun Oct 30, 2011 1:15 pm    Post subject: Recreational pilot |
				I would expect the FAA to place the same stringent requirements on a qualifying aircraft as they do for Light Sport. That is that from certification forward it must have met the requirements of the category at all times. In other words they don't let you go back and forth between categories. Hard to say if they would place a gross wt limit on the category...don't recall if there ever was one.  There are some numbers that Vans has for the prototype with Continental IO-360 engine as to performance. I don't believe that engine has ever been derated below 195hp.
 On Sun, Oct 30, 2011 at 9:21 AM, Bobby J. Hughes <bhughes(at)qnsi.net (bhughes(at)qnsi.net)> wrote:
  	  | Quote: | 	 		   Chris,
  Bobby
 #avg_ls_inline_popup{position:absolute;z-index:9999;padding:0px;margin:0px;overflow:hidden;wordWrap:break-word;color:black;font-size:10px;text-align:left;line-height:130%;}#avg_ls_inline_popup div{border-width:3px;border-style:solid;padding:3px;padding-left:8px;padding-right:8px;-moz-border-radius:5px;-webkit-border-radius:5px;}#avg_ls_inline_popup .red{border-color:#D20003;;background-color:#F5D4C1;;}#avg_ls_inline_popup .orange{border-color:#F57301;;background-color:#FFD3B0;;}#avg_ls_inline_popup .yellow{border-color:#EAA500;;background-color:#FEEFAE;;}#avg_ls_inline_popup .green{border-color:#00A120;;background-color:#C3E5CA;;}
A&P/IA, EAA Tech Counselor
KCHD |
		davidsoutpost(at)comcast. Guest
				 Posted: Sun Oct 30, 2011 2:48 pm    Post subject: Recreational pilot |
				There is also a maximum 130 knot limitation.
 David Clifford
 RV-10 Builder
 Howell,  MI
 To: "RV10 post msg" <rv10-list(at)matronics.com>
 Sent: Sunday, October 30, 2011 9:22:01 AM
 Subject: Recreational pilot
  Chris Hukill
		Bob Turner
				 Posted: Sun Oct 30, 2011 7:59 pm    Post subject: Re: Recreational pilot |
				I don't recall any speed limitations for recreational pilots. There is one for Sport Pilots.
 The FAR wording says the aircraft must not have been certificated for more than 2 seats. So I don't think you can go back and forth between a "regular" RV-10 (4 seats) and a "recreational" one. You have to declare the number of seats when you get your A/W inspection. Once in writing, it's not easy to change.
  _________________ Bob Turner
RV-10 QB |
		Bob Turner
				 Posted: Sun Oct 30, 2011 8:05 pm    Post subject: Re: Recreational pilot |
				Ignore my last comment. I see that you say the FAA has changed the wording from 2 seats to one passenger. Is this done, or a proposal?
RV-10 QB |
				 Posted: Sun Oct 30, 2011 9:32 pm    Post subject: Recreational pilot |
				Not to put too fine a point on it but... I think one would end up with an expensive, heavy, underpowered aircraft that has minimal resale potential.
 Robin
		richard.beebe(at)yale.edu Guest
				 Posted: Fri Nov 04, 2011 6:41 am    Post subject: Recreational pilot |
				No, this is a different animal. They're not talking about adding another
 category of aircraft. And actually there's some confusion in the
 original message. It doesn't just apply to pilots with Recreational
 licenses.
 EAA and FAA are going to submit, in January, a proposal to the FAA that
 would let pilots flying recreationally to self-certify. Under the
 proposed exemption, pilots holding recreational, private, commercial, or
 airline transport pilot certificates who only fly recreationally could
 use the same driver’s license medical self-certification standard
 currently available to sport pilots. The limitations would be that the
 plane has to have 180hp or less, fixed gear, max 4 seats, in daylight
 VFR, with up to one passenger. The pilot will have to take and pass an
 on-online course that shows they understand the ramifications of
 self-certification (it'll be similar to the ADIZ course in size and
 difficulty I think). You'll get a card to carry that shows you've passed.
 The specs on the aircraft were derived from the limitations imposed on
 Rec pilots as that's something the FAA is comfortable with.
 Since the proposal hasn't been submitted yet, the details could, of
 course, change.
 --Rick
 On 10/30/2011 5:09 PM, Kelly McMullen wrote:
  	  | Quote: | 	 		   I would expect the FAA to place the same stringent requirements on a
  below 195hp.
		Kelly McMullen
				 Posted: Fri Nov 04, 2011 6:58 am    Post subject: Recreational pilot |
				Hi Rick,
 I understand that the EAA and AOPA are wanting to define it as a set
 of rules that apply to a pilot. Odds are very strong that the FAA will
 want to apply it to a set of aircraft qualifying requirements, because
 that is much easier for them to draw the line in the sand. (inspectors
 can more easily determine if an airplane conforms than if a pilot
 does)  I was under the impression that the request had been submitted.
 Otherwise, why all the press hoopla for a non-submittal?
 Kelly
 On Fri, Nov 4, 2011 at 7:37 AM, Rick Beebe <richard.beebe(at)yale.edu> wrote:
  category of aircraft. And actually there's some confusion in the original
  message. It doesn't just apply to pilots with Recreational licenses.
  would let pilots flying recreationally to self-certify. Under the proposed
  exemption, pilots holding recreational, private, commercial, or airline
  transport pilot certificates who only fly recreationally could use the same
  driver’s license medical self-certification standard currently available to
  sport pilots. The limitations would be that the plane has to have 180hp or
  less, fixed gear, max 4 seats, in daylight VFR, with up to one passenger.
  The pilot will have to take and pass an on-online course that shows they
  understand the ramifications of self-certification (it'll be similar to the
  ADIZ course in size and difficulty I think). You'll get a card to carry that
  The specs on the aircraft were derived from the limitations imposed on Rec
  Since the proposal hasn't been submitted yet, the details could, of course,
  change.
  --Rick
KCHD |
				 Posted: Mon Nov 07, 2011 6:32 am    Post subject: Recreational pilot |
				I think because they wanted a "big announcement" at AOPA Summit. They're
 still working out the legalese of the proposal and they're waiting until
 after the elections. Word I have is that it will be submitted in January.
 --Rick
 On 11/04/2011 10:55 AM, Kelly McMullen wrote:
    Hi Rick,
  Kelly
