		PMorel
  Joined: 09 Jul 2007 Posts: 62 Location: Locust Grove, GA USA
				 Posted: Sat Nov 12, 2011 5:39 am    Post subject: Classic IV Firewall |
				I'm building a Classic IV and was hoping someone has the dimensions of the lower firewall panels.  I'll be installing a Rotax 912 and I have the cutout for the starter for the panel.  I only need the dimensions for the center and ether left or right panel since I assume they are the same size.  Thanks
 Paul
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ Paul Morel
912 Speedster
Locust Grove, GA
www.WingsAirPhotos.com |
		lcfitt(at)sbcglobal.net Guest
				 Posted: Sat Nov 12, 2011 8:19 am    Post subject: Classic IV Firewall |
				Paul,
  The dimensions of what I would call the foot wells are :  top forward bend begins right below the side engine mount and is 4" to the  downward bend.  The lower section runs from that bend 10-3/8" to the bottom  bend.  This results is a  foot well that extends forward of the  plane of the firewall slightly under 4" at the top, tapering to zero at the  bottom.  The extension that fits over and around the bottom front of the  fuselage is 1-3/8" top to bend and then extends aft under the fuselage 5-3/8".  The gap between the foot wells is 6" wide.
 If this sounds confusing, drop another note.
  Lowell
  Sent: Saturday, November 12, 2011 5:36 AM
  To: kitfox-list(at)matronics.com (kitfox-list(at)matronics.com)
  Subject: Classic IV Firewall
 Paul
 href="http://www.aeroelectric.com">www.aeroelectric.com
 href="http://www.buildersbooks.com">www.buildersbooks.com
 href="http://www.homebuilthelp.com">www.homebuilthelp.com
 href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
