Rick Lewis
Joined: 03 Jul 2007 Posts: 122 Location: Kingston, Tn.
Posted: Mon Nov 14, 2011 2:14 pm Post subject: Nose wheel on a Kolb MK3X |
I have not worked on my MKx in quite a while but have been re-motivated with the thought of building it with the new nose wheel option. What do you guys think about this option?
_________________ Rick Lewis
(VW Watercooled Engine) |
Mike Welch
Posted: Mon Nov 14, 2011 2:44 pm Post subject: Nose wheel on a Kolb MK3X |
Hi Rick,
I think it could be a good idea. I'll work with ya on the design. I've already scribbled a drawing just for grins.
BTW, what do you mean "with the new nose wheel option"? Are you referring to the Firestar's new front wheel or
has Kolb Aircraft come up with a new bolt-on option for the MkIIIX? (or will the Firestar front wheel work with either one?)
Mike Welch
On Nov 14, 2011, at 4:14 PM, Rick Lewis wrote:
Rick Lewis
http://forums.matronics.com/viewtopic.php?p=357860#357860
Dana
Posted: Mon Nov 14, 2011 4:24 pm Post subject: Nose wheel on a Kolb MK3X |
At 05:14 PM 11/14/2011, Rick Lewis wrote:
| Quote: | --> Kolb-List message posted by: "Rick Lewis" <cktman(at)hughes.net>
I have not worked on my MKx in quite a while but have been re-motivated with the thought of building it with the new nose wheel option. What do you guys think about this option? |
Why put a training wheel on a perfectly good taildragger?
-Dana
Alcohol, tobacco and firearms should be a convenience store, not a government agency.
Rick Lewis
Posted: Mon Nov 14, 2011 5:18 pm Post subject: Re: Nose wheel on a Kolb MK3X |
Thanks Mike for the reply. Kolb has NOT afford an option for the MKX, as far as I know, but they have impressed me with what they have done so far on this. I talked to Brian today about this modification on the MKX and I will be going to see them in a fews days to look at a prototype. If others are interested in this I will submit pictures that I take. I Will be looking for other positive replies on this.
I really would appreciate any idea's YOU might have on me converting my MKX to a nose wheel aircraft. I have not covered the cage yet so that should be of some help. Rick cktman(at)hughes.net
David d.
Joined: 04 Jul 2011 Posts: 60 Location: Fitzgerald Ga.
Posted: Mon Nov 14, 2011 5:21 pm Post subject: Re: Nose wheel on a Kolb MK3X |
And why not?? Nobody is asking ya to put one on yours.
_________________ Kolb Mark IIIX 582 Blue head |
Rick Lewis
Posted: Mon Nov 14, 2011 6:35 pm Post subject: Re: Nose wheel on a Kolb MK3X |
Thanks ss568 for the remark, I feel the same way. Rick
David d.
Posted: Mon Nov 14, 2011 6:48 pm Post subject: Re: Nose wheel on a Kolb MK3X |
Rick,
I would be interested in converting my mk 3 to a tri . If you get some pictures they would be appreciated.
David d.
ces308
Joined: 03 Nov 2008 Posts: 317 Location: houghton lake ,mi
Posted: Mon Nov 14, 2011 8:54 pm Post subject: Re: Nose wheel on a Kolb MK3X |
Just curious....Why don't you like the tail dragger version??? They are so easy to handle...not sure why you would want to go through the extra work....Please post the pictures ..I would never do it ,but would like to see how they set it up...
chris ambrose
M3X/Jabiru A-2200 238.hrs
N327CS
Posted: Tue Nov 15, 2011 5:39 am Post subject: Nose wheel on a Kolb MK3X |
Folks:
Right off hand I can think of a couple things that a nose gear might affect
on a MKIIIx or a MKIIIc.
-The nose wheel and mount will add a lot more weight and drag than a tail
wheel.
-We already have an inherent problem with a high mounted pusher
configuration. The high thrust line wants to push the nose of the aircraft
down. Takes a lot of nose up trim to keep it happy. If we add a nose
wheel, it will add to the nose down trim problem. Low drag up front will
combine with a high thrust line to try and push the nose down even more.
The standard main gear on Kolb aircraft places most of the weight on the
main gear with a light tail wheel. It is very easy to handle on the ground.
As easy, or more so, than tricycle gear. That is why Homer designed it that
way.
_________________ John Hauck
Titus, Alabama |
herbgh(at)nctc.com Guest
Posted: Tue Nov 15, 2011 6:05 am Post subject: Nose wheel on a Kolb MK3X |
John
Valid points...but----
Looks as if we already have a similar configuration with the Tri
Firestar....The interview that I saw with Brian, indicated good
flying qualities..
Maybe Travis will give us some feedback on the ground handling
qualities and your concerns?
Herb
At 07:37 AM 11/15/2011, you wrote:
Folks:
wheel.
way.
Posted: Tue Nov 15, 2011 6:18 am Post subject: Nose wheel on a Kolb MK3X |
Firestar....The interview that I saw with Brian, indicated good flying
qualities..
Herb
Herb/Kolbers:
I've never seen the new tri-gear Firestar, nor have I talked with the
designer and test pilot. Know virtually nothing about it.
I have flown a MKIIIx and am familiar with it. I think that is what we are
talking about here, adding a nose gear to the MKIIIx.
I am a tail wheel guy and partial to that configuration. This doesn't
change the inherent problems mounting a nose gear on a MKIIIx will generate.
Titus, Alabama |
Posted: Tue Nov 15, 2011 6:33 am Post subject: Nose wheel on a Kolb MK3X |
We have machines here that started out as taildraggers, I had one. The
change to the nose wheel option has happened without any drama and although
I have no figures I would guess that the tricycle is now in the majority.
I think you are wrong in describing the Xtra as `light on the tail`, mine
certainly is not, although you are right in saying that it would require a
major trim change to accommodate a front wheel. That would have to be a
redistribution of weight rather that just trimming it out.
I would certainly be interested in a trike gear but under our rules I
suspect that I would have to jump through quite a few hoops to get it
accepted on the register.
I don`t think that I will bother.
Pat
Mike Welch
Posted: Tue Nov 15, 2011 7:16 am Post subject: Nose wheel on a Kolb MK3X |
| Quote: | I don`t think that I will bother.
Pat
Pat, others,
I suspect the nosewheel/tailwheel argument is a lot like VGs, Mystery Oil, Seafoam, and a host of other unending
discussions.
Whether pro-tailwheel guys like it or not, there are probably lots of other guys who 'might' prefer a nosewheel. That doesn't make
either side wrong, it just may be what we are used to, or have a preference for. Much like VGs, or NO VGs.
That being said, without a doubt, to install a nosewheel on an Xtra would certainly require a heckava lot more than simply
bolting on a ready-made front wheel. (IMO)
The main gear's present location, which is designed for a taildragger weight distribution, would be a very poor place to adapt
for a nosewheel. It should be placed several inches rearward (after proper design calculations).
Plus, the added stresses a nosewheel would place on the very front portion of the fuselage would likely require some beefing up.
In other words....done properly, a nosewheel Xtra would need a signifcant re-design, strengthening the front end and relocating the
main gear mounts, maybe about 30" rearward or more. There may also be other design considerations...I would imagine.
If Kolb Aircraft were to seriously tackle this concept;
a) I would think the fuselage would require the appropriate modifications and new shape.
b) there darn sure would be a market for a nosewheel Xtra
c) it should be renamed, to clarify the distinction between nosewheel and tailwheel models.
The idea that a high thrustline doesn't make for a good nosewheel airplane seems a little weak, to me. If I had to guess, I'd bet there are FAR more
nosewheel/high engine lightplanes than there are tailwheel/high engine lightplanes. Titan Tornado, Quicksilvers, Carlsons, Rans S12, to name just a few.
Whether there are more of one or the other, doesn't mean the opposite style won't work, especially when designed correctly.
Just my humble little opinion.
Mike Welch
MkIII
neilsenrm(at)gmail.com Guest
Posted: Tue Nov 15, 2011 7:31 am Post subject: Nose wheel on a Kolb MK3X |
I started flying nose dragging airplanes and may still have more hours in them than tail daggers. With all the stories around I was also concerned about the Kolb before I flew it. Bottom line it isn't as much the nose verses tail as it is the overall aircraft design.
Of the planes that I have flown there is one nose wheel airplane that is much more difficult to fly (drive on the ground) than my Kolb and that is a Piper Saratoga. The higher landing/take off speeds with the weight of the plane makes this nose wheel airplane a challenge. Another plane I now rent in the winter, a Sport Cruiser has differential braking with no link to the castering nose wheel. This configuration took more adjustment than a Kolb. I will say that I once landed down wind on a paved runway and my Kolb was a challenge. The Kolb flying off grass is the easiest to handle of any airplane I have ever flown.
So with that said get a flight in a Kolb before you add the weight, drag, and complexity to a perfectly fine airplane.
Rick Neilsen
1st Redrive VW Powered MKIIIC
On Tue, Nov 15, 2011 at 8:37 AM, John Hauck <jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com)> wrote:
[quote] --> Kolb-List message posted by: "John Hauck" <jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com)>
Folks:
wheel.
way.
="_blank">www.aeroelectric.com
ooks.com" target="_blank">www.buildersbooks.com
et="_blank">www.homebuilthelp.com
le, List Admin.
le, List Admin.
byoungplumbing(at)gmail.c Guest
Posted: Tue Nov 15, 2011 7:57 am Post subject: Nose wheel on a Kolb MK3X |
the entire time i was building my mkiii, my brother kept telling me that
it needed a nose wheel... it needs a nose wheel,,, it needs a nose whee...
so when it was done i took him for a ride, when i showed him some slow s
turns down the runway with the tail in the air,,, and told him that this
was the hardest part of flying a tail dragger, he said,,," guess it dont
need a nose wheel, this dosent seem as bad as i had been led to believe."
many pilots when starting with a tail dragger, get a bit behind what is
going on and end up "stomping on snakes" when making adjustments to the
rudder. if , or should i say when, you learn that you should use a
constant steady pressure, and only enough to get the desired results, the
tail dragger tames down and is no longer a scary monster.
ask me how i know about the "stomping on snakes" my first few flights in a
super cub,,, well i am glad the runway was 75 ft wide. and now landing on
a 2 track road is doable.
my 2 cents
boyd young
mkiii utah
Mike Welch
Posted: Tue Nov 15, 2011 8:24 am Post subject: Nose wheel on a Kolb MK3X |
| Quote: | the tail dragger tames down and is no longer a scary monster.
boyd young
mkiii utah
Boyd,
I suspect you are hitting the nail on the head the best. For those of us with little, or NO
tailwheel time, I think all we want is a stable, unscary plane. Whether it is nosedragger, or taildragger,
we mostly prefer non-wingdragger.
Like Rick N. suggested, maybe we should just get a flight in a MkIII and relax. By all accounts,
evidently Kolbs are some of the best taildraggers around.
Mike W
Posted: Tue Nov 15, 2011 9:00 am Post subject: Nose wheel on a Kolb MK3X |
a few.
Mike Welch
MkIII
Mike W/Folks:
No argument here. I simply tried to contribute the effects of adding a nose
wheel to a MKIIIx, probably with the big nose (I am assuming the gentleman
has an older model MKIIIx).
I didn't say, "a high thrust line doesn't make for a good nose wheel
airplane."
There is no comparison between a MKIIIx and "Titan Tornado, Quicksilvers,
Carlsons, Rans S12, to name a few," when comparing nose and tail wheel
aircraft.
If and when you ever fly a MKIIIx, you will probably be immediately aware of
the high thrust line and how it affects flight characteristics and
performance, especially in cruise. Add a nose wheel to this characteristic
and it will only add to the high thrust line effect. Sort of like riding a
bicycle with one pedal. Then getting the other foot on a pedal and riding
with two. Suddenly there is a lot more force being applied. The drag on
the nose wheel will tend to compound the high thrust line and its
characteristic of pushing down on the nose.
I have no argument for or against, either nose or tail wheel, as I have no
argument with or without VGs. I have been there and done that, with
experience to back up my thoughts.
My MKIII and the couple other MKIII's with Hauck mods are "real" tail
draggers. Thom Riddle talks of his heavy tailed Slingshot. I can assure
you the Hauck/MKIII has more weight and much longer arm than a Slingshot. I
have flown both, many times, and can give a good comparison between my
airplane and a Slingshot. It will be much harder for a low time Kolb pilot,
or high time pilot of a standard built Kolb to adjust to my MKIII. However,
once you get the hang of it, in a short time it becomes normal, and the
benefits of not having to worry about getting your Kolb up on its nose,
either from power application or terrain surface or taxiing in a tail wind
will become quite apparent. In over 3,100 hours I have never had my MKIII
attempt to get the tail high and the nose low while maneuvering on the
ground in all types of terrain. I have put the Firestar, Firefly, and the
factory MKIII on their noses at one time or the other.
MKIII
Titus, Alabama |
Posted: Tue Nov 15, 2011 9:04 am Post subject: Nose wheel on a Kolb MK3X |
relax. By all accounts, evidently Kolbs are some of the best taildraggers
around.
Mike W
Mike W/Kolbers:
Maybe get some "actual pilot time" in a MKIII will help get a better picture
of that aircraft's handling characteristics.
I find it difficult to make effective changes to a proven aircraft design
without having actual experience flying that aircraft.
Titus, Alabama |
Posted: Tue Nov 15, 2011 9:05 am Post subject: Nose wheel on a Kolb MK3X |
my extra two cents....
I do not think it is about liking one design or the other...It is
what sells...and allows one to stay in business...
Innovation shows that Kolb is a viable company...
I suspect that they could have sold many times as many planes
had the nose dragger been in the stable... Most people train in that
miserable straight jacket of a plane, the cessna 150, and most of
the time their instructor has no tail time....It is during this stage
that the tail dragger fear is instilled in the neophyte...
Too...Kolb has to be concerned about what engines will be
available in the near future... no 447 or 503 I hear...
imho again Herb
At 10:21 AM 11/15/2011, you wrote:
> boyd young
> mkiii utah
Boyd,
Mike W
Posted: Tue Nov 15, 2011 9:36 am Post subject: Nose wheel on a Kolb MK3X |
I do not think it is about liking one design or the other...It is what
imho again Herb
Herb G/Kolbers:
Yes, I agree "staying in business" is of primary concern to Kolb Aircraft.
Another reason for all of us that build and fly Kolbs to give Kolb Aircraft
as much support as we can. Every little bit we use Travis Brown to supply
our parts, even if they cost a dollar or more, is a little bit more
insurance we are going to have Kolb Aircraft when we need them. If we fly
long enough, we are going to need repair and replacement parts.
I fly and have been flying my mkIII for nearly 20 years because I like my
airplane, I like what it does and what it doesn't do. If I didn't, I'd
either change it to suit "me" or I would sell it and build something else.
This flight to Starhill, LA, last weekend was great for refreshing my memory
of how much I enjoy the mkIII and my friends and folks that fly Kolbs. When
the mkIII sits in the hanger for months on end, I get those feelings I
probably need to sell it because of the cost of insurance, etc. Then I get
over to the airstrip, break ground, and I know why I still have it.
Titus, Alabama |
