		rv10rob(at)gmail.com Guest
				 Posted: Fri Nov 11, 2011 12:16 pm    Post subject: Heavy wing |
				Hi, all... I have about 90 hours on the RV-10 now, and everything is great, with the exception of a significantly heavy right wing. I feel like I've tried just about everything, but still can't get it figured out, so looking for suggestions from the group.  Here's what I know (and what I've ruled out):
   - Using the standard aileron trim, it takes nearly full left trim to keep the wings level at cruise speed. The heavy wing is less noticeable at slower speeds, so it's definitely an aerodynamic problem.
 -   Problem has existed since first flight, so it's not a new issue and not an issue with the leg and wheel fairings
 - Rigghing is correct (per plans, verified with the aileron bellcrank templates). I tried adjusting one side a little, but as you can imagine, since the ailerons are interconnected, it didn't make a difference).
 - Flaps are even (measured with a digital level).  just out of curiosity, I lowered the right flap a little to see if it would make a difference.  It did not.
 - Loading is even (i.e. see the problem w/ balanced load in the cabin and balanced fuel tanks).
 - Perhaps the most telling: when holding the airplane level, the ailerons are even with the flaps (in the reflex position).  When I let go of the stick, with neutral trim, the left aileron goes down and the right up slightly (maybe 1/8" at most). This is consistent with the heavy left wing.
 - I've verified that the ailerons are mounted evenly with respect to the rear wing spar, since Van's "heavy wing" document says this can cause issues.
 - Ailerons seem to be well-built and symmetrical (they're quickbuilds).
  I've tried everything in Van's "heavy wing" document and talked to several people over there.  They don't have any ideas for me, other than to put a wedge under the left aileron to balance it out (which I've had on there for 60 hours or so).  N410RV has a trim wedge, and one of the guys at Van's says that Van's personal RV-10 has a sizeable trim wedge. too.  Though I'm usually pragmatic about issues like this, it seems that adding the wedge is just admitting defeat--something is giving it a heavy right wing (specifically something is deflecting the left aileron down and the right aileron up), and I should be able to figure out what it is.
 Anyone have any ideas?  Much appreciated.
 -Rob
 Rob Kochman
  RV-10 Flying since March 2011
  Woodinville, WA
  http://kochman.net/N819K
		rene(at)felker.com Guest
				 Posted: Fri Nov 11, 2011 12:58 pm    Post subject: Heavy wing |
				This may have no merit…..so…..
 Wing tip?  I did not see anything about checking the wingtip and their position and possible effect.  I spent a lot of time rebuilding mine because they did not line up with my Ailerons and were not the same on both sides.  If I remember right , the tips have a little bit of a dihedral to them and being way out there on the wing, they could have a big effect if they were different.
 Just a wag….
 Good luck, don’t let the #$%$ win…….or just go ugly early and put the wedge on….
 Rene' Felker
 N423CF
 801-721-6080
 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rob Kochman
 Sent: Friday, November 11, 2011 1:13 PM
 To: rv10-list
 Subject: Heavy wing
 -Rob
 Rob Kochman
 Woodinville, WA
  01234567890123456789012
		Bob Turner
				 Posted: Fri Nov 11, 2011 1:11 pm    Post subject: Re: Heavy wing |
				I know you said you tried everything in Van's 'help' document, but....
 In my case it was the left wing heavy in flight, and I could see the ailerons deflected, too.
 I moved the left aileron outboard attachment point lower by about 1/32" (barely noticeable) and it took out 90% of the heaviness. e.g., it is very sensitive to this.
 Bob
  _________________ Bob Turner
RV-10 QB |
				 Posted: Fri Nov 11, 2011 2:24 pm    Post subject: Heavy wing |
				As already mentioned, check the aileron height (compare left/right at inboard and outboard attach points using a straight edge running aft off the wing).  A very small difference between aileron heights will make a big difference – and just how heavy the wing is will be dependent on speed.  I found this problem in several heavy wing RVs, including my RV-8A.  Moving the offending attachment point completely solve my problem on the 8A.
 Other things to look at:
 <![if !supportLists]>-          <![endif]>Do not assume that if the ailerons (in neutral position) are even with the flaps (in reflex position) that they are rigged correctly as there may be a slight twist in the flap.  Put the flaps in the reflex position, clamp one aileron to the flap, then compare using a straight edge running aft off the wing the two ailerons deflection.  If there is a difference, adjust the push rods until they are exactly the same.
 <![if !supportLists]>-          <![endif]>Do the same straight edge measurement on the flaps to compare.  If you do have a slight twist in a flap, I would expect that you can compensate for it if the ailerons are symmetrically rigged as they provide the higher moment arm.
 <![if !supportLists]>-          <![endif]>Once you have the ailerons at the same deflection, then look at the wingtips.  When building the wingtips you can move the wingtip tailing edge up or down a good quarter of an inch when fitting the aft rib.
 Of note, the easy tone in Van’s instructions on rigging the aircraft never seemed right for me.  After chasing my tail on a heavy wing I went back to basics as discussed above and found the small difference in aileron mount height.  Rigging is a big deal – and something that few will get right on the first attempt.
 Carl
 Sent: Friday, November 11, 2011 3:13 PM
 To: rv10-list
 Subject: Heavy wing
 -Rob
 Rob Kochman
 Woodinville, WA
		n520tx(at)gmail.com Guest
				 Posted: Fri Nov 11, 2011 2:55 pm    Post subject: Heavy wing |
				On Fri, 2011-11-11 at 17:20 -0500, Carl Froehlich wrote:
  	  | Quote: | 	 		   Moving the offending attachment point
 How does one "move the attach point"? The ailerons are attached to a
 powder coated bracket that attaches at the pivot point of bracket
 riveted to the spar - I just looked at my wings in the cradle and tried
 to imagine how this would  be done. Are you talking about elongating the
 holes in that bracket to allow the aileron to shift up or down relative
 to that pivot point ?
 A photo with some arrows to point things out would go a long way.
 I'm not disagreeing, just trying to visualize how you did this.
 --Ron
		robin(at)PaintTheWeb.com Guest
				 Posted: Fri Nov 11, 2011 3:31 pm    Post subject: Heavy wing |
				I think Matt elongated the hole on his -8 with success. I believe he was surprised at how very small the hole modification required. One may want to check the recent archives or throw the question out to Matt.
 Robin
				 Posted: Fri Nov 11, 2011 4:13 pm    Post subject: Heavy wing |
				On the 8A I got the brackets from Van's that don't have holes and drilled
 holes slightly offset from center.  I don't know if these "no hole" brackets
 are available for the 10.  I've seen others elongate the holes the small
 amount needed (I understand this was the advice the person received from
 Van's but that is second hand).  Another approach is to take the current
 brackets and weld the holes shut, grind the weld flat and then re-drill.
 If the aileron height is off, you typically only need to adjust one bracket
 as the fix.
 Carl
		speckter(at)comcast.net Guest
				 Posted: Fri Nov 11, 2011 4:44 pm    Post subject: Heavy wing |
				I am sure you probably checked this but is your rudder  neutral with the heavy wing.  Does the heavyness change as you step on one  side or the other?
  Gary Specketer
  Sent: Friday, November 11, 2011 3:12 PM
  To: rv10-list (rv10-list(at)matronics.com)
  Subject: Heavy wing
  -Rob
  Rob Kochman
  Woodinville, WA
 href="http://www.aeroelectric.com">www.aeroelectric.com
 href="http://www.buildersbooks.com">www.buildersbooks.com
 href="http://www.homebuilthelp.com">www.homebuilthelp.com
 href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List
		Strasnuts
  Joined: 10 Feb 2009 Posts: 502 Location: Salt Lake City, UT
				 Posted: Fri Nov 11, 2011 5:10 pm    Post subject: Heavy wing |
				When I started flying mine I had a heavy wing. During phase 1 I was always alone, of course.  Right rudder obviously helps and putting a right seater helps too.  I remember reading a lot of these on the FAQ's on vans site. You might want to look over these.  They sell the brackets undrilled and recommend elongating the originals first.
 On Nov 11, 2011, at 13:12, Rob Kochman <rv10rob(at)gmail.com (rv10rob(at)gmail.com)> wrote:
 [quote]Hi, all... I have about 90 hours on the RV-10 now, and everything is great, with the exception of a significantly heavy right wing. I feel like I've tried just about everything, but still can't get it figured out, so looking for suggestions from the group.  Here's what I know (and what I've ruled out):
 -Rob
 Rob Kochman
  Woodinville, WA
  _________________ 40936
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours |
		Bob Turner
				 Posted: Fri Nov 11, 2011 6:15 pm    Post subject: Re: Heavy wing |
				re: moving the aileron down.
 Yes, I elongated the holes in the steel bracket.
 Vans sells undrilled brackets for exactly this purpose. Unfortunately, not for the -10. But they say the ones for the -7 or -8 '...can be made to work...'.
RV-10 QB |
		Kellym
				 Posted: Fri Nov 11, 2011 6:47 pm    Post subject: Heavy wing |
				I have seen several RV7s that the stock right aileron outer bracket made
 that aileron 1/8-1/4" high..like Vans punched holes are off. I would
 think builder error, except it is common when you start looking for it.
 Doesn't take much elongation, and you can do say 1/16th on wing, 1/16th"
 on bracket.
 On 11/11/2011 7:15 PM, Bob Turner wrote:
  Bob Turner
  RV-10 QB
  http://forums.matronics.com/viewtopic.php?p=357599#357599
KCHD |
		arplnplt(at)gmail.com Guest
				 Posted: Fri Nov 11, 2011 8:33 pm    Post subject: Heavy wing |
				I agree with Gary.Try a rudder trim block if you don't have rudder trim.  I thought I had a heavy wing until I played with my rudder trim after the first few flights.
  David Leikam
 RV10
 Flying
 On Nov 11, 2011, at 6:42 PM, Gary Specketer wrote:
 [quote]     I am sure you probably checked this but is your rudder  neutral with the heavy wing.  Does the heavyness change as you step on one  side or the other?
  Gary Specketer
  Subject: Heavy wing
  -Rob
  Rob Kochman
  Woodinville, WA
				 Posted: Fri Nov 11, 2011 10:09 pm    Post subject: Heavy wing |
				Thanks, guys.  It seems like my wing tips are even, and I've verified that the rudder is correct (i.e. ball is centered) when noting the heavy wing.
 I checked that the ailerons are mounted on the wing evenly, but I'll check more closely.  Not sure I would have noticed a 1/32" difference, and it sounds like such a little difference might actually matter.
 Thanks again, and I'll report back.
 -Rob
 On Fri, Nov 11, 2011 at 8:27 PM, David Leikam <arplnplt(at)gmail.com (arplnplt(at)gmail.com)> wrote:
   	  | Quote: | 	 		  I agree with Gary. Try a rudder trim block if you don't have rudder trim.  I thought I had a heavy wing until I played with my rudder trim after the first few flights.
    David Leikam
 RV10
 Flying
  	  | Quote: | 	 		       I am sure you probably checked this but is your rudder  neutral with the heavy wing.  Does the heavyness change as you step on one  side or the other?
  Gary Specketer
  Subject: Heavy wing
  -Rob
  Rob Kochman
  Woodinville, WA
 _blank">www.aeroelectric.com
 Rob Kochman
  Woodinville, WA
		coop85(at)verizon.net Guest
				 Posted: Sun Nov 13, 2011 12:33 pm    Post subject: Heavy wing |
				This may have been mentioned already, but on the RV-6 the solution was to squeeze, ever so slightly, the trailing edge of the aileron or tap it a little to make the trailing end more square.  It worked like a champ!  There might be some comments in the RV-6 archives.
 Marcus
 -Rob
    David Leikam
 RV10
 Flying
  Gary Specketer
  Subject: Heavy wing
  -Rob
  Rob Kochman
  Woodinville, WA
 Rob Kochman
  Woodinville, WA
		Kellym
				 Posted: Sun Nov 13, 2011 12:48 pm    Post subject: Heavy wing |
				That only works on RVs that have the trailing edge as a bent piece of
 aluminum. The -10 ailerons are two sheets of aluminum double flush
 riveted with an extrusion between them(except the quick builds Manila
 doesn't do double flush, grrr)
 On 11/13/2011 1:30 PM, Marcus Cooper wrote:
  	  | Quote: | 	 		   This may have been mentioned already, but on the RV-6 the solution was
  Marcus
  heavy wing.
  -Rob
  <mailto:arplnplt(at)gmail.com>> wrote:
      I agree with Gary.
      first few flights.
      David Leikam
      RV10
      Flying
 >     Gary Specketer
 >     *From:* Rob Kochman <mailto:rv10rob(at)gmail.com>
 >     *Sent:* Friday, November 11, 2011 3:12 PM
 >     *To:* rv10-list <mailto:rv10-list(at)matronics.com>
 >     *Subject:* Heavy wing
 >       * Using the standard aileron trim, it takes nearly full left
 >       * Problem has existed since first flight, so it's not a new
 >       * Rigghing is correct (per plans, verified with the aileron
 >       * Flaps are even (measured with a digital level).  just out of
 >       * Loading is even (i.e. see the problem w/ balanced load in the
 >       * Perhaps the most telling: when holding the airplane level,
 >         position). *When I let go of the stick, with neutral trim,
 >         1/8" at most). This is consistent with the heavy left wing.*
 >       * I've verified that the ailerons are mounted evenly with
 >       * Ailerons seem to be well-built and symmetrical (they're
 >         quickbuilds).
 >     what it is.
 >     -Rob
 >     Rob Kochman
 >     Woodinville, WA
 >     href="http://www.aeroelectric.com  <http://www.aeroelectric.com/>">www.aeroelectric.com  <http://www.aeroelectric.com/>
 >     <http://www.buildersbooks.com/>">www.buildersbooks.com
 >     <http://www.homebuilthelp.com/>">www.homebuilthelp.com
 >     href="http://forums.matronics.com
 >     <http://forums.matronics.com/>">http://forums.matronics.com
 >     href="http://www.aeroelectric.com/">www.aeroelectric.com  <http://www.aeroelectric.com/>
 >     href="http://www.buildersbooks.com/">www.buildersbooks.com  <http://www.buildersbooks.com/>
 >     href="http://www.homebuilthelp.com/">www.homebuilthelp.com  <http://www.homebuilthelp.com/>
 >     href="http://www.matronics.com/contribution">http://www.matronics.com/contribution
 >     href="http://forums.matronics.com/">http://forums.matronics.com  <http://forums.matronics.com/>
      _blank">http://www.matronics.com/contribution *
  Rob Kochman
  Woodinville, WA
KCHD |
				 Posted: Sun Nov 13, 2011 6:26 pm    Post subject: Heavy wing |
				Yep, I completely forgot that part, good catch.  Not a very useful tip, but unfortunately not my first time.
 Marcus
 On Nov 13, 2011, at 3:45 PM, Kelly McMullen wrote:
 That only works on RVs that have the trailing edge as a bent piece of aluminum. The -10 ailerons are two sheets of aluminum double flush riveted with an extrusion between them(except the quick builds Manila doesn't do double flush, grrr)
  	  | Quote: | 	 		   This may have been mentioned already, but on the RV-6 the solution was to squeeze, ever so slightly, the trailing edge of the aileron or tap it a little to make the trailing end more square.  It worked like a champ!  There might be some comments in the RV-6 archives.
  Marcus
  -Rob
  On Fri, Nov 11, 2011 at 8:27 PM, David Leikam <arplnplt(at)gmail.com <mailto:arplnplt(at)gmail.com>> wrote:
     I agree with Gary.
     first few flights.
     David Leikam
     RV10
     Flying
 >    Gary Specketer
 >        quickbuilds).
 >    what it is.
 >    -Rob
 >    --     Rob Kochman
 >    Woodinville, WA
  Rob Kochman
  Woodinville, WA
